Part Number: MSPM0L1105
Hi Team,
One of my customers is using MSPM0L1105, when set this MCU to SPI master, 3-wire mode, the PICO signal (the yellow rail in picture below, pink one is clock) is ramping slowly, the whole process takes 92us, which supposed to be ns rank. There is no pull-up or pull-down circuits around the pin, just equipped with a 100pF capacitor. If set this pin to GPIO function, it works normally, and it works when sending data.
Customers could not share the original code with us under restriction, could you please help to share your insights on this issue? Thanks a lot.
