Part Number: SYSCONFIG
I am considering configuring a BSL using UART or I2C with the MPSM0G1105.
I think this should be set in the "Configuration NVM" item in SysConfig, but even when I set it, the target pins do not change to the green "Pin Assigned" status.
For example, if I want to use BSL with I2C, do I need to assign the corresponding pins to be used with I2C?
Thank you in advance.
Hiroshi Yamada
