Part Number: TMS570LC4357
I have been working with the Clock Source Disable Clear Register (CSDISCLR) as described in the technical reference manual. I noticed an apparent discrepancy in the documentation that I would like to clarify.
According to the documentation of the CSDISCLR register (Figure 2-19 and Table 2-31):
- For bits clearing clock sources ([7-3], [1-0]):
- Reading 0: Clock source is enabled.
- Writing 0: Clock source state is unchanged.
- Reading 1: Clock source is enabled.
- Writing 1: Sets the clock source to the enabled state.
This documented behavior where both reading 0 and 1 indicate an enabled state seems contradictory and may lead to confusion regarding the actual state of the clock source.
My assumption is by considering typical behavior for such registers:
- Reading 0 usually indicates that the clock source is enabled.
- Reading 1 usually indicates that the clock source is disabled.
- Writing 0 has no effect.
- Writing 1 enables the clock source.
My question is: Is this a documentation error, or is there a specific reason for this behavior? Could you please provide clarification or the correct way to interpret these register operations, is my assumption correct?
Thank you for your assistance.
