Part Number: MSPM0G3507
Hello Team,
I have a customer testing ECC on the MSPM0G3507.
In our tests as for other Controllers we wanted to trigger a error by simply not initializing the memory before we read it.
This works as expected for the memory region starting at 0x20100000. But not for the default region we wanted to use at 0x20000000.
In the datasheet we haven’t found any reason why the two regions behave differently, can you explain this behavior?
I have checked the MSPM0G user guide and it should have worked.
The user guide says that the region 0x2000 0000 is available in all MSPM0 devices.
In the memory map of the datasheet the 0x2000 0000 does not look to be implemented, and would justify why by the customer is not working.
- Can you clarify the behavior?
- Is really not implemented by the MSPM0G3507?
- If it is so, it would be a mismatch between datasheet and user guide. Please clarify
User Guide
Datasheet
