Part Number: TMS570LC4357-EP
HI ALL,
I"M TRYING TO REDUCE THE CLOCK TIMINGS OF THE EMIF. THE ISSUE IS, I HAVE SET THE VALUES OF WRITE TIME, SETUP, HOLD & STROBE & READ TIME, SETUP, HOLD & STROBE AS MINIMUM AS POSSIBLE YET THE LOWEST TIMING THAT IM ABLE TO ACHIEVE IS IN MICROSECONDS EVEN THOUGH THE CLOCK SPEED IS 75Mhz. I HAVE ATTACHED THE CODE FOR REFERENCE BELOW.
/** @file HL_emif.c
* @brief emif Driver Implementation File
* @date 11-Dec-2018
* @version 04.07.01
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
#include "HL_emif.h"
#include "common.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
extern int Card_sel;
/** @fn void emif_ASYNC1Init(void)
* @brief Initializes the emif Driver for ASYNC memories
* This function initializes the emif driver for Asynchronous memories like Nor and Nand Flashes,Asynchronous RAM.
/* SourceId : EMIF_SourceId_002 */
/* DesignId : EMIF_DesignId_002 */
/* Requirements : HL_CONQ_EMIF_SR3 */
if(Card_sel == 1){
/* USER CODE BEGIN (4) */
/* USER CODE END */
emifREG->CE2CFG = 0x00000000U;
emifREG->CE2CFG = (uint32)((uint32)0U << 31U)| // SS select Strobe mode
(uint32)((uint32)0U << 30U)| // EW Extended Wait
(uint32)((uint32)6U << 26U)| // W_STEUP
(uint32)((uint32)16U << 20U)| // W_STROBE
(uint32)((uint32)6U << 17U)| // W_Hold
(uint32)((uint32)6U << 13U)| // R_STEUP
(uint32)((uint32)16U << 7U)| // R_STROBE
(uint32)((uint32)6U << 4U)| // R_HOLD
(uint32)((uint32)0U << 2U)| // TA
(uint32)((uint32)emif_16_bit_port);
emifREG->AWCC = (emifREG->AWCC & 0xC0FF0000U)|
(uint32)((uint32)emif_pin_high << 29U)|
(uint32)((uint32)emif_pin_low << 28U)|
(uint32)((uint32)emif_wait_pin0 << 16U)|
(uint32)((uint32)0U);
emifREG->PMCR = (emifREG->PMCR & 0xFFFFFF00U)|
(uint32)((uint32)emif_4_words << 1U)|
/* USER CODE BEGIN (5) */
/* USER CODE END */
}else{
/* USER CODE END */
(uint32)((uint32)1U << 26U)| // W_STEUP
(uint32)((uint32)2U << 20U)| // W_STROBE
(uint32)((uint32)1U << 17U)| // W_Hold
(uint32)((uint32)1U << 13U)| // R_STEUP
(uint32)((uint32)5U << 7U)| // R_STROBE
(uint32)((uint32)1U << 4U)| // R_HOLD
/* USER CODE END */
/** @fn void emif_ASYNC2Init(void)
/* SourceId : EMIF_SourceId_003 */
/* Requirements : HL_CONQ_EMIF_SR4 */
/* USER CODE BEGIN (6) */
///* USER CODE END */
emifREG->CE3CFG = 0x00000000U;
emifREG->CE3CFG = (uint32)((uint32)0U << 31U)| // SS select Strobe mode
(uint32)((uint32)3U << 20U)| // W_STROBE
(uint32)((uint32)6U << 7U)| // R_STROBE
(uint32)((uint32)emif_wait_pin0 << 18U)|
emifREG->PMCR = (emifREG->PMCR & 0xFFFF00FFU)|
(uint32)((uint32)0U << 10U)|
(uint32)((uint32)emif_4_words << 9U)|
(uint32)((uint32)0U << 8U);
/* USER CODE BEGIN (7) */
/** @fn void emif_ASYNC3Init(void)
/* SourceId : EMIF_SourceId_004 */
/* Requirements : HL_CONQ_EMIF_SR5 */
void emif_ASYNC3Init(UINT16 ModuleNo)
if(ModuleNo == 1){
/* USER CODE BEGIN (8) */
/* USER CODE END */
/* 1553 init */
emifREG->CE4CFG = 0x00000000U;
emifREG->CE4CFG = (uint32)((uint32)0U << 31U)| // SS select Strobe mode
(uint32)((uint32)1U << 30U)| // EW Extended Wait
(uint32)((uint32)9U << 7U)| // R_STROBE
(uint32)((uint32)emif_wait_pin0 << 20U)|
(uint32)((uint32)1U);
emifREG->PMCR = (emifREG->PMCR & 0xFF00FFFFU) |
(uint32)((uint32)0U << 18U)|
(uint32)((uint32)emif_4_words << 17U)|
(uint32)((uint32)0U << 16U);
/* USER CODE BEGIN (9) */
/* USER CODE END */
}else{
/* USER CODE END */
(uint32)((uint32)0U << 26U)| // W_STEUP
(uint32)((uint32)0U << 20U)| // W_STROBE
(uint32)((uint32)0U << 17U)| // W_Hold
(uint32)((uint32)0U << 13U)| // R_STEUP
(uint32)((uint32)2U << 7U)| // R_STROBE
(uint32)((uint32)0U << 4U)| // R_HOLD
/* USER CODE END */
/* USER CODE BEGIN (10) */
/* USER CODE END */
/** @fn void emifGetConfigValue(emif_config_reg_t *config_reg, config_value_type_t type)
* @brief Get the initial or current values of the EMIF configuration registers
* @param[in] *config_reg: pointer to the struct to which the initial or current
* value of the configuration registers need to be stored
* @param[in] type: whether initial or current value of the configuration registers need to be stored
* - InitialValue: initial value of the configuration registers will be stored
* in the struct pointed by config_reg
* - CurrentValue: initial value of the configuration registers will be stored
* This function will copy the initial or current value (depending on the parameter 'type')
* of the configuration registers to the struct pointed by config_reg
/* SourceId : EMIF_SourceId_005 */
/* DesignId : EMIF_DesignId_003 */
/* Requirements : HL_CONQ_EMIF_SR6 */
if (type == InitialValue)
config_reg->CONFIG_AWCC = EMIF_AWCC_CONFIGVALUE;
config_reg->CONFIG_SDCR = EMIF_SDCR_CONFIGVALUE;
config_reg->CONFIG_SDRCR = EMIF_SDRCR_CONFIGVALUE;
config_reg->CONFIG_CE2CFG = EMIF_CE2CFG_CONFIGVALUE;
config_reg->CONFIG_CE3CFG = EMIF_CE3CFG_CONFIGVALUE;
config_reg->CONFIG_CE4CFG = EMIF_CE4CFG_CONFIGVALUE;
config_reg->CONFIG_CE5CFG = EMIF_CE5CFG_CONFIGVALUE;
config_reg->CONFIG_SDTIMR = EMIF_SDTIMR_CONFIGVALUE;
config_reg->CONFIG_SDSRETR = EMIF_SDSRETR_CONFIGVALUE;
config_reg->CONFIG_INTMSK = EMIF_INTMSK_CONFIGVALUE;
config_reg->CONFIG_PMCR = EMIF_PMCR_CONFIGVALUE;
else
/*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "LDRA Tool issue" */
config_reg->CONFIG_AWCC = emifREG->AWCC;
config_reg->CONFIG_SDCR = emifREG->SDCR;
config_reg->CONFIG_SDRCR = emifREG->SDRCR ;
config_reg->CONFIG_CE2CFG = emifREG->CE2CFG;
config_reg->CONFIG_CE3CFG = emifREG->CE3CFG;
config_reg->CONFIG_CE4CFG = emifREG->CE4CFG;
config_reg->CONFIG_CE5CFG = emifREG->CE5CFG;
config_reg->CONFIG_SDTIMR = emifREG->SDTIMR;
config_reg->CONFIG_SDSRETR = emifREG->SDSRETR;
config_reg->CONFIG_INTMSK = emifREG->INTMSK;
config_reg->CONFIG_PMCR = emifREG->PMCR;
void EMIF_WRITE_ADDR(uint32 addr, uint16 val)
*((volatile uint16 *)addr) = val;
uint16 EMIF_READ_ADDR(uint32 addr)
return *((volatile uint16 *)addr);
