Part Number: TMS570LS0914
Hi
I am facing some issue using CCS for TMS570LS0914 IC(we are use customize bootloader). I have generated(using TI Compiler) bin and hex file with 0x00020000 address of Vector and Flash in .cmd file.(I use this file as application file). When hex file is flash through our proprietary tool then its stuck somewhere but when we use BIN file of same code(generated same time) which is converted into hex using HEXVIEW tool and flash through our proprietary tool. Its working fine.
I have to check another possibility also - If i generated hex file with address 0x00020000 in .cmd file. and flash hex file through UNIFLASH tool its also working fine.
If we assume its application code issue but HEX file generated through HEXVIEW tool its working so I couldn't understand its setting issue in CCS or any other .
Please assist in this issues.
