Part Number: UNIFLASH
We are generating ECC through linker command file and as per below thread, we copied the FlashHercules.dll in uniflash to the base CC location when we had loading problem.
However, what we are seeing now is, occasionally, we are getting the following error while loading the tek file and on the second attempt with the same tek file, we were able to flash the ECC locations successfully. We confirmed it by reading the ECC locations.
The above image has "File loader: Verification failed: Values at address 0xF043BFF0 do not match. Please verify target memory and memory map....."
Please help to resolve the issue.
Jaiganesh
