Part Number: MSPM0L1306
Hi team,
My customer is using MSPM0L1306 32pin VQFN.
They just found out that the pin for PA5/Pin 9, is set as output (high) after reset(default state).
if that is the case, they need to take care those pins on their board.
Could you please check whether the PA5/pin 9 is set as output/high as default before setting the GPIO ?
And any other pins that is the same setting as it ?
If yes, how should customer take care those pins ?
I could not find the information on TRM and data sheets.
Kenley
