Part Number: MCU-PLUS-SDK-AM243X
Hi exports,
We need use two gpio(AA7/Y8) interrupts, but found not work.
Import project "gpio_input_interrupt" can reproduce the issue: Config as show in the below pictures, and running failed: Board_gpioInit()->Sciclient_gpioIrqSet()->Sciclient_rmIrqSet() (Line142) failed.
Modify gpios to C13/AA11 is OK, so why? I test some gpios, found that if the two GPIOs within the same bank will trigger the issue, otherwise ok.
