Part Number: BQ41Z50EVM
Other Parts Discussed in Thread: BQSTUDIO, BQ41Z50
I'm currently working on a production software used to modify the dataflash values. The function that modified the dataflash value for Manufacturer Information (0x4080) was working perfectly when out of the blue the device stopped taking in any modification to the dataflash. I tried modifying the dataflash with BQStudio and my custom software, both not succeeding. After some research I found the problem, the PFStatus(DFW) bit is high which means that the dataflash permanent fail is enabled.
Is there a way in which I can disable the dataflash permanent fail ?
Why did the dataflash permanent fail activate ?
Thanks in advance for any help on this subject.
