Part Number: LP-MSPM0G3507
HI,
I have encountered the problem with this board while try to program/flash application over UART.
Issue : Accidentally, while programing application s/w address got selected as 0x00 (which I suppose BSL code starts). Further, Application s/w is not getting programmed through UART as there is no response coming for the BSL connection packet sent.
MOde Of Flashing/Programming : Through UART by invoking BSL pin.
How Issue occurred : Through same way but address got selected 0x00.
Seeking problem solution : How to reflash Bootloader or BSL s/w on target device so that, further it can be flashed with application s/w.
EVAL KIT : LP-MSPM0G3507
Pls guide/help me on this as it's blocking for further project work.
Kindly, let me know if any other details are required.
Kind Regards
