LP-MSPM0G3519: Read from Flash section 0x41D00000, provides default handler issues
Part Number: LP-MSPM0G3519
Hello Team,
I have the example case provided by TI which reads 0x00001000 address and allows the read operation to be done without any issues.
Now trying to read data starting from 0x41D00000 region.
While trying to change it to read starting from 0x41D00000 using this modified function 'EEPROM_TypeA_IncReadData' please find the attached file for eeprom_emulation_type_a.c file for reference.
Please help me resolve this. Are there any other specific procedures to be followed for this read?
Thanks.
 * Copyright (c) 2021-24, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <ti/eeprom/emulation_type_a/eeprom_emulation_type_a.h>
#include "ti_msp_dl_config.h"
/* Address in main memory to write to. This is defined in the
 * eeprom_emulation_type_a.h header file. Uncommenting the #define below will
 * overwrite the default #define in the header file. */
#define SECTOR_SIZE (1024)
#define NUMBER_OF_WRITES ((SECTOR_SIZE / EEPROM_EMULATION_DATA_SIZE) + 1)
uint32_t DataArray[EEPROM_EMULATION_DATA_SIZE / sizeof(uint32_t)] = {
    0xABCDEF00, 0x12345678, 0x00FEDCBA, 0x87654321, 0xABCDEF00, 0x12345678,
    0x00FEDCBA, 0x87654321, 0xABCDEF00, 0x12345678, 0x00FEDCBA, 0x87654321,
    0xABCDEF00, 0x12345678, 0x00FEDCBA, 0x87654321, 0xABCDEF00, 0x12345678};
uint32_t EEPROMEmulationBuffer[EEPROM_EMULATION_DATA_SIZE / sizeof(uint32_t)];
#pragma clang section bss=".eeprom_bss"
#pragma clang section text=".eeprom_text"
uint32_t rec_data[7];
#pragma clang section bss=""
#pragma clang section text=""
uint32_t BLANKAPISTATE;
uint32_t DATABLANKSTATE;
uint32_t gData32 = 0xABCDEF00;
volatile DL_FLASHCTL_COMMAND_STATUS gCmdStatus;
static volatile uint8_t var_test = 0xffu;
int main(void)
    uint32_t EEPROMEmulationState;
    SYSCFG_DL_init();
        for (uint16_t num = 0;
             num < EEPROM_EMULATION_DATA_SIZE / sizeof(uint32_t); num++) {
            EEPROMEmulationBuffer[num] = DataArray[num];
        while(1)
            __BKPT(0);
            switch(var_test)
                case 5:
                EEPROM_TypeA_IncReadData(0x41D00004, &rec_data[1], 1);
                var_test = 0xff;
                break;
                case 6:
                EEPROM_TypeA_IncReadData(0x41D00000, &rec_data[0], 1);
                var_test = 0xff;
                break;
            __BKPT(0);
    while(1) {
        __WFI();
 * are met:
int main(void)
    SYSCFG_DL_init();
        while(1)
            __BKPT(0);
            switch(var_test)
                case 5:
                var_test = 0xff;
                break;
                case 6:
                var_test = 0xff;
                break;
            __BKPT(0);
    while(1) {
        __WFI();
  • Please find the map file and eeprom source file for refe
    void EEPROM_TypeA_IncReadData(uint32_t srcaddr, uint32_t *data, uint32_t length)
        uint32_t *ReadRecordPointer;
        uint32_t ReadRecordAddress;
        ReadRecordAddress = srcaddr;
        for (uint16_t num = 0; num < length;
             num++) {
            ReadRecordPointer = (void *) ReadRecordAddress;
            data[num]         = *ReadRecordPointer;
            ReadRecordAddress += 4;
                TI ARM Clang Linker PC v4.0.1
    >> Linked Tue Feb 25 18:44:45 2025
    OUTPUT FILE NAME:   <eeprom_emulation_type_a.out>
    ENTRY POINT SYMBOL: "_c_int00_noargs"  address: 00000271
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
      FLASH                 00000000   00080000  00000340  0007fcc0  R  X
      SRAM_BANK0            20200000   00010000  000001f1  0000fe0f  RW X
      SRAM_BANK1            20210000   00010000  00000020  0000ffe0  RW X
      BCR_CONFIG            41c00000   000000ff  00000000  000000ff  R
      BSL_CONFIG            41c00100   00000080  00000000  00000080  R
      DATA                  41d00000   00004000  00000000  00004000  R
    SEGMENT ALLOCATION MAP
    run origin  load origin   length   init length attrs members
    00000000    00000000    00000340   00000340    r-x
      00000000    00000000    000000c0   000000c0    r-- .intvecs
      000000c0    000000c0    00000230   00000230    r-x .text
      000002f0    000002f0    00000050   00000050    r-- .cinit
    20200000    20200000    000000f4   00000000    rw-
      20200000    20200000    00000079   00000000    rw- .data
      2020007c    2020007c    00000078   00000000    rw- .bss
    2020ff00    2020ff00    00000120   00000000    rw-
      2020ff00    2020ff00    00000100   00000000    rw- .stack
      20210000    20210000    00000020   00000000    rw- .eeprom_bss
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    .intvecs   0    00000000    000000c0
                      00000000    000000c0     ticlang_startup_mspm0g351x_ticlang.obj (.intvecs)
    .text      0    000000c0    00000230
                      000000c0    0000007c     libc.a : copy_decompress_lzss.c.obj (.text:decompress:lzss)
                      0000013c    0000006c     ti_msp_dl_config.obj (.text.SYSCFG_DL_init)
                      000001a8    00000050     main.obj (.text.main)
                      000001f8    0000003c     libc.a : autoinit.c.obj (.text:__TI_auto_init_nobinit_nopinit)
                      00000234    0000003a     ti_eeprom_emulation_type_a_eeprom_emulation_type_a.obj (.text.EEPROM_TypeA_IncReadData)
                      0000026e    00000002     ticlang_startup_mspm0g351x_ticlang.obj (.text.Default_Handler)
                      00000270    00000028     libc.a : boot_cortex_m.c.obj (.text:_c_int00_noargs)
                      00000298    00000016            : copy_zero_init.c.obj (.text:decompress:ZI:__TI_zero_init_nomemset)
                      000002ae    00000012            : memcpy16.S.obj (.text:TI_memcpy_small)
                      000002c0    00000012            : copy_decompress_none.c.obj (.text:decompress:none)
                      000002d2    0000000a     driverlib.a : dl_common.o (.text.DL_Common_delayCycles)
                      000002dc    00000008     libclang_rt.builtins.a : aeabi_memcpy.S.obj (.text.__aeabi_memcpy)
                      000002e4    00000004     ticlang_startup_mspm0g351x_ticlang.obj (.text.Reset_Handler)
                      000002e8    00000004     libc.a : pre_init.c.obj (.text._system_pre_init)
                      000002ec    00000004            : exit.c.obj (.text:abort)
    .cinit     0    000002f0    00000050
                      000002f0    0000001a     (.cinit..data.load) [load image, compression = lzss]
                      0000030a    00000002     --HOLE-- [fill = 0]
                      0000030c    0000000c     (__TI_handler_table)
                      00000318    00000008     (.cinit..bss.load) [load image, compression = zero_init]
                      00000320    00000008     (.cinit..eeprom_bss.load) [load image, compression = zero_init]
                      00000328    00000018     (__TI_cinit_table)
    .init_array
    *          0    00000000    00000000     UNINITIALIZED
    .binit     0    00000000    00000000
    .data      0    20200000    00000079     UNINITIALIZED
                      20200000    00000078     main.obj (.data.DataArray)
                      20200078    00000001     main.obj (.data.var_test)
    .bss       0    2020007c    00000078     UNINITIALIZED
                      2020007c    00000078     (.common:EEPROMEmulationBuffer)
    .stack     0    2020ff00    00000100     UNINITIALIZED
                      2020ff00    00000004     libc.a : boot_cortex_m.c.obj (.stack)
                      2020ff04    000000fc     --HOLE--
    .eeprom_bss
    *          0    20210000    00000020     UNINITIALIZED
                      20210000    0000001c     main.obj (.eeprom_bss)
                      2021001c    00000004     --HOLE--
    __llvm_prf_cnts
    *          0    20200000    00000000     UNINITIALIZED
    __llvm_prf_bits
    MODULE SUMMARY
           Module                                                   code   ro data   rw data
        <current directory>
           main.obj                                                 80     0         269
           ticlang_startup_mspm0g351x_ticlang.obj                   6      192       0
           ti_msp_dl_config.obj                                     108    0         0
           ti_eeprom_emulation_type_a_eeprom_emulation_type_a.obj   58     0         0
           Total:                                                   252    192       269
        c:/ti/mspm0_sdk_2_03_00_07/source/ti/driverlib/lib/ticlang/m0p/mspm0gx51x/driverlib.a
           dl_common.o                                              10     0         0
           Total:                                                   10     0         0
        c:\ti\ti-cgt-armllvm_4.0.1.LTS\\lib\armv6m-ti-none-eabi/c/libc.a
           copy_decompress_lzss.c.obj                               124    0         0
           autoinit.c.obj                                           60     0         0
           boot_cortex_m.c.obj                                      40     0         0
           copy_zero_init.c.obj                                     22     0         0
           copy_decompress_none.c.obj                               18     0         0
           memcpy16.S.obj                                           18     0         0
           exit.c.obj                                               4      0         0
           pre_init.c.obj                                           4      0         0
           Total:                                                   290    0         0
        c:\ti\ti-cgt-armllvm_4.0.1.LTS\\lib\armv6m-ti-none-eabi/libclang_rt.builtins.a
           aeabi_memcpy.S.obj                                       8      0         0
           Total:                                                   8      0         0
           Stack:                                                   0      0         256
           Linker Generated:                                        0      78        0
           Grand Total:                                             560    270       525
    LINKER GENERATED COPY TABLES
    __TI_cinit_table @ 00000328 records: 3, size/record: 8, table size: 24
    	.data: load addr=000002f0, load size=0000001a bytes, run addr=20200000, run size=00000079 bytes, compression=lzss
    	.bss: load addr=00000318, load size=00000008 bytes, run addr=2020007c, run size=00000078 bytes, compression=zero_init
    	.eeprom_bss: load addr=00000320, load size=00000008 bytes, run addr=20210000, run size=00000020 bytes, compression=zero_init
    LINKER GENERATED HANDLER TABLE
    __TI_handler_table @ 0000030c records: 3, size/record: 4, table size: 12
    	index: 0, handler: __TI_decompress_lzss
    	index: 1, handler: __TI_decompress_none
    	index: 2, handler: __TI_zero_init
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    address   name
    0000026f  ADC0_IRQHandler
    0000026f  ADC1_IRQHandler
    0000026f  AESADV_IRQHandler
    000002ec  C$$EXIT
    0000026f  CANFD0_IRQHandler
    0000026f  CANFD1_IRQHandler
    0000026f  DAC0_IRQHandler
    000002d3  DL_Common_delayCycles
    0000026f  DMA_IRQHandler
    20200000  DataArray
    0000026f  Default_Handler
    2020007c  EEPROMEmulationBuffer
    00000235  EEPROM_TypeA_IncReadData
    0000026f  GROUP0_IRQHandler
    0000026f  GROUP1_IRQHandler
    0000026f  HardFault_Handler
    0000026f  I2C0_IRQHandler
    0000026f  I2C1_IRQHandler
    0000026f  I2C2_IRQHandler
    0000026f  LFSS_IRQHandler
    0000026f  NMI_Handler
    0000026f  PendSV_Handler
    000002e5  Reset_Handler
    0000026f  SPI0_IRQHandler
    0000026f  SPI1_IRQHandler
    0000026f  SPI2_IRQHandler
    0000026f  SVC_Handler
    0000013d  SYSCFG_DL_init
    0000026f  SysTick_Handler
    0000026f  TIMA0_IRQHandler
    0000026f  TIMA1_IRQHandler
    0000026f  TIMG0_IRQHandler
    0000026f  TIMG12_IRQHandler
    0000026f  TIMG14_IRQHandler
    0000026f  TIMG6_IRQHandler
    0000026f  TIMG7_IRQHandler
    0000026f  TIMG8_IRQHandler
    0000026f  TIMG9_IRQHandler
    000002af  TI_memcpy_small
    0000026f  UART0_IRQHandler
    0000026f  UART1_IRQHandler
    0000026f  UART3_IRQHandler
    0000026f  UART4_IRQHandler
    0000026f  UART5_IRQHandler
    0000026f  UART6_IRQHandler
    0000026f  UART7_IRQHandler
    20210000  __STACK_END
    00000100  __STACK_SIZE
    00000000  __TI_ATRegion0_region_sz
    00000000  __TI_ATRegion0_src_addr
    00000000  __TI_ATRegion0_trg_addr
    00000000  __TI_ATRegion1_region_sz
    00000000  __TI_ATRegion1_src_addr
    00000000  __TI_ATRegion1_trg_addr
    00000000  __TI_ATRegion2_region_sz
    00000000  __TI_ATRegion2_src_addr
    00000000  __TI_ATRegion2_trg_addr
    00000328  __TI_CINIT_Base
    00000340  __TI_CINIT_Limit
    00000340  __TI_CINIT_Warm
    0000030c  __TI_Handler_Table_Base
    00000318  __TI_Handler_Table_Limit
    000001f9  __TI_auto_init_nobinit_nopinit
    000000c1  __TI_decompress_lzss
    000002c1  __TI_decompress_none
    ffffffff  __TI_pprof_out_hndl
    ffffffff  __TI_prof_data_size
    ffffffff  __TI_prof_data_start
    00000000  __TI_static_base__
    00000299  __TI_zero_init_nomemset
    000002dd  __aeabi_memcpy
    000002dd  __aeabi_memcpy4
    000002dd  __aeabi_memcpy8
    ffffffff  __binit__
    UNDEFED   __mpu_init
    2020ff00  __stack
    20200000  __start___llvm_prf_bits
    20200000  __start___llvm_prf_cnts
    20200000  __stop___llvm_prf_bits
    20200000  __stop___llvm_prf_cnts
    00000271  _c_int00_noargs
    UNDEFED   _system_post_cinit
    000002e9  _system_pre_init
    000002ed  abort
    ffffffff  binit
    00000000  interruptVectors
    000001a9  main
    20210000  rec_data
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    address   name
    000001a9  main
    000002ec  C$$EXIT
    000002ed  abort
    20200000  DataArray
    2020ff00  __stack
    20210000  rec_data
    ffffffff  __binit__
    ffffffff  binit
    UNDEFED   __mpu_init
    [88 symbols]
    rence
  • Hi Eswaran,
    Are you getting an ECC violation in your default handler? The memory section you're looking at is ECC protected so if you program that section and without the proper ECC code then it should throw a flag.
    Luke
  • Hi Luke,
    Thanks for your reply.
    Can you please tell confirm is this is the register that needs to be checked for ECC violation? - SYSSTATUS under SYSCTL. The ECC error bits in this register were set to TRUE.
    Just wanted to ensure if the same problem will occur for reading from the memory as you have said this happens while programming?
    So, for this address 0x41D00000 of DATA Flash we have to use programming with ECC so that the read will be processed without any issues.
    And could you please also suggest if the ECC can be disabled for this 0x41D00000?
    If we want to use memory without ECC, should we proceed with 0x41E00000 area?
    but 0x41e00000 always shows like this,
    please guide us how to program and read from this 0x41E00000 region?
    Eswar
  • Hi Eswar,
    I recommend looking at the flashctl_program_with_ecc example for programming the ECC code, the functions that have "WithECCGenerated" should be doing the ecc code for you.
    If you want to go with unchecked region, then yes you will use the memory address of 0x41E00000 instead of 0x41D00000.
    Luke
  • Hi Luke,
    Yes, I had a look at the ECC coding examples and tried then the issue was solved. Thanks.
    For unchecked region, when I am trying to write in 0x41E00000, it is not writing. Should we follow any specific procedure to write here?
    Eswar
