LP-MSPM0G3507: MSPM0 Flash Setting - device was locked
Part Number: LP-MSPM0G3507
Hello
I'm using LP-MSPM0G3507
I want to write data to Flash(EEPROM Emulation)
To check the data written on memory, I tried
1. Write data thru EEPROM Emulation Type B
2. Unplug and plug MSPM0
3. Debug new code to check EEPROM data
But, because of the erase configuration, EEPROM data(which is located in MAIN memory) was erased when debugging
So, I changed erase method to 'Do not erase Flash memory' to check EEPROM data
After I changed erase config, my launchpad was locked.
Do you know how to recover my launchpad?
And the way to read data without erase MAIN memory?
