LP-AM261: Unable to use memcpy multiple time if flash write api is used in the middle
Part Number: LP-AM261
The issue is with the example ospi_flash_io.c .
In this example, we are testing the read write two times. if I try to use memcpy for reading from flash both the time, the code goes into abort handler.
Code works fine if I enable DAC mode everytime I use memcpy.
Note : application uses memcpy at higher layers so I need the support for memcpy.
Observations
I have to call OSPI_enableDacMode(gOspiHandle[CONFIG_FLASH0]) every time I use memcpy if there is Flash_write() api used in the middle.
Code which works
 *  Copyright (C) 2021-24 Texas Instruments Incorporated
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <kernel/dpl/DebugP.h>
#include "ti_drivers_open_close.h"
#include "ti_board_open_close.h"
#include "string.h"
#define APP_OSPI_FLASH_OFFSET_BASE  (0x200000U)
#define APP_OSPI_DATA_SIZE (2048)
uint8_t gOspiTxBuf[APP_OSPI_DATA_SIZE];
/* read buffer MUST be cache line aligned when using DMA, we aligned to 128B though 32B is enough */
uint8_t gOspiRxBuf[APP_OSPI_DATA_SIZE] __attribute__((aligned(128U)));
void ospi_flash_io_fill_buffers(void);
int32_t ospi_flash_io_compare_buffers(void);
void ospi_flash_io_main(void *args)
    int32_t status = SystemP_SUCCESS;
    uint32_t offset;
    uint32_t blk, page;
    Flash_Attrs *flashAttrs;
    /* Open OSPI Driver, among others */
    Drivers_open();
//    gFlashConfig[CONFIG_FLASH0].skipHwInit = TRUE;
    /* Open Flash drivers with OSPI instance as input */
    status = Board_driversOpen();
    DebugP_assert(status==SystemP_SUCCESS);
    flashAttrs = Flash_getAttrs(CONFIG_FLASH0);
    //OSPI_enableDacMode(gOspiHandle[CONFIG_FLASH0]);
    /* Fill buffers with known data,
     * find block number from offset,
     * erase block, write the data, read back from a specific offset
     * and finally compare the results.
    offset = APP_OSPI_FLASH_OFFSET_BASE;
    ospi_flash_io_fill_buffers();
    Flash_offsetToBlkPage(gFlashHandle[CONFIG_FLASH0], offset, &blk, &page);
    status = Flash_eraseBlk(gFlashHandle[CONFIG_FLASH0], blk);
    if(status != SystemP_SUCCESS)
        DebugP_log("Block Erase Failed at 0x%X offset !!!", offset);
    if(SystemP_SUCCESS == status)
        status = Flash_write(gFlashHandle[CONFIG_FLASH0], offset, gOspiTxBuf, APP_OSPI_DATA_SIZE);
    else
        DebugP_log("Flash Write of %d bytes failed at 0x%X offset !!!", APP_OSPI_DATA_SIZE, offset);
        //status = Flash_read(gFlashHandle[CONFIG_FLASH0], offset, gOspiRxBuf, APP_OSPI_DATA_SIZE);
        memcpy(&gOspiRxBuf[0],(unsigned char *)(offset + 0x60000000),APP_OSPI_DATA_SIZE);
        status |= ospi_flash_io_compare_buffers();
    offset = APP_OSPI_FLASH_OFFSET_BASE + (flashAttrs->blockSize*2);
    else
       // status = Flash_read(gFlashHandle[CONFIG_FLASH0], offset, gOspiRxBuf, APP_OSPI_DATA_SIZE);
        DebugP_log("All tests have passed!!\r\n");
    else
        DebugP_log("Some tests have failed!!\r\n");
    Board_driversClose();
    Drivers_close();
    uint32_t i;
    for(i = 0U; i < APP_OSPI_DATA_SIZE; i++)
        gOspiTxBuf[i] = i % 256;
        gOspiRxBuf[i] = 0U;
    uint32_t i;
        if(gOspiTxBuf[i] != gOspiRxBuf[i])
            status = SystemP_FAILURE;
            DebugP_logError("OSPI read data mismatch !!!\r\n");
            break;
    return status;
Code which doesn't work
 *  are met:
 *    distribution.
#include "string.h"
    uint32_t offset;
    uint32_t blk, page;
    Drivers_open();
    else
    else
    else
    Drivers_close();
    uint32_t i;
        gOspiRxBuf[i] = 0U;
    uint32_t i;
            break;
    return status;
