Part Number: LP-AM261
Hi
I was able to integrate CDC Echo functionality to application running on LP-AM261.
Firmware is sending back echo over usb virtual com
Our application is micrium uC/OS RTOS based.
Scenario 1 : USB_dwcTask, tud_task, cdc_task called in sequence in a single task
Enumeration and data transfer is working properly
Scenario 2: USB_dwcTask and tud_task called in a task and cdc_task is called in another task
Enumeration and data transfer is working properly initially
But at some point, echo back is stopped working. (this behavior is random in nature)
While debugging we can see that transmit from PC is still reaching the device.
But echo back from the device is not coming to PC anymore.
What i understand is Endpoint 2 IN transactions stopped working
But if try to re-connect serial terminal application that is still happening. But echo back is not working
If we reconnect the USB cable again, then the device is still enumerating, and echo will be working again.
Logs from our testing script is given below:
2025-03-04 17:15:51 - __main__ - INFO - data_send_iteration:1
2025-03-04 17:15:51 - __main__ - INFO - delay_between_send:0.001s
2025-03-04 17:15:51 - __main__ - INFO - data_length_initial:1
2025-03-04 17:15:51 - __main__ - INFO - data_length_increment:1
2025-03-04 17:15:51 - __main__ - INFO - port_open_iteration:1
2025-03-04 17:15:51 - __main__ - INFO - delay_between_data_length:0
2025-03-04 17:15:51 - __main__ - INFO - data_length_final:100
2025-03-04 17:15:51 - __main__ - INFO - 1 1
2025-03-04 17:15:51 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:51 - __main__ - INFO - 1 bytes 1/1 messages received 1 bytes received
2025-03-04 17:15:51 - __main__ - INFO - 2 2
2025-03-04 17:15:51 - __main__ - INFO - 2 bytes 1/1 messages received 2 bytes received
2025-03-04 17:15:51 - __main__ - INFO - 3 3
2025-03-04 17:15:51 - __main__ - INFO - 3 bytes 1/1 messages received 3 bytes received
2025-03-04 17:15:51 - __main__ - INFO - 4 4
2025-03-04 17:15:52 - __main__ - INFO - 4 bytes 1/1 messages received 4 bytes received
2025-03-04 17:15:52 - __main__ - INFO - 5 5
2025-03-04 17:15:52 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:52 - __main__ - INFO - 5 bytes 1/1 messages received 5 bytes received
2025-03-04 17:15:52 - __main__ - INFO - 6 6
2025-03-04 17:15:52 - __main__ - INFO - 6 bytes 1/1 messages received 6 bytes received
2025-03-04 17:15:52 - __main__ - INFO - 7 7
2025-03-04 17:15:52 - __main__ - INFO - 7 bytes 1/1 messages received 7 bytes received
2025-03-04 17:15:52 - __main__ - INFO - 8 8
2025-03-04 17:15:53 - __main__ - INFO - 8 bytes 1/1 messages received 8 bytes received
2025-03-04 17:15:53 - __main__ - INFO - 9 9
2025-03-04 17:15:53 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:53 - __main__ - INFO - 9 bytes 1/1 messages received 9 bytes received
2025-03-04 17:15:53 - __main__ - INFO - 10 10
2025-03-04 17:15:53 - __main__ - INFO - 10 bytes 1/1 messages received 10 bytes received
2025-03-04 17:15:53 - __main__ - INFO - 11 11
2025-03-04 17:15:53 - __main__ - INFO - 11 bytes 1/1 messages received 11 bytes received
2025-03-04 17:15:53 - __main__ - INFO - 12 12
2025-03-04 17:15:54 - __main__ - INFO - 12 bytes 1/1 messages received 12 bytes received
2025-03-04 17:15:54 - __main__ - INFO - 13 13
2025-03-04 17:15:54 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:54 - __main__ - INFO - 13 bytes 1/1 messages received 13 bytes received
2025-03-04 17:15:54 - __main__ - INFO - 14 14
2025-03-04 17:15:54 - __main__ - INFO - 14 bytes 1/1 messages received 14 bytes received
2025-03-04 17:15:54 - __main__ - INFO - 15 15
2025-03-04 17:15:54 - __main__ - INFO - 15 bytes 1/1 messages received 15 bytes received
2025-03-04 17:15:54 - __main__ - INFO - 16 16
2025-03-04 17:15:55 - __main__ - INFO - 16 bytes 1/1 messages received 16 bytes received
2025-03-04 17:15:55 - __main__ - INFO - 17 17
2025-03-04 17:15:55 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:55 - __main__ - INFO - 17 bytes 1/1 messages received 17 bytes received
2025-03-04 17:15:55 - __main__ - INFO - 18 18
2025-03-04 17:15:55 - __main__ - INFO - 18 bytes 1/1 messages received 18 bytes received
2025-03-04 17:15:55 - __main__ - INFO - 19 19
2025-03-04 17:15:55 - __main__ - INFO - 19 bytes 1/1 messages received 19 bytes received
2025-03-04 17:15:55 - __main__ - INFO - 20 20
2025-03-04 17:15:56 - __main__ - INFO - 20 bytes 1/1 messages received 20 bytes received
2025-03-04 17:15:56 - __main__ - INFO - 21 21
2025-03-04 17:15:56 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:56 - __main__ - INFO - 21 bytes 1/1 messages received 21 bytes received
2025-03-04 17:15:56 - __main__ - INFO - 22 22
2025-03-04 17:15:56 - __main__ - INFO - 22 bytes 1/1 messages received 22 bytes received
2025-03-04 17:15:56 - __main__ - INFO - 23 23
2025-03-04 17:15:56 - __main__ - INFO - 23 bytes 1/1 messages received 23 bytes received
2025-03-04 17:15:56 - __main__ - INFO - 24 24
2025-03-04 17:15:57 - __main__ - INFO - 24 bytes 1/1 messages received 24 bytes received
2025-03-04 17:15:57 - __main__ - INFO - 25 25
2025-03-04 17:15:57 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:57 - __main__ - INFO - 25 bytes 1/1 messages received 25 bytes received
2025-03-04 17:15:57 - __main__ - INFO - 26 26
2025-03-04 17:15:57 - __main__ - INFO - 26 bytes 1/1 messages received 26 bytes received
2025-03-04 17:15:57 - __main__ - INFO - 27 27
2025-03-04 17:15:57 - __main__ - INFO - 27 bytes 1/1 messages received 27 bytes received
2025-03-04 17:15:57 - __main__ - INFO - 28 28
2025-03-04 17:15:58 - __main__ - INFO - 28 bytes 1/1 messages received 28 bytes received
2025-03-04 17:15:58 - __main__ - INFO - 29 29
2025-03-04 17:15:58 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:58 - __main__ - INFO - 29 bytes 1/1 messages received 29 bytes received
2025-03-04 17:15:58 - __main__ - INFO - 30 30
2025-03-04 17:15:58 - __main__ - INFO - 30 bytes 1/1 messages received 30 bytes received
2025-03-04 17:15:58 - __main__ - INFO - 31 31
2025-03-04 17:15:58 - __main__ - INFO - 31 bytes 1/1 messages received 31 bytes received
2025-03-04 17:15:58 - __main__ - INFO - 32 32
2025-03-04 17:15:58 - __main__ - INFO - 32 bytes 1/1 messages received 32 bytes received
2025-03-04 17:15:58 - __main__ - INFO - 33 33
2025-03-04 17:15:59 - __main__ - INFO - 33 bytes 1/1 messages received 33 bytes received
2025-03-04 17:15:59 - __main__ - INFO - 34 34
2025-03-04 17:15:59 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:15:59 - __main__ - INFO - 34 bytes 1/1 messages received 34 bytes received
2025-03-04 17:15:59 - __main__ - INFO - 35 35
2025-03-04 17:15:59 - __main__ - INFO - 35 bytes 1/1 messages received 35 bytes received
2025-03-04 17:15:59 - __main__ - INFO - 36 36
2025-03-04 17:15:59 - __main__ - INFO - 36 bytes 1/1 messages received 36 bytes received
2025-03-04 17:15:59 - __main__ - INFO - 37 37
2025-03-04 17:16:00 - __main__ - INFO - 37 bytes 1/1 messages received 37 bytes received
2025-03-04 17:16:00 - __main__ - INFO - 38 38
2025-03-04 17:16:00 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:00 - __main__ - INFO - 38 bytes 1/1 messages received 38 bytes received
2025-03-04 17:16:00 - __main__ - INFO - 39 39
2025-03-04 17:16:00 - __main__ - INFO - 39 bytes 1/1 messages received 39 bytes received
2025-03-04 17:16:00 - __main__ - INFO - 40 40
2025-03-04 17:16:00 - __main__ - INFO - 40 bytes 1/1 messages received 40 bytes received
2025-03-04 17:16:00 - __main__ - INFO - 41 41
2025-03-04 17:16:01 - __main__ - INFO - 41 bytes 1/1 messages received 41 bytes received
2025-03-04 17:16:01 - __main__ - INFO - 42 42
2025-03-04 17:16:01 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:01 - __main__ - INFO - 42 bytes 1/1 messages received 42 bytes received
2025-03-04 17:16:01 - __main__ - INFO - 43 43
2025-03-04 17:16:01 - __main__ - INFO - 43 bytes 1/1 messages received 43 bytes received
2025-03-04 17:16:01 - __main__ - INFO - 44 44
2025-03-04 17:16:01 - __main__ - INFO - 44 bytes 1/1 messages received 44 bytes received
2025-03-04 17:16:01 - __main__ - INFO - 45 45
2025-03-04 17:16:02 - __main__ - INFO - 45 bytes 1/1 messages received 45 bytes received
2025-03-04 17:16:02 - __main__ - INFO - 46 46
2025-03-04 17:16:02 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:02 - __main__ - INFO - 46 bytes 1/1 messages received 46 bytes received
2025-03-04 17:16:02 - __main__ - INFO - 47 47
2025-03-04 17:16:02 - __main__ - INFO - 47 bytes 1/1 messages received 47 bytes received
2025-03-04 17:16:02 - __main__ - INFO - 48 48
2025-03-04 17:16:02 - __main__ - INFO - 48 bytes 1/1 messages received 48 bytes received
2025-03-04 17:16:02 - __main__ - INFO - 49 49
2025-03-04 17:16:03 - __main__ - INFO - 49 bytes 1/1 messages received 49 bytes received
2025-03-04 17:16:03 - __main__ - INFO - 50 50
2025-03-04 17:16:03 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:03 - __main__ - INFO - 50 bytes 1/1 messages received 50 bytes received
2025-03-04 17:16:03 - __main__ - INFO - 51 51
2025-03-04 17:16:03 - __main__ - INFO - 51 bytes 1/1 messages received 51 bytes received
2025-03-04 17:16:03 - __main__ - INFO - 52 52
2025-03-04 17:16:03 - __main__ - INFO - 52 bytes 1/1 messages received 52 bytes received
2025-03-04 17:16:03 - __main__ - INFO - 53 53
2025-03-04 17:16:04 - __main__ - INFO - 53 bytes 1/1 messages received 53 bytes received
2025-03-04 17:16:04 - __main__ - INFO - 54 54
2025-03-04 17:16:04 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:04 - __main__ - INFO - 54 bytes 1/1 messages received 54 bytes received
2025-03-04 17:16:04 - __main__ - INFO - 55 55
2025-03-04 17:16:04 - __main__ - INFO - 55 bytes 1/1 messages received 55 bytes received
2025-03-04 17:16:04 - __main__ - INFO - 56 56
2025-03-04 17:16:04 - __main__ - INFO - 56 bytes 1/1 messages received 56 bytes received
2025-03-04 17:16:04 - __main__ - INFO - 57 57
2025-03-04 17:16:05 - __main__ - INFO - 57 bytes 1/1 messages received 57 bytes received
2025-03-04 17:16:05 - __main__ - INFO - 58 58
2025-03-04 17:16:05 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:05 - __main__ - INFO - 58 bytes 1/1 messages received 58 bytes received
2025-03-04 17:16:05 - __main__ - INFO - 59 59
2025-03-04 17:16:05 - __main__ - INFO - 59 bytes 1/1 messages received 59 bytes received
2025-03-04 17:16:05 - __main__ - INFO - 60 60
2025-03-04 17:16:05 - __main__ - INFO - 60 bytes 1/1 messages received 60 bytes received
2025-03-04 17:16:05 - __main__ - INFO - 61 61
2025-03-04 17:16:06 - __main__ - INFO - 61 bytes 1/1 messages received 61 bytes received
2025-03-04 17:16:06 - __main__ - INFO - 62 62
2025-03-04 17:16:06 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:06 - __main__ - INFO - 62 bytes 1/1 messages received 62 bytes received
2025-03-04 17:16:06 - __main__ - INFO - 63 63
2025-03-04 17:16:06 - __main__ - INFO - 63 bytes 1/1 messages received 63 bytes received
2025-03-04 17:16:06 - __main__ - INFO - 64 64
2025-03-04 17:16:06 - __main__ - INFO - 64 bytes 1/1 messages received 64 bytes received
2025-03-04 17:16:06 - __main__ - INFO - 65 65
2025-03-04 17:16:07 - __main__ - INFO - 65 bytes 1/1 messages received 65 bytes received
2025-03-04 17:16:07 - __main__ - INFO - 66 66
2025-03-04 17:16:07 - __main__ - INFO - ABB COM detected COM9
2025-03-04 17:16:07 - __main__ - INFO - 66 bytes 1/1 messages received 66 bytes received
2025-03-04 17:16:07 - __main__ - INFO - 67 67
2025-03-04 17:16:09 - __main__ - INFO - 67 bytes 0/1 messages received 0 bytes received
2025-03-04 17:16:09 - __main__ - INFO - Failed on 1st message :
2025-03-04 17:16:09 - __main__ - INFO - Send :b'hello welcome111111111111111111111hello welcome11111111111111111111'
2025-03-04 17:16:09 - __main__ - INFO - Received:b''
Please help us in resolving this.
Nithin
