Part Number: AM2632
Other Parts Discussed in Thread: UNIFLASH,
On a pcba that has an AM2632, programmed with a valid SBL image (.tiimage) and Application image (.appimage): is it possible to export the memory to a single .bin file? And then take this single .bin file and program it to another identical board? I use the SBL Image address off-set as my starting point to export the memory. UniFlash gives me an error when I attempt to do this (see attached image). I select SBL Image only when attempting to do this programming. Are there other settings I need to toggle? Thank-you!
