Part Number: MSPM0G3107
I need to use command line to perform following operation in that order: Mass Erase of the tagert => Load image
But the load image only seem to work without MassErase operation using DSLite:
C:\ti\uniflash_9.1.0>DSLite.bat --config=C:\Git\rdu_swqt\SWQT\Flash\MSPM0G3107.ccxml -a MassErase -e -f C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
Executing the following command:
> "C:\ti\uniflash_9.1.0\deskdb\content\TICloudAgent\win\ccs_base\DebugServer\bin\DSLite" flash --config=C:\Git\rdu_swqt\SWQT\Flash\MSPM0G3107.ccxml -a MassErase -e -f C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
For more details and examples, please refer to the UniFlash Quick Start guide.
DSLite version 20.1.0.3671
Configuring Debugger (may take a few minutes on first launch)...
Initializing Register Database...
Initializing: CS_DAP_0
Executing Startup Scripts: CS_DAP_0
Initializing: CORTEX_M0P
Executing Startup Scripts: CORTEX_M0P
Initializing: SEC_AP
Executing Startup Scripts: SEC_AP
Connecting...
CORTEX_M0P: GEL Output: Memory Map Initialization Complete
Loading Program: C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
Preparing ...
0 of 131072 at 0x0
32752 of 131072 at 0x0: 24%
65504 of 131072 at 0x0: 49%
98256 of 131072 at 0x0: 74%
131008 of 131072 at 0x0: 99%
Finished: 99%
Setting PC to entry point.: 99%
Failed: Timed out waiting for target to halt
C:\ti\uniflash_9.1.0>DSLite.bat --config=C:\Git\rdu_swqt\SWQT\Flash\MSPM0G3107.ccxml -b MassErase -e -f C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
> "C:\ti\uniflash_9.1.0\deskdb\content\TICloudAgent\win\ccs_base\DebugServer\bin\DSLite" flash --config=C:\Git\rdu_swqt\SWQT\Flash\MSPM0G3107.ccxml -b MassErase -e -f C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
Connecting...
C:\ti\uniflash_9.1.0>DSLite.bat --config=C:\Git\rdu_swqt\SWQT\Flash\MSPM0G3107.ccxml -e -f C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
> "C:\ti\uniflash_9.1.0\deskdb\content\TICloudAgent\win\ccs_base\DebugServer\bin\DSLite" flash --config=C:\Git\rdu_swqt\SWQT\Flash\MSPM0G3107.ccxml -e -f C:\RDU_SW\release_1.2.1.0\Rdu_MainSW_ff_release_1.2.1.0_25-02-25_17h04_ebee1a3_clean.hex
Connecting...
Preparing ...
0 of 131072 at 0x0
Finished: 99%
Success
The different Mass Erase Operation seem to work fine when using UniFlash
[27/03/2025, 14:48:13] [INFO] CS_DAP_0: GEL Output: Initiating Device Mass Erase [27/03/2025, 14:48:13] [INFO] CS_DAP_0: GEL Output: Attempting CS_DAP connection [27/03/2025, 14:48:14] [INFO] CS_DAP_0: GEL Output: Attempting SEC_AP connection [27/03/2025, 14:48:14] [INFO] CS_DAP_0: GEL Output: Command Sent [27/03/2025, 14:48:15] [INFO] CS_DAP_0: GEL Output: Start hardware Reset using NRST [27/03/2025, 14:48:15] [INFO] CS_DAP_0: GEL Output: Initiating BOOTRST Board Reset [27/03/2025, 14:48:15] [INFO] CS_DAP_0: GEL Output: Reset line asserted [27/03/2025, 14:48:16] [INFO] CS_DAP_0: GEL Output: Reset line de-asserted [27/03/2025, 14:48:16] [INFO] CS_DAP_0: GEL Output: Board Reset Complete [27/03/2025, 14:48:16] [INFO] CS_DAP_0: GEL Output: Reset done [27/03/2025, 14:48:16] [INFO] CS_DAP_0: GEL Output: SEC_AP Disconnect [27/03/2025, 14:48:16] [INFO] CS_DAP_0: GEL Output: SEC_AP Reconnect [27/03/2025, 14:48:16] [INFO] CS_DAP_0: GEL Output: Command execution completed. [27/03/2025, 14:48:16] [INFO] CORTEX_M0P: GEL Output: Mass Erase executed. Please terminate debug session, power-cycle and restart debug session. [27/03/2025, 14:48:42] [INFO] CS_DAP_0: GEL Output: Initiating Device Factory Reset [27/03/2025, 14:48:42] [INFO] CS_DAP_0: GEL Output: Command Sent [27/03/2025, 14:48:43] [INFO] CS_DAP_0: GEL Output: Start hardware Reset using NRST [27/03/2025, 14:48:43] [INFO] CS_DAP_0: GEL Output: Initiating BOOTRST Board Reset [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: Reset line asserted [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: Reset line de-asserted [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: Board Reset Complete [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: Reset done [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: SEC_AP Disconnect [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: SEC_AP Reconnect [27/03/2025, 14:48:44] [INFO] CS_DAP_0: GEL Output: Command execution completed. [27/03/2025, 14:48:44] [INFO] CORTEX_M0P: GEL Output: Factory Reset executed. Please terminate debug session, power-cycle and restart debug session.
What coul be the cause?
