Part Number: MCU-PLUS-SDK-AM243X
Other Parts Discussed in Thread: LP-AM243
Hi
I am using AM243x for EtherCAT controlled motor control drive.
1. I am using a PRU for SDFM in which it is configured that sync out of PWM0 is the trigger to reset the IEP
2, I am using an additional PRU for EtherCAT communication in which outputs sync0 signal is routed to the PWM0 sync in
My system is working properly with ethercat master, however, when I disconnect the ethercat cable and reconnect it the SDFM's PRU sometimes get stuck in the following endless loop
Have you ever encountered this issue in the past ?
