Part Number: MSPM0G3507
Hello TI Support Team,
I’m new to working with TI microcontrollers and have started exploring each peripheral individually. While doing so, I encountered an issue when trying to add a peripheral to the empty driver project.
I imported the empty_freertos example from the following path:
C:\ti\mspm0_sdk_2_04_00_06\examples\rtos\LP_MSPM0G3507\drivers\empty_freertos
The project builds and runs fine in its default state. However, when I try to add UART peripheral support to this project, I run into build errors. I’ve attached the error logs for reference.
I also noticed that this example does not include a SysConfig file, which makes it unclear how to correctly add and configure peripherals manually.
Could you please guide me on the correct steps to add peripherals (like UART) to this type of empty project?
Thank you for your support!
Amara Rakesh
