Part Number: MSPM0G3507
Hello.
I have the MCU configured as a slave.
I want to generate an event from the PICO pin...but I am not sure if this is possible ?
Phil
Hello.
Phil
I suspect the answer is "no", but I should ask anyway: What sort of event are you thinking of? Do you just want to see that bits (mix of 0s/1s) are arriving?
The PF (Pin Function) for SPI is separate from that for GPIO, so you can't really see the state/activity of the pin unless the peripheral (SPI in this case) provides it, and I haven't found that. [I personally would like to see an indication (level/edge) of the /CS state, but there's not even that.]
