Part Number: MSPM0G1507
Other Parts Discussed in Thread: SYSCONFIG, UNIFLASH
Currently we are facing an issue with bootup of MCU MSPM0G1507.
- In MCU, the BSL and “BSL invoke pin check” is enabled by default unless we disable it through SysConfig in CCS.
- In our application BSL invoke pin forces the PC to jump into bootloader.
- Disabling the BSL through CCS and then programming the application file through Uniflash (External debugger XDS110) is tedious job.
We need to program around 600 boards hence looking for an easy and faster way of disabling the BSL or “BSL invoke pin check”. Can you please provide us the procedure to program the NONMAIN memory region of the MSPM0G1507 via an external debugger (XDS110).
If there is any limitation with UNIFLASH, then we are open to use any other tool that can program both application and nonmain memory region.
