Part Number: MSPM0L1306
Zero code studio does not address ( to the best of my understanding ) the use of OPA interface block.
Are You likely to add this functionality to zero code studio ?
If not how do I access the OPA functions?
Hi Ziggy,
You are correct, we currently don't support OPA in the Zero Code Studio. We will have it in the next release.
Diego Abad
Diego,
Thank You.
Is there a release date for the next version of Zero Code Studio?
In the mean time I have been looking into this issue and now I understand there exist a stand alone analog configuration tool which can help with OPA configuration.
I shall investigate this option. I hope to be able to shrink an existing solution presently consisting of four op amps,a voltage reference and a micro controller down to a single MPSM0G350x which offers everything I think is needed. Reference voltage output and sufficient analog processing.
Hi Ziggy,
The next release should be between May and June (there's not a confirmed date yet). As for the OPA configuration, I recommend looking into one of our examples in our SDK related to OPAs. Finally, the MSPM0G family is a good alternative, but we currently don't have any with four op-amps. If the criteria is price, our MSPM0C family should be sufficient.
Diego Abad
Hello Diego,
My apologies for the late response.
Yes this exchange has addressed my concerns. The fact that Vref is available on an external pin reduces the complexity of analog processing . I look forward to the new release and its utility in this instance.
