Part Number: AM2612
Other Parts Discussed in Thread: SYSCONFIG, LP-AM263, , UNIFLASH
Hi all:
I am currently working with the LP-AM2612 to debug the ospi_flash_dma example and encountered an issue requiring your expertise. Here are the details:
Original JSON Issue
Generated a device configuration JSON using the
ospi_flash_diagdiagnostic example. -
Attempted to import the JSON into CCS v20, but the import process hangs indefinitely (continuously "spinning").
Manual Configuration Attempt
Proceeded to manually configure the OSPI Flash parameters based on the JSON content.
However, during debugging, no signal activity is observed on the OSPI interface (confirmed via logic analyzer).
Request:
Could you please:
Verify if the
ospi_flash_diagJSON generation/import process is compatible with CCS v20?
- Provide a validated OSPI Flash configuration on syscfg for the LP-AM2612?
Best regards
zx
