TMDSRM48HDK: Cannot connect to TI HDK for RM48x Hercules Microcontrollers using Black-Hawk XDS560v2 trace emulator (windows 10).
Part Number: TMDSRM48HDK
ATTEMPT #1 uses 60-Pin MIPI connector on TI Hercules HDK target PCB:
Emulator is pingable on local subnet:
c:\Users\Kip_Leitner\workspace_v12\IslandDER\Debug>ping 10.1.10.208
Pinging 10.1.10.208 with 32 bytes of data:
Reply from 10.1.10.208: bytes=32 time=1ms TTL=64
Ping statistics for 10.1.10.208:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
TI response to "Debug"
[Start: Blackhawk XDS560v2-LAN System Trace Emulator_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag.exe -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\KIP_LE~1\AppData\Local\TEXASI~1\
CCS\ccs1281\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 560/2xx-class product.
This utility will load the program 'bh560v2e.out'.
Loaded FPGA Image: C:\ti\ccs1281\ccs\ccs_base\common\uscif\dtc_top.jbc
The library build date was 'Sep 26 2024'.
The library build time was '10:02:16'.
The library package version is '20.0.0.3178'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-100' (0xffffff9c).
The title is 'SC_ERR_BAD_GENERIC'.
The explanation is:
The controller or software detected an error with an unknown cause.
This error number is used when detailed information is not available.
[End: Blackhawk XDS560v2-LAN System Trace Emulator_0]
Setup Connection Error from CCS:
[Result]
The explanation is:
Attempt #2 Uses BlackHawk supplied MIPI - to - mini_20_pin_TI_JTAG.  Error message is different:
[Result]
E_RPCENV_IO_ERROR(-6) No connection: Error on socket connect: Connection timed out (ETIMEDOUT): Check the IP address
Download failed for file C:\ti\ccs1281\ccs\ccs_base\common\uscif\xds560v2.out
An error occurred while soft opening the controller.
The value is '-250' (0xffffff06).
The title is 'SC_ERR_ECOM_EMUNAME'.
The explanation is:
An attempt to access the debug probe via USCIF ECOM has failed.
Also, our network is showing the device XDS560v2 active
