Part Number: MSPM0G3507
Other Parts Discussed in Thread: UNIFLASH,
we will recommend create the thread to discuss technical question with English, this can help to contribute more E2E user.
Translate your question:
"I encountered one issue when use MSPM0G3507 device in my project. After downloading the image via CCS or uniflash, the program can run normally, but it cannot run after power cycle. But if I use EVM board(LP-MSPM0G3507), it can run normally after power cycle. Does this device have a hardware boot to determine the program running address?"
You need check PA18 pin voltage when power, if this is High when power, MCU will enter Bootloader mode, will not run app code(main.c), in our EVM board, this pin keep pull-down via 47K resistor.
Thanks!
Best Regards
Johnson
