Part Number: AM2434
Other Parts Discussed in Thread: SYSCONFIG, DP83869
Hi TI Experts,
Customer plans to use AM2434 run Profinet IRT Stack via MII interface.
Customer wants to know whether or not the following signals will be occupied by Profinet IRT Stack?
- COL (e.g. corresponding to DP83822 Pin 29)
- CRS/CRS_DV (e.g. corresponding to DP83822 Pin 27)
The reason to ask this question is that, the GPIO resource in AM2434 PRU is not sufficient. Hence, if the above signals will not be occupied by Profinet IRT Stack then customer will configure the corresponding pins as GPIO.
As customer needs to know this information before drawing the PCB schematic, could you help double check this and feedback to us as soon as possible please?
Kevin
