Part Number: AM263P4-Q1
I am trying to route a multiplexed PWM signal to the HSEC header on the AM263P EVM. In order to do this, the signal needs to go through the onboard SN74CB3Q3257PWR chip. However, the VSYS_3V3_LDO2 rail does not appear to be powered. LD22 is also not lighting up, meaning that for some reason, LDO2 is not configured. Is there a configuration setting for this? According to the datasheet, this power rail should be configured on startup.
