Part Number: TM4C129ENCPDT
Hello!
I am running into a issue when testing my EPI performance. I am using the EPI to interface with a Lattice FPGA.
Setup Details:
static int32_t SetEpiParams
EpiDriverConfigParamsType* params ///< EPI Parameter pointer
int32_t returnVal = -1;
if (params)
params->clkDiv = 64;
params->config = (EPI_GPMODE_CLKPIN | EPI_GPMODE_CLKGATE | EPI_GPMODE_FRAME50 | EPI_GPMODE_ASIZE_20 | EPI_GPMODE_DSIZE_8 | EPI_GPMODE_WRITE2CYCLE);
params->frameCount = 0;
params->addrMap = (EPI_ADDR_PER_BASE_NONE | EPI_ADDR_PER_BASE_A);
returnVal = 1;
return returnVal;
Starting Base Address:
#define EPI_PERIPH_ADDR 0xA0000000
The test I am doing, writes a random 8-bit values to offset 0 and then another random 8-bit to offset 1. Then I go back and read from offset 0 and offset 1. If the values read back on the inverse of the original values, that test passes, and the offset is incremented by 2, and the process continues.
The problem is that once my address equals 0xA0000110, the code freezes up when I try to perform a read. I have disconnected the FPGA, but still I can't read from this address, and the debugger itself wont step any further.
I suspect that I've setup the EPI incorrectly. I want it to be general purpose, 20 address bits, 8 data bits.
/** @file "epi_drv.c"
@b Details
The external peripheral interface (EPI) is configured in general purpose
A20, D8 mode to interface with an external FPGA.
-- Company: LASP, EGSE
-- Engineer: N. Madinger
-- Modified by N. Madinger
-- Create Date: 20 May 2025
-- Design Name: BETSI MCU
-- Project Name: BETSI
-- Target Devices: TIVA
-- Tool versions: CCS 12.5
@b
Description: This contains the initialization, and interface functions for the
EPI interface, as it relates to the general purpose interface with an external
FPGA.
Copyright 2025 (c) by: LASP
// Includes
#include <string.h>
#include "epi_drv.h"
#include "epi_fpga_tempSensor.h"
#include "inc/hw_epi.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "inc/hw_gpio.h"
#include "driverlib/epi.h"
#include "driverlib/gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
//#include "driverlib/uart.h"
//#include "utils/uartstdio.h"
// Constants
// Modular Variables
static EpiDriverSysType epiDriverSys;
// Private Functions
@return
- int32_t
* Positive value means that execution was valid
* Negative value means that execution was invalid
Clears the modular variable.
static int32_t ClearModVars
EpiDriverSysType* epiModVarPtr ///< Pointer to EPI driver modular variable
if (epiModVarPtr)
returnVal = 1;
memset(epiModVarPtr,0,sizeof(EpiDriverSysType));
return returnVal;
@return
- void
Initializes specific port for EPI functionality.
static void InitEpiPortA(void)
GPIOPinConfigure(GPIO_PA6_EPI0S8);
GPIOPinTypeEPI(GPIO_PORTA_BASE, GPIO_PIN_6);
GPIOPinConfigure(GPIO_PA7_EPI0S9);
GPIOPinTypeEPI(GPIO_PORTA_BASE, GPIO_PIN_7);
@return
- void
static void InitEpiPortB(void)
GPIOPinConfigure(GPIO_PB2_EPI0S27);
GPIOPinTypeEPI(GPIO_PORTB_BASE, GPIO_PIN_2);
GPIOPinConfigure(GPIO_PB3_EPI0S28);
GPIOPinTypeEPI(GPIO_PORTB_BASE, GPIO_PIN_3);
@return
- void
static void InitEpiPortC(void)
GPIOPinConfigure(GPIO_PC4_EPI0S7);
GPIOPinTypeEPI(GPIO_PORTC_BASE, GPIO_PIN_4);
GPIOPinConfigure(GPIO_PC5_EPI0S6);
GPIOPinTypeEPI(GPIO_PORTC_BASE, GPIO_PIN_5);
GPIOPinConfigure(GPIO_PC6_EPI0S5);
GPIOPinTypeEPI(GPIO_PORTC_BASE, GPIO_PIN_6);
GPIOPinConfigure(GPIO_PC7_EPI0S4);
GPIOPinTypeEPI(GPIO_PORTC_BASE, GPIO_PIN_7);
@return
- void
static void InitEpiPortG(void)
GPIOPinConfigure(GPIO_PG0_EPI0S11);
GPIOPinTypeEPI(GPIO_PORTG_BASE, GPIO_PIN_0);
GPIOPinConfigure(GPIO_PG1_EPI0S10);
GPIOPinTypeEPI(GPIO_PORTG_BASE, GPIO_PIN_1);
@return
- void
static void InitEpiPortH(void)
GPIOPinConfigure(GPIO_PH0_EPI0S0);
GPIOPinTypeEPI(GPIO_PORTH_BASE, GPIO_PIN_0);
GPIOPinConfigure(GPIO_PH1_EPI0S1);
GPIOPinTypeEPI(GPIO_PORTH_BASE, GPIO_PIN_1);
GPIOPinConfigure(GPIO_PH2_EPI0S2);
GPIOPinTypeEPI(GPIO_PORTH_BASE, GPIO_PIN_2);
@return
- void
static void InitEpiPortK(void)
GPIOPinConfigure(GPIO_PK3_EPI0S3);
GPIOPinTypeEPI(GPIO_PORTK_BASE, GPIO_PIN_3);
GPIOPinConfigure(GPIO_PK5_EPI0S31);
GPIOPinTypeEPI(GPIO_PORTK_BASE, GPIO_PIN_5);
GPIOPinConfigure(GPIO_PK6_EPI0S25);
GPIOPinTypeEPI(GPIO_PORTK_BASE, GPIO_PIN_6);
GPIOPinConfigure(GPIO_PK7_EPI0S24);
GPIOPinTypeEPI(GPIO_PORTK_BASE, GPIO_PIN_7);
@return
- void
static void InitEpiPortL(void)
GPIOPinConfigure(GPIO_PL0_EPI0S16);
GPIOPinTypeEPI(GPIO_PORTL_BASE, GPIO_PIN_0);
GPIOPinConfigure(GPIO_PL1_EPI0S17);
GPIOPinTypeEPI(GPIO_PORTL_BASE, GPIO_PIN_1);
GPIOPinConfigure(GPIO_PL2_EPI0S18);
GPIOPinTypeEPI(GPIO_PORTL_BASE, GPIO_PIN_2);
GPIOPinConfigure(GPIO_PL3_EPI0S19);
GPIOPinTypeEPI(GPIO_PORTL_BASE, GPIO_PIN_3);
GPIOPinConfigure(GPIO_PL4_EPI0S26);
GPIOPinTypeEPI(GPIO_PORTL_BASE, GPIO_PIN_4);
@return
- void
static void InitEpiPortM(void)
GPIOPinConfigure(GPIO_PM0_EPI0S15);
GPIOPinTypeEPI(GPIO_PORTM_BASE, GPIO_PIN_0);
GPIOPinConfigure(GPIO_PM1_EPI0S14);
GPIOPinTypeEPI(GPIO_PORTM_BASE, GPIO_PIN_1);
GPIOPinConfigure(GPIO_PM2_EPI0S13);
GPIOPinTypeEPI(GPIO_PORTM_BASE, GPIO_PIN_2);
GPIOPinConfigure(GPIO_PM3_EPI0S12);
GPIOPinTypeEPI(GPIO_PORTM_BASE, GPIO_PIN_3);
@return
- void
static void InitEpiPortN(void)
GPIOPinConfigure(GPIO_PN2_EPI0S29);
GPIOPinTypeEPI(GPIO_PORTN_BASE, GPIO_PIN_2);
GPIOPinConfigure(GPIO_PN3_EPI0S30);
GPIOPinTypeEPI(GPIO_PORTN_BASE, GPIO_PIN_3);
@return
- void
static void InitEpiPortQ(void)
GPIOPinConfigure(GPIO_PQ0_EPI0S20);
GPIOPinTypeEPI(GPIO_PORTQ_BASE, GPIO_PIN_0);
GPIOPinConfigure(GPIO_PQ1_EPI0S21);
GPIOPinTypeEPI(GPIO_PORTQ_BASE, GPIO_PIN_1);
GPIOPinConfigure(GPIO_PQ2_EPI0S22);
GPIOPinTypeEPI(GPIO_PORTQ_BASE, GPIO_PIN_2);
GPIOPinConfigure(GPIO_PQ3_EPI0S23);
GPIOPinTypeEPI(GPIO_PORTQ_BASE, GPIO_PIN_3);
@return
- int32_t
Configures EPI GPIO by configuring ports.
static int32_t InitEpiGpio(void)
InitEpiPortA();
InitEpiPortB();
InitEpiPortC();
InitEpiPortG();
InitEpiPortH();
InitEpiPortK();
InitEpiPortL();
InitEpiPortM();
InitEpiPortN();
InitEpiPortQ();
returnVal = 1;
return returnVal;
@return
- int32_t
Sets the initial settings for the EPI parameters.
if (params)
returnVal = 1;
return returnVal;
@return
- int32_t
static int32_t InitEpiPerph
if (params)
// The EPI0 peripheral must be enabled for use.
SysCtlPeripheralEnable(SYSCTL_PERIPH_EPI0);
// Sets the usage mode of the EPI module.
// The general purpose 8-bit data mode will be used.
EPIModeSet(EPI0_BASE, EPI_MODE_GENERAL);
//EPI CLK is 1/2 of SysClk
EPIDividerSet(EPI0_BASE, params->clkDiv);
EPIConfigGPModeSet
EPI0_BASE,
params->config,
params->frameCount,
0
EPIAddressMapSet(EPI0_BASE, params->addrMap);
//epiDriverSys.epiConfigParams = (*params);
returnVal = 1;
return returnVal;
// Public Functions
@return
- int32_t: positive value means success; negative value means error; 0 is invalid
Initializes the EPI interface to general purpose A20, D8 mode.
int32_t InitEpi(void)
returnVal = ClearModVars(&epiDriverSys);
if (0 < returnVal)
returnVal = InitEpiGpio();
if (0 < returnVal)
returnVal = SetEpiParams(&epiDriverSys.epiConfigParams);
if (0 < returnVal)
InitEpiPerph(&epiDriverSys.epiConfigParams);
epiDriverSys.epiDriverInitStatus = epiDriver_isInit;
return returnVal;
}//InitEpi
/** @file "epi_test.c"
@b Details
-- Create Date: 23 May 2025
@b
FPGA.
// Includes
#include <string.h>
#include <stdlib.h>
#include "epi_test.h"
// Constants
static EpiTestSysType epiTestSys;
@return
- int32_t
EpiTestSysType* epiModVarPtr ///< Pointer to EPI driver modular variable
if (epiModVarPtr)
returnVal = 1;
memset(epiModVarPtr,0,sizeof(EpiTestSysType));
return returnVal;
@return
- int32_t
Assigns peripheral base address to pointer;
int32_t AssignAddrToPrt
void** ptr, ///< Reference to pointer
uint32_t addr ///< Base address
if (ptr)
(*ptr) = ((void*)(addr));
returnVal = 1;
return returnVal;
@return
- int32_t
Assigns peripheral structure pointers to peripheral base addresses.
static int32_t SetPerphPointer
EpiPerphPtrsType* epiPerphsPtr ///< Pointer to EPI peripheral pointers
if (epiPerphsPtr)
AssignAddrToPrt(((void**)(&epiPerphsPtr->tempSensorDevicePtr)), ((uint32_t)(ON_BOARD_TEMP_SENSOR_ADDR)));
returnVal = 1;
return returnVal;
@return
- int32_t
This function generates a pseudo-random number within the specified range.
static int32_t GenterateRandInRange
uint32_t min, ///< The minimum value for the range
uint32_t max, ///< The maximum value for the range
uint32_t* randNumb ///< The random number is passed by reference
if ((NULL != randNumb) && (min < max))
(*randNumb) = rand() % (max - min + 1) + min;
returnVal = 1;
return returnVal;
@return
- int32_t
static int32_t SetMemoryTestVals
EpiMemoryTestType* memTstPtr ///< Pointer to memory test elements
uint32_t i = 0;
uint32_t randNumb = 0;
if (memTstPtr)
for (i = 0; i < MEM_TEST_ARRAY_SIZE; i++)
returnVal = GenterateRandInRange(0x00, 0xFF, &randNumb);
if (0 < returnVal)
memTstPtr->testArray[i].origVal = ((uint8_t)(randNumb));
memTstPtr->testArray[i].invertVal = ~(memTstPtr->testArray[i].origVal);
return returnVal;
@return
- int32_t
Writes values to the test addresses.
int32_t WriteToAddresses
uint32_t baseAddr, ///< Current base address
uint8_t* conductor = NULL;
if (memTstPtr)
returnVal = AssignAddrToPrt(((void**)(&conductor)),baseAddr);
if (0 < returnVal)
conductor[0] = memTstPtr->testArray[0].origVal;
conductor[1] = memTstPtr->testArray[1].origVal;
return returnVal;
@return
- int32_t
Reads values from the test addresses.
int32_t ReadFromAddresses
uint8_t* value1, ///< First value read by reference
uint8_t* value2 ///< Second value read by reference
if ((NULL != value1) && (NULL != value2))
if (0 < returnVal)
(*value1) = conductor[0];
(*value2) = conductor[1];
returnVal = 1;
return returnVal;
@return
- int32_t
* Positive value means that there is a logical inversion
* Negative value means that there was no logical inversion, or an error
Tests for a logical inversion amongst values.
int32_t TestInversion
EpiMemoryTestType* memTstPtr, ///< Pointer to memory test elements
uint8_t value1, ///< First comparison value
uint8_t value2 ///< Second comparison value
bool inversion = false;
if (memTstPtr)
inversion = ((memTstPtr->testArray[0].invertVal) == (value1));
if (inversion)
inversion = ((memTstPtr->testArray[1].invertVal) == (value2));
returnVal = 1;
return returnVal;
@return
- int32_t
Reads values from the test addresses and tests to see if these are inversions
of the original values.
int32_t ReadAndTestFromAddresses
uint8_t value1 = 0;
uint8_t value2 = 0;
if (memTstPtr)
returnVal = ReadFromAddresses(baseAddr, &value1, &value2);
if (0 < returnVal)
returnVal = TestInversion(memTstPtr,value1, value2);
return returnVal;
// Public Functions
@return
Initializes the EPI interface test.
int32_t InitEpiTest(void)
returnVal = ClearModVars(&epiTestSys);
if (0 < returnVal)
returnVal = InitEpi();
if (0 < returnVal)
//returnVal = SetPerphPointer(&epiTestSys.epiPerphPtrs);
epiTestSys.epiTestStatus = epi_test_memory;
return returnVal;
@return
Executes the EPI interface test;
int32_t ExecuteEpiTest(void)
uint8_t i = 0;
//volatile uint8_t temp = 0;
volatile TempCntrlReg0UseType temp;
uint32_t currentAddress = EPI_PERIPH_ADDR;
uint32_t offset = 0;
do
switch (epiTestSys.epiTestStatus)
case epi_test_init:
//epiTestSys.epiPerphPtrs.tempSensorDevicePtr->tempCntrlReg0.bits.enable = 0;
temp.byte = i;
epiTestSys.epiPerphPtrs.tempSensorDevicePtr->tempCntrlReg0.byte = i;
temp.byte = epiTestSys.epiPerphPtrs.tempSensorDevicePtr->tempCntrlReg0.byte;
//epiTestSys.epiPerphPtrs.tempSensorDevicePtr->tempCntrlReg1.byte = i+1;
i++;
break;
case epi_test_memory:
returnVal = SetMemoryTestVals(&epiTestSys.epiMemoryTest);
if (0 < returnVal)
returnVal = WriteToAddresses(currentAddress, &epiTestSys.epiMemoryTest);
if (0 < returnVal)
returnVal = ReadAndTestFromAddresses(currentAddress, &epiTestSys.epiMemoryTest);
returnVal = 1;
if (0 < returnVal)
offset += 2;
if ( offset >= MEMORY_TEST_TOTAL_REG)
offset = 0;
//Test complete if all valid
currentAddress += offset;
if (0 > returnVal)
epiTestSys.epiTestStatus = epi_test_error;
break;
case epi_test_config:
break;
case epi_test_read_temp:
break;
case epi_test_error:
break;
default:
break;
}while (epi_test_finished != epiTestSys.epiTestStatus);
returnVal = ((int32_t)(epiTestSys.epiTestStatus));
return returnVal;
