AM2431: How to change the snd buf size in LWIP?
Part Number: AM2431
I am using SDK8.3.0 (It is currently difficult for us to upgrade to the latest SDK version.)
I want to change the SO_SNDBUF, but it is not implemented.
I'd like to confirm that:
To achieve the functionality of SO_SNDBUF, can modifying TCP_SND_BUF achieve the same effect?
if not, can you give some advice to achieve the same effect?
  • Hi ,
    Thanks for your query.
    Will check on this and get back to you.
    Ashwani
  • Hi ,
    Yes, the SO_SNDBUF is not implemented in the LwIP as of now.
    You can set the value of TCP_SND_BUF to achieve similar results, but it is a compile time configuration, and this will be applicable globally. So, if any other applications have conflicting requirements, it has to be a trade-off.
    Although, there are implementations of SO_SNDBUF available in LwIP forums if you are interested to give it a try. This has not been tested internally in TI. So, we don't have assurance about its stability.
    Teja.
