Part Number: TMS570LS2135
Other Parts Discussed in Thread: HALCOGEN
Background:
- We are using a bootloader (BL, sectors 0,1) and application (sectors 2,3,4).
- Both the BL and App run their HalCoGen generated sys_startup.c files
- BL has `checkRAMECC()` while App has `checkRAMECC()` and `checkFlashECC()` tests enabled in their respective sys_startup.c files.
- Our exception handling could be better. But for now, exceptions are part of BL code and nothing unique is done in App or BL to redirect them while running App.
- We use the `vfill` mechanism in BL linker to ensure valid ECC for entire flash when loading the BL. BL is loaded by JTAG with "Auto ECC" and "Flash Verification" disabled.
- This works so far, except for 2 boards described below.
Problem:
- For 2 boards, BL loads fine after reset. When the BL attempts a jump to app, it runs the app's sys_startup.c file. In that file, when it runs either of `checkRAMECC` or `checkFlashECC` functions, then control jumps to address 0x0C (Prefetch abort). The MCU gets stuck, and asserts nERROR pin as those functions intentionally inject ECC errrors. The board has to be power cycled to clear the error and the whole cycle repeats.
- We have at least 3 other boards that don't show this behavior, for the same BL and App.
- One unique thing I can think of for these 2 problematic boards is they have stayed continuously ON for relatively much longer than other boards. Other boards see at least several power cycles in a day as they are part of CI setup. These two boards are for bench development and have stayed on without any power cycle or reset for several days and weeks at a stretch. They started showing this problem recently with no known HW/FW change.
Questions:
- checkRAMECC() and checkFlashECC() are supposed to induce dabort exceptions, which are then gracefully handled. Why would they generate prefetch_abort exceptions ?
- Is there any time varying behavior to be expected where these 2 boards having stayed on much longer than others might show an otherwise latent issue ?
- Do you think this is related how the app relies on exception handlers in BL's space ? While not ideal, I don't understand why would it be a problem.
App Linker File:
/* Linker Settings */
--retain="*(.intvecs)"
/* USER CODE BEGIN (1) */
/* Reserve a 4 byte memory location at end of FLASH_CODE to store CRC */
#define __CRC_ADDRESS 0x3FFFC
/* USER CODE END */
/* Memory Map */
MEMORY
VECTORS (X) : origin=0x00010020 length=0x00000020
/* FLASH CODE: sectors 2 to 4 are used for application */
/* Rest of FLASH is unused */
FLASH_CODE (RX) : origin=0x00010040 length=0x30000 - 0x40 fill=0xFFFFFFFF
FLASH0_UNUSED (RX) : origin=0x00040000 length=0x00180000 - 0x40000
FLASH1_UNUSED (RX) : origin=0x00180000 length=0x00080000
STACKS (RW) : origin=0x08000000 length=0x00001500
RAM (RW) : origin=0x08001500 length=0x0003EB00
/* Section Configuration */
SECTIONS
.intvecs : {} > VECTORS
.text : {} > FLASH_CODE
.const : {} > FLASH_CODE
.cinit : {} > FLASH_CODE
.pinit : {} > FLASH_CODE
.crc_section : {} > __CRC_ADDRESS
.bss : {} > RAM
.data : {} > RAM
.sysmem : {} > RAM
BL Linker File/***********************************************************************
* Author : QJ Wang. qjwang@ti.com
* Date : 5-25-2019
/* Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* USER CODE END */
/* Memory Map */
MEMORY
/* USER CODE BEGIN (2) */
/* USER CODE END */
VECTORS (X) : origin=0x00000000 length=0x00000020 vfill = 0xffffffff
FLASH0 (RX) : origin=0x00000020 length=0x0017FFE0 vfill = 0xffffffff
FLASH1 (RX) : origin=0x00180000 length=0x00080000 vfill = 0xffffffff
SRAM (RWX) : origin=0x08002000 length=0x0002D000
STACK (RW) : origin=0x08000000 length=0x00002000
/* USER CODE BEGIN (3) */
ECC_VEC (R) : origin=0xf0400000 length=0x4 ECC={algorithm=algoL2R5F021, input_range=VECTORS }
ECC_FLA0 (R) : origin=0xf0400000 + 0x4 length=0x3FFFC ECC={algorithm=algoL2R5F021, input_range=FLASH0 }
ECC_FLA1 (R) : origin=0xf0440000 length=0x40000 ECC={algorithm=algoL2R5F021, input_range=FLASH1 }
#if 1
ECC_VEC (R) : origin=(0xf0400000 + (start(VECTORS) >> 3))
length=(size(VECTORS) >> 3)
ECC={algorithm=algoL2R5F021, input_range=VECTORS}
ECC_FLA0 (R) : origin=(0xf0400000 + (start(FLASH0) >> 3))
length=(size(FLASH0) >> 3)
ECC_FLA1 (R) : origin=(0xf0400000 + (start(FLASH1) >> 3))
length=(size(FLASH1) >> 3)
#endif
/* USER CODE END */
/* USER CODE BEGIN (4) */
ECC
algoL2R5F021 : address_mask = 0xfffffff8 /* Address Bits 31:3 */
hamming_mask = R4 /* Use R4/R5 build in Mask */
parity_mask = 0x0c /* Set which ECC bits are Even and Odd parity */
mirroring = F021 /* RM57Lx and TMS570LCx are build in F021 */
/* USER CODE END */
SECTIONS
/* USER CODE BEGIN (5) */
/* USER CODE END */
/* The toot directory is \Debug */
flashAPI:
./build/src/SafetyMCU_Bootloaders/F021_Flash_API/02.01.01/source/Fapi_UserDefinedFunctions.o (.text)
./build/src/SafetyMCU_Bootloaders/source/bl_flash.o (.text)
--library= "./src/SafetyMCU_Bootloaders/F021_Flash_API/02.01.01/F021_API_CortexR4_BE.lib" (.text)
} palign=8 load = FLASH0, run = SRAM, LOAD_START(apiLoadStart), RUN_START(apiRunStart), SIZE(apiLoadSize)
.text : {} > FLASH0 /*Initialized executable code and constants*/
.const : {} > FLASH0
.cinit : {} > FLASH0 /*Initialized global and static variables*/
.pinit : {} > FLASH0
.data : {} > SRAM
.bss : {} > SRAM /*Uninitialized Global and static variables */
.sysmem : {} > SRAM
/* USER CODE BEGIN (6) */
/* USER CODE END */
/* USER CODE BEGIN (7) */
/* USER CODE END */
/* Misc */
/* USER CODE BEGIN (8) */
/* USER CODE END */
