    If the communication fails, have you checked the hardware, since I2C signal SDA/SCL require pull-up resistors, and also don't forget the ground should connect together. And also have you observed the transmitted waveform of the data through the oscilloscope or logic analyzer, any abnormal behavior?
    Peter
