MCU-PLUS-SDK-AM263PX: UART Logs Missing After Configuration Change – Need Help
Part Number: MCU-PLUS-SDK-AM263PX
Hi TI Community,
I’m currently working on a project using the AM263Px board, and I’ve encountered a problem where UART logs are no longer showing up after I made some changes to the project configuration.
Pushpin Issue
After modifying the system configuration, I noticed that no UART output is visible on the serial terminal.
Tools️ Setup Details
  • Board: AM263Px LaunchPad
  • SDK Version: SDK 10_02_00_15
  • UART Instance: UART0
  • Development Tool: CCS / SysConfig
  • Expected Behavior: Boot logs should appear via UART console
  • Current Behavior: No logs or output from UART after config changes
QuestionQuestions
  • Is there anything else I should check in the SysConfig or linker settings?
  • Could this be caused by interrupts or clock configuration?
  • Any known issues related to UART logging with the AM263Px?
Paperclip Attached
I’m attaching the current .syscfg file I’m using. Please have a look in case there's anything I might have missed.
 * These arguments were used when this file was generated. They will be automatically applied on subsequent loads
 * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
 * @cliArgs --device "AM263Px" --part "AM263P4" --package "ZCZ_C" --context "r5fss0-0" --product "MCU_PLUS_SDK_AM263Px@10.02.00"
 * @v2CliArgs --device "AM263P4-Q1" --package "NFBGA (ZCZ-C)" --context "r5fss0-0" --product "MCU_PLUS_SDK_AM263Px@10.02.00"
 * @versions {"tool":"1.23.1+4034"}
 * Import the modules used in this configuration.
const eeprom          = scripting.addModule("/board/eeprom/eeprom", {}, false);
const eeprom1         = eeprom.addInstance();
const led             = scripting.addModule("/board/led/led", {}, false);
const led1            = led.addInstance();
const i2c             = scripting.addModule("/drivers/i2c/i2c", {}, false);
const i2c1            = i2c.addInstance();
const debug_log       = scripting.addModule("/kernel/dpl/debug_log");
const dpl_cfg         = scripting.addModule("/kernel/dpl/dpl_cfg");
const mpu_armv7       = scripting.addModule("/kernel/dpl/mpu_armv7", {}, false);
const mpu_armv71      = mpu_armv7.addInstance();
const mpu_armv72      = mpu_armv7.addInstance();
const mpu_armv73      = mpu_armv7.addInstance();
const mpu_armv74      = mpu_armv7.addInstance();
const default_linker  = scripting.addModule("/memory_configurator/default_linker", {}, false);
const default_linker1 = default_linker.addInstance();
const general         = scripting.addModule("/memory_configurator/general", {}, false);
const general1        = general.addInstance();
const region          = scripting.addModule("/memory_configurator/region", {}, false);
const region1         = region.addInstance();
const section         = scripting.addModule("/memory_configurator/section", {}, false);
const section1        = section.addInstance();
const section2        = section.addInstance();
const section3        = section.addInstance();
const section4        = section.addInstance();
const section5        = section.addInstance();
const section6        = section.addInstance();
const section7        = section.addInstance();
const section8        = section.addInstance();
const section9        = section.addInstance();
const section10       = section.addInstance();
const section11       = section.addInstance();
const section12       = section.addInstance();
const enet_cpsw       = scripting.addModule("/networking/enet_cpsw/enet_cpsw", {}, false);
const enet_cpsw1      = enet_cpsw.addInstance();
 * Write custom configuration values to the imported modules.
eeprom1.$name      = "CONFIG_EEPROM0";
eeprom1.i2cAddress = 0x53;
led1.$name      = "CONFIG_LED0";
led1.name       = "TPIC2810";
led1.i2cAddress = 0x61;
i2c1.$name               = "CONFIG_I2C1";
led1.peripheralDriver    = i2c1;
eeprom1.peripheralDriver = i2c1;
i2c1.I2C.$assign         = "I2C1";
i2c1.I2C.SCL.$assign     = "I2C1_SCL";
i2c1.I2C.SDA.$assign     = "I2C1_SDA";
i2c1.I2C_child.$name     = "drivers_i2c_v1_i2c_v1_template0";
debug_log.enableUartLog            = true;
debug_log.uartLog.$name            = "CONFIG_UART0";
debug_log.uartLog.UART.$assign     = "UART0";
debug_log.uartLog.UART.RXD.$assign = "UART0_RXD";
debug_log.uartLog.UART.TXD.$assign = "UART0_TXD";
debug_log.uartLog.child.$name      = "drivers_uart_v2_uart_v2_template0";
mpu_armv71.$name             = "CONFIG_MPU_REGION0";
mpu_armv71.size              = 31;
mpu_armv71.attributes        = "Device";
mpu_armv71.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv71.allowExecute      = false;
mpu_armv72.$name             = "CONFIG_MPU_REGION1";
mpu_armv72.size              = 15;
mpu_armv72.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv73.$name             = "CONFIG_MPU_REGION2";
mpu_armv73.baseAddr          = 0x80000;
mpu_armv73.size              = 15;
mpu_armv73.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.$name             = "CONFIG_MPU_REGION3";
mpu_armv74.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.baseAddr          = 0x70000000;
mpu_armv74.size              = 21;
default_linker1.$name = "memory_configurator_default_linker0";
general1.$name        = "CONFIG_GENERAL0";
general1.linker.$name = "TIARMCLANG0";
region1.$name                                = "MEMORY_REGION_CONFIGURATION0";
region1.memory_region.create(11);
region1.memory_region[0].type                = "TCMA";
region1.memory_region[0].$name               = "R5F_VECS";
region1.memory_region[0].size                = 0x40;
region1.memory_region[0].auto                = false;
region1.memory_region[1].type                = "TCMA";
region1.memory_region[1].$name               = "R5F_TCMA";
region1.memory_region[1].size                = 0x7FC0;
region1.memory_region[2].type                = "TCMB";
region1.memory_region[2].size                = 0x8000;
region1.memory_region[2].$name               = "R5F_TCMB";
region1.memory_region[3].$name               = "SBL";
region1.memory_region[3].auto                = false;
region1.memory_region[3].size                = 0x40000;
region1.memory_region[4].$name               = "OCRAM";
region1.memory_region[4].auto                = false;
region1.memory_region[4].manualStartAddress  = 0x70040000;
region1.memory_region[4].size                = 0x200000;
region1.memory_region[5].type                = "FLASH";
region1.memory_region[5].auto                = false;
region1.memory_region[5].manualStartAddress  = 0x60100000;
region1.memory_region[5].$name               = "FLASH";
region1.memory_region[5].size                = 0x2000000;
region1.memory_region[6].$name               = "USER_SHM_MEM";
region1.memory_region[6].manualStartAddress  = 0x701D0000;
region1.memory_region[6].size                = 0x4000;
region1.memory_region[6].isShared            = true;
region1.memory_region[6].shared_cores        = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[7].$name               = "LOG_SHM_MEM";
region1.memory_region[7].manualStartAddress  = 0x701D4000;
region1.memory_region[7].size                = 0x4000;
region1.memory_region[7].isShared            = true;
region1.memory_region[7].shared_cores        = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[8].type                = "CUSTOM";
region1.memory_region[8].$name               = "RTOS_NORTOS_IPC_SHM_MEM";
region1.memory_region[8].auto                = false;
region1.memory_region[8].manualStartAddress  = 0x72000000;
region1.memory_region[8].size                = 0x3E80;
region1.memory_region[8].isShared            = true;
region1.memory_region[8].shared_cores        = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[9].type                = "CUSTOM";
region1.memory_region[9].$name               = "MAILBOX_HSM";
region1.memory_region[9].auto                = false;
region1.memory_region[9].manualStartAddress  = 0x44000000;
region1.memory_region[9].size                = 0x3CE;
region1.memory_region[9].isShared            = true;
region1.memory_region[9].shared_cores        = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[10].type               = "CUSTOM";
region1.memory_region[10].$name              = "MAILBOX_R5F";
region1.memory_region[10].auto               = false;
region1.memory_region[10].manualStartAddress = 0x44000400;
region1.memory_region[10].size               = 0x3CE;
region1.memory_region[10].isShared           = true;
region1.memory_region[10].shared_cores       = ["r5fss0-1","r5fss1-0","r5fss1-1"];
section1.load_memory                  = "R5F_VECS";
section1.group                        = false;
section1.$name                        = "Vector Table";
section1.output_section.create(1);
section1.output_section[0].$name      = ".vectors";
section1.output_section[0].palignment = true;
section2.load_memory                  = "OCRAM";
section2.$name                        = "Text Segments";
section2.output_section.create(5);
section2.output_section[0].$name      = ".text.hwi";
section2.output_section[0].palignment = true;
section2.output_section[1].$name      = ".text.cache";
section2.output_section[1].palignment = true;
section2.output_section[2].$name      = ".text.mpu";
section2.output_section[2].palignment = true;
section2.output_section[3].$name      = ".text.boot";
section2.output_section[3].palignment = true;
section2.output_section[4].$name      = ".text:abort";
section2.output_section[4].palignment = true;
section3.$name                        = "Code and Read-Only Data";
section3.load_memory                  = "FLASH";
section3.output_section.create(2);
section3.output_section[0].$name      = ".text";
section3.output_section[0].palignment = true;
section3.output_section[1].$name      = ".rodata";
section3.output_section[1].palignment = true;
section4.load_memory                  = "OCRAM";
section4.$name                        = "Data Segment";
section4.output_section.create(1);
section4.output_section[0].$name      = ".data";
section4.output_section[0].palignment = true;
section5.load_memory                             = "OCRAM";
section5.$name                                   = "Memory Segments";
section5.output_section.create(3);
section5.output_section[0].$name                 = ".bss";
section5.output_section[0].output_sections_start = "__BSS_START";
section5.output_section[0].output_sections_end   = "__BSS_END";
section5.output_section[0].palignment            = true;
section5.output_section[1].$name                 = ".sysmem";
section5.output_section[1].palignment            = true;
section5.output_section[2].$name                 = ".stack";
section5.output_section[2].palignment            = true;
section6.load_memory                              = "OCRAM";
section6.$name                                    = "Stack Segments";
section6.output_section.create(5);
section6.output_section[0].$name                  = ".irqstack";
section6.output_section[0].output_sections_start  = "__IRQ_STACK_START";
section6.output_section[0].output_sections_end    = "__IRQ_STACK_END";
section6.output_section[0].input_section.create(1);
section6.output_section[0].input_section[0].$name = ". = . + __IRQ_STACK_SIZE;";
section6.output_section[1].$name                  = ".fiqstack";
section6.output_section[1].output_sections_start  = "__FIQ_STACK_START";
section6.output_section[1].output_sections_end    = "__FIQ_STACK_END";
section6.output_section[1].input_section.create(1);
section6.output_section[1].input_section[0].$name = ". = . + __FIQ_STACK_SIZE;";
section6.output_section[2].$name                  = ".svcstack";
section6.output_section[2].output_sections_start  = "__SVC_STACK_START";
section6.output_section[2].output_sections_end    = "__SVC_STACK_END";
section6.output_section[2].input_section.create(1);
section6.output_section[2].input_section[0].$name = ". = . + __SVC_STACK_SIZE;";
section6.output_section[3].$name                  = ".abortstack";
section6.output_section[3].output_sections_start  = "__ABORT_STACK_START";
section6.output_section[3].output_sections_end    = "__ABORT_STACK_END";
section6.output_section[3].input_section.create(1);
section6.output_section[3].input_section[0].$name = ". = . + __ABORT_STACK_SIZE;";
section6.output_section[4].$name                  = ".undefinedstack";
section6.output_section[4].output_sections_start  = "__UNDEFINED_STACK_START";
section6.output_section[4].output_sections_end    = "__UNDEFINED_STACK_END";
section6.output_section[4].input_section.create(1);
section6.output_section[4].input_section[0].$name = ". = . + __UNDEFINED_STACK_SIZE;";
section7.load_memory                  = "OCRAM";
section7.$name                        = "Initialization and Exception Handling";
section7.output_section.create(3);
section7.output_section[0].$name      = ".ARM.exidx";
section7.output_section[0].palignment = true;
section7.output_section[1].$name      = ".init_array";
section7.output_section[1].palignment = true;
section7.output_section[2].$name      = ".fini_array";
section7.output_section[2].palignment = true;
section8.load_memory                 = "USER_SHM_MEM";
section8.type                        = "NOLOAD";
section8.$name                       = "User Shared Memory";
section8.group                       = false;
section8.output_section.create(1);
section8.output_section[0].$name     = ".bss.user_shared_mem";
section8.output_section[0].alignment = 0;
section9.load_memory                 = "LOG_SHM_MEM";
section9.$name                       = "Log Shared Memory";
section9.group                       = false;
section9.type                        = "NOLOAD";
section9.output_section.create(1);
section9.output_section[0].$name     = ".bss.log_shared_mem";
section9.output_section[0].alignment = 0;
section10.load_memory                 = "RTOS_NORTOS_IPC_SHM_MEM";
section10.type                        = "NOLOAD";
section10.$name                       = "IPC Shared Memory";
section10.group                       = false;
section10.output_section.create(1);
section10.output_section[0].$name     = ".bss.ipc_vring_mem";
section10.output_section[0].alignment = 0;
section11.load_memory                 = "MAILBOX_HSM";
section11.type                        = "NOLOAD";
section11.$name                       = "SIPC HSM Queue Memory";
section11.group                       = false;
section11.output_section.create(1);
section11.output_section[0].$name     = ".bss.sipc_hsm_queue_mem";
section11.output_section[0].alignment = 0;
section12.load_memory                 = "MAILBOX_R5F";
section12.$name                       = "SIPC R5F Queue Memory";
section12.group                       = false;
section12.type                        = "NOLOAD";
section12.output_section.create(1);
section12.output_section[0].$name     = ".bss.sipc_secure_host_queue_mem";
section12.output_section[0].alignment = 0;
enet_cpsw1.$name                  = "CONFIG_ENET_CPSW0";
enet_cpsw1.DisableMacPort2        = true;
enet_cpsw1.BoardType              = "am263px-lp";
enet_cpsw1.LargePoolPktCount      = 32;
enet_cpsw1.PktInfoOnlyEnable      = true;
enet_cpsw1.cptsHostRxTsEn         = false;
enet_cpsw1.RGMII1.$assign         = "RGMII1";
enet_cpsw1.txDmaChannel[0].$name  = "ENET_DMA_TX_CH0";
enet_cpsw1.rxDmaChannel[0].$name  = "ENET_DMA_RX_CH0";
enet_cpsw1.netifInstance.create(1);
enet_cpsw1.netifInstance[0].$name = "NETIF_INST_ID0";
const ethphy_cpsw_icssg  = scripting.addModule("/board/ethphy_cpsw_icssg/ethphy_cpsw_icssg", {}, false);
const ethphy_cpsw_icssg1 = ethphy_cpsw_icssg.addInstance({}, false);
ethphy_cpsw_icssg1.$name = "CONFIG_ENET_ETHPHY0";
enet_cpsw1.ethphy1       = ethphy_cpsw_icssg1;
 * Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
 * version of the tool will not impact the pinmux you originally saw.  These lines can be completely deleted in order to
 * re-solve from scratch.
enet_cpsw1.MDIO.$suggestSolution          = "MDIO";
enet_cpsw1.MDIO.MDC.$suggestSolution      = "MDIO_MDC";
enet_cpsw1.MDIO.MDIO.$suggestSolution     = "MDIO_MDIO";
enet_cpsw1.RGMII1.RD0.$suggestSolution    = "RGMII1_RD0";
enet_cpsw1.RGMII1.RD1.$suggestSolution    = "RGMII1_RD1";
enet_cpsw1.RGMII1.RD2.$suggestSolution    = "RGMII1_RD2";
enet_cpsw1.RGMII1.RD3.$suggestSolution    = "RGMII1_RD3";
enet_cpsw1.RGMII1.RX_CTL.$suggestSolution = "RGMII1_RX_CTL";
enet_cpsw1.RGMII1.RXC.$suggestSolution    = "RGMII1_RXC";
enet_cpsw1.RGMII1.TD0.$suggestSolution    = "RGMII1_TD0";
enet_cpsw1.RGMII1.TD1.$suggestSolution    = "RGMII1_TD1";
enet_cpsw1.RGMII1.TD2.$suggestSolution    = "RGMII1_TD2";
enet_cpsw1.RGMII1.TD3.$suggestSolution    = "RGMII1_TD3";
enet_cpsw1.RGMII1.TX_CTL.$suggestSolution = "RGMII1_TX_CTL";
enet_cpsw1.RGMII1.TXC.$suggestSolution    = "RGMII1_TXC";
enet_cpsw1.RGMII2.$suggestSolution        = "RGMII2";
enet_cpsw1.RGMII2.RD0.$suggestSolution    = "PR0_PRU0_GPIO0";
enet_cpsw1.RGMII2.RD1.$suggestSolution    = "PR0_PRU0_GPIO1";
enet_cpsw1.RGMII2.RD2.$suggestSolution    = "PR0_PRU0_GPIO2";
enet_cpsw1.RGMII2.RD3.$suggestSolution    = "PR0_PRU0_GPIO3";
enet_cpsw1.RGMII2.RX_CTL.$suggestSolution = "PR0_PRU0_GPIO4";
enet_cpsw1.RGMII2.RXC.$suggestSolution    = "PR0_PRU0_GPIO6";
enet_cpsw1.RGMII2.TD0.$suggestSolution    = "PR0_PRU0_GPIO11";
enet_cpsw1.RGMII2.TD1.$suggestSolution    = "PR0_PRU0_GPIO12";
enet_cpsw1.RGMII2.TD2.$suggestSolution    = "PR0_PRU0_GPIO13";
enet_cpsw1.RGMII2.TD3.$suggestSolution    = "PR0_PRU0_GPIO14";
enet_cpsw1.RGMII2.TX_CTL.$suggestSolution = "PR0_PRU0_GPIO15";
enet_cpsw1.RGMII2.TXC.$suggestSolution    = "PR0_PRU0_GPIO16";
Thanks in advance for your help!
Aymen SALEM
