Hi Jean,
Can you share the configurations you see from a regular I/O and the Debug lines I/O generated by SYSCONFIG (specifically the
Diego Abad
Hi Jean,
Do you still need help with this problem?
Diego Abad
Hi Diego,
Sorry for my delay. Here's the SYSCFG_DL_GPIO_init function:
SYSCONFIG_WEAK void SYSCFG_DL_GPIO_init(void)
DL_GPIO_initPeripheralOutputFunction(GPIO_PWM_0_C0_IOMUX,GPIO_PWM_0_C0_IOMUX_FUNC);
DL_GPIO_enableOutput(GPIO_PWM_0_C0_PORT, GPIO_PWM_0_C0_PIN);
DL_GPIO_initPeripheralOutputFunction(GPIO_PWM_1_C0_IOMUX,GPIO_PWM_1_C0_IOMUX_FUNC);
DL_GPIO_enableOutput(GPIO_PWM_1_C0_PORT, GPIO_PWM_1_C0_PIN);
DL_GPIO_initPeripheralOutputFunction(GPIO_PWM_1_C2_IOMUX,GPIO_PWM_1_C2_IOMUX_FUNC);
DL_GPIO_enableOutput(GPIO_PWM_1_C2_PORT, GPIO_PWM_1_C2_PIN);
DL_GPIO_setDigitalInternalResistor(GPIO_PWM_1_C0_IOMUX, DL_GPIO_RESISTOR_NONE);
DL_GPIO_setDigitalInternalResistor(GPIO_PWM_1_C2_IOMUX, DL_GPIO_RESISTOR_NONE);
As far as I understand, DL_GPIO_RESISTOR_NONE means that the internal pull-up/pull-down resistors are disabled.
Hi Jean,
Let me check this on my side if I can replicate the same problem.
Diego Abad
Hi Jean,
I found a temporary solution for this problem. Enabling the Digital IOMUX features seems to make the PWM signals work as intended. Moreover, you should remove the SWDIO and SWCLK jumpers from the launchpad.
Diego Abad
Hi Diego,
Thank you! Enabling pin configuration solved my issue. PWM seems to be working just fine.
Jean Tonin
