Part Number: MSPM0L2228
Hi TI Team,
I am working on a project using the MSPM0L2228 microcontroller and I am facing issues with clock configuration affecting I2C and UART.
Issue 1: Bit-Banging I2C Not Working at SYSOCS = 4 MHz
I am using a software-based (bit-banging) I2C to communicate with a TRH sensor.
When I configure SYSOCS to 2 MHz, the I2C works correctly.
But at SYSOCS = 4 MHz, the I2C stops working (no signal or improper waveform).
I enabled MFCLK, thinking it might help with peripheral clocks, but it didn’t resolve the issue.
Issue 2: Cannot Use MFPCLK for UART
I am trying to use MFPCLK as the UART source clock.
UART does not transmit or receive data when MFPCLK is selected.
I am using SysConfig for clock setup and UART configuration.
Thnak you,
ANKUSH.
