AM263P4-Q1: 128 Byte Alignment
Part Number: AM263P4-Q1
Hi Team,
My customer was looking at the ospi_flash_io.c file.
Could you tell me why the buffer is 128Byte aligned instead of 32Byte alignment? It looks like 32Byte should be sufficient. Is there a reason for this?
Mari Tsunoda
  • Hi Mari
    The code in ospi_flash_io.c is a common code shared by other MPU devices as well, where DMA needs 128B aligned. For AM263Px, the burst size defaults to 32B and so 32B alignment is okay, however, if the EDMA burst size is increased to 128B, then in that case alignment of 128B is required. So to cover all the cases, 128B alignment is made in the driver.
