Part Number: LP-MSPM0G3507
To the TI Team:
I'm testing the i2c_target_rw_multibyte_fifo_interrupts sample code and encountered an issue when remapping the I2C pins. When I configure SDA as PA10 and SCL as PA11, the code fails to function. Other pin combinations work correctly, but pins marked in the red square (including PA10/PA11) consistently cause issues.
My questions:
Are there mandatory modifications I might have missed for these specific pins?
Is it possible to implement I2C using PA10 and PA11? If so, what changes are required?
Appreciate your guidance!
