Part Number: MSPM0C1104
Other Parts Discussed in Thread: UNIFLASH, , SYSCONFIG
Hi All,
I'm using MSPM0C1104SDDFR SoT23-8 8 pin microcontroller . I upon referring the reference manual of the MSPMC1104 IC I understood that i can disable SWD pins in software and access them as a GPIO Pin, and can can enable them only by POR (Power on Reset ) .
In my code i Disabled the SWD pins using the API " DL_SYSCTL_disableSWD();" with delay cycles 10000000 "delay_cycles(10000000);" assuming it as 10 sec . After this is configered those pins as a PWM pin by the following api's
* Copyright (c) 2021, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <ti/driverlib/m0p/dl_interrupt.h>
#include "ti_msp_dl_config.h"
bool pulseTerminal=0 ;
int main(void)
SYSCFG_DL_init();
for(uint32_t i=0 ; i<100 ;i++)
DL_GPIO_initPeripheralOutputFunction(IOMUX_PINCM21,IOMUX_PINCM21_PF_TIMA0_CCP0);
DL_GPIO_enableOutput(GPIOA, DL_GPIO_PIN_20);
DL_GPIO_initPeripheralOutputFunction(IOMUX_PINCM20,IOMUX_PINCM20_PF_TIMA0_CCP2);
DL_GPIO_enableOutput(GPIOA, DL_GPIO_PIN_19);
DL_GPIO_setDigitalInternalResistor(IOMUX_PINCM21, (IOMUX_PINCM_PIPU_DISABLE | IOMUX_PINCM_PIPD_DISABLE));
DL_GPIO_setDigitalInternalResistor(IOMUX_PINCM20, (IOMUX_PINCM_PIPU_DISABLE | IOMUX_PINCM_PIPD_DISABLE));
DL_TimerA_setCCPDirection(TIMA0 , DL_TIMER_CC0_OUTPUT | DL_TIMER_CC2_OUTPUT );
NVIC_EnableIRQ(TIMA0_INT_IRQn);
DL_Timer_startCounter(TIMA0);
while (1)
void TIMA0_IRQHandler(void)
pulseTerminal =! pulseTerminal;
if(pulseTerminal)
DL_Timer_setCCPOutputDisabledAdv(TIMA0, DL_TIMER_CCP0_DIS_OUT_ADV_SET_BY_OCTL| DL_TIMER_CCP1_DIS_OUT_ADV_FORCE_LOW| \
DL_TIMER_CCP2_DIS_OUT_ADV_FORCE_LOW | DL_TIMER_CCP3_DIS_OUT_ADV_FORCE_LOW);
else
DL_Timer_setCCPOutputDisabledAdv(TIMA0, DL_TIMER_CCP0_DIS_OUT_ADV_FORCE_LOW| DL_TIMER_CCP1_DIS_OUT_ADV_FORCE_LOW| \
DL_TIMER_CCP2_DIS_OUT_ADV_SET_BY_OCTL | DL_TIMER_CCP3_DIS_OUT_ADV_FORCE_LOW);
