Part Number: AM2634
Other Parts Discussed in Thread: SYSCONFIG,
Hi Team,
I am trying to run I2C3 with a receive interrupt in slave mode on the AM263x LP kit, but we are not able to call the ISR function. Could you please let me know what I might be missing?
In addition, I am facing another issue — the I2C communication is happening and data is being exchanged between I2C_ICDXR and I2C_CDRR, but the data is not being copied into the variable. Could you let me know why this might be happening?
I am sharing my main.c, SysConfig file, and some UART log files for your reference. Please check and advise.
Note-: I have shorted I2C1 and I2C3 just only for reduce the HW connection. I am facing same issue with other MCU I2C also.
* Copyright (C) 2018-2022 Texas Instruments Incorporated
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdlib.h>
#include "ti_drivers_config.h"
#include "ti_board_config.h"
#include <drivers/soc.h>
#include <drivers/i2c/v1/lld/i2c_lld.h>
#include <drivers/hw_include/cslr_i2c.h>
#include "ti_drivers_open_close.h"
#include <kernel/dpl/HwiP.h>
#include <drivers/hw_include/soc_config.h>
#include <drivers/hw_include/cslr_soc.h>
#include <kernel/nortos/dpl/r5/HwiP_armv7r_vim.h>
#define I2C_TIMEOUT (5000U)
#define I2C_INTERRUPT_PRIORITY (4U)
I2CLLD_Handle I2C3,I2C1;
uint8_t tx_byte = 0x0A,rx_byte=0x00,count=1;
I2C_ExtendedParams I2C3_RX_Params,I2C3_TX_Params,I2C1_RX_Params,I2C1_TX_Params;
I2CLLD_Handle gI2cLldHandle3;
uint32_t gI2cVimStsAddr, intrNum, gI2cVimStsClrMask, intcBaseAddr;
HwiP_Params hwiPrms;
HwiP_Object gGpioHwiObject;
HwiP_Config gHwiConfig3 = {
.intcBaseAddr = 0x50F00000u,
void gpio_led_blink_main(void *args);
static void i2c_isr(void *args,const I2CLLD_Transaction * targetTxn,int32_t transferStatus);
static __attribute__((__section__(".text.hwi"), noinline, naked, target("arm"), aligned(4))) void App_I2C_ISR(void);
void print_dat(void)
DebugP_log("Tx_Byte = 0x%02X, Rx_Byte = 0x%02X,\n\r",tx_byte,rx_byte);
// DebugP_log("BRD Send = {");
// for(int i=0; i<txlen; i++)
// DebugP_log("0x%02X,",txdata[i]);
// DebugP_log("} \n\r");
// DebugP_log("AM263x Rec = {");
// for(int i=0; i<rxlen; i++)
// DebugP_log("0x%02X,",rxdata[i]);
// rxdata[i] = 0;
// DebugP_log("} \n\n\r");
void printRegisterRange(void)
uint32_t startAddr = 0x52503004UL;
uint32_t endAddr = 0x52503008UL;
for (uint32_t addr = startAddr; addr <= endAddr; addr += 4)
uint32_t val = *(volatile uint32_t *)addr;
DebugP_log("0x%08X : 0x%08X\r\n", addr, val);
uint32_t addr1 = 0x52501020UL;
uint32_t val1 = *(volatile uint32_t *)addr1;
DebugP_log("0x%08X : 0x%08X\r\n", addr1, val1);
uint32_t addr3 = 0x52503018UL;
uint32_t val3 = *(volatile uint32_t *)addr3;
DebugP_log("0x%08X : 0x%08X\r\n", addr3, val3);
ISR_CALL_LEVEL_NONFLOAT_REENTRANT(I2C_lld_controllerIsr, \
gI2cLldHandle3, \
intrNum, \
gI2cVimStsAddr, \
gI2cVimStsClrMask,
intcBaseAddr);
tx_byte = 0xAB;
count++;
void init_i2c_int(void)
gI2cLldHandle3 = (I2CLLD_Handle)(gI2cLldHandle[CONFIG_I2C3]);
intrNum = gI2cLldHandle3->intrNum;
intcBaseAddr = gHwiConfig3.intcBaseAddr;
gI2cVimStsAddr = intcBaseAddr + (0x404u + (((intrNum)>> 5) & 0xFu) * 0x20u);
gI2cVimStsClrMask = 0x1u << ((intrNum) & 0x1Fu);
gI2cLldHandle3->targetTransferCompleteCallback = i2c_isr;
HwiP_setVecAddr(intrNum, (uintptr_t)&App_I2C_ISR);
HwiP_setPri(intrNum, I2C_INTERRUPT_PRIORITY);
HwiP_enableInt(intrNum);
int main(void)
System_init();
Board_init();
Drivers_open();
I2C3 = (I2CLLD_Handle)(gI2cLldHandle[CONFIG_I2C3]);
I2C1 = (I2CLLD_Handle)(gI2cLldHandle[CONFIG_I2C1]);
I2C1->i2cMsg.controllerMode = true;
I2C1_TX_Params.deviceAddress = 0x53;
I2C1_TX_Params.buffer = &tx_byte;
I2C1_TX_Params.size = 1U;
I2C1_TX_Params.expandSA = false;
I2C3->i2cMsg.targetAddress = 0x40;
I2C3_RX_Params.buffer = &rx_byte;
I2C3_RX_Params.size = 1U;
I2C3_RX_Params.expandSA = false;
GPIO_pinWriteHigh(CSL_GPIO0_U_BASE, GPIO_LED_PIN);
printRegisterRange();
print_dat();
init_i2c_int();
while(1)
I2C_lld_write(I2C1, &I2C1_TX_Params, 100);
I2C_lld_target_read(I2C3, &I2C3_RX_Params, 100);
ClockP_sleep(1);
DebugP_log("GPIO LED Blinking...%d\r\n",count);
print_dat();
// tx_byte++;
if(tx_byte > 0xF0)
tx_byte = 0x0A;
Board_deinit();
System_deinit();
return 0;
* These arguments were used when this file was generated. They will be automatically applied on subsequent loads
* via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
* @cliArgs --device "AM263x_beta" --part "AM263x" --package "ZCZ" --context "r5fss0-0" --product "MCU_PLUS_SDK_AM263x@10.02.00"
* @v2CliArgs --device "AM2634" --package "NFBGA (ZCZ)" --context "r5fss0-0" --product "MCU_PLUS_SDK_AM263x@10.02.00"
* @versions {"tool":"1.23.0+4000"}
* Import the modules used in this configuration.
const gpio = scripting.addModule("/drivers/gpio/gpio", {}, false);
const gpio1 = gpio.addInstance();
const i2c = scripting.addModule("/drivers/i2c/i2c");
const i2c1 = i2c.addInstance();
const i2c2 = i2c.addInstance();
const debug_log = scripting.addModule("/kernel/dpl/debug_log");
const dpl_cfg = scripting.addModule("/kernel/dpl/dpl_cfg");
const mpu_armv7 = scripting.addModule("/kernel/dpl/mpu_armv7", {}, false);
const mpu_armv71 = mpu_armv7.addInstance();
const mpu_armv72 = mpu_armv7.addInstance();
const mpu_armv73 = mpu_armv7.addInstance();
const mpu_armv74 = mpu_armv7.addInstance();
const default_linker = scripting.addModule("/memory_configurator/default_linker", {}, false);
const default_linker1 = default_linker.addInstance();
const general = scripting.addModule("/memory_configurator/general", {}, false);
const general1 = general.addInstance();
const region = scripting.addModule("/memory_configurator/region", {}, false);
const region1 = region.addInstance();
const section = scripting.addModule("/memory_configurator/section", {}, false);
const section1 = section.addInstance();
const section2 = section.addInstance();
const section3 = section.addInstance();
const section4 = section.addInstance();
const section5 = section.addInstance();
const section6 = section.addInstance();
const section7 = section.addInstance();
const section8 = section.addInstance();
const section9 = section.addInstance();
const section10 = section.addInstance();
const section11 = section.addInstance();
const section12 = section.addInstance();
* Write custom configuration values to the imported modules.
gpio1.$name = "GPIO_LED";
gpio1.pinDir = "OUTPUT";
gpio1.rx = true;
gpio1.GPIO_n.$assign = "UART0_CTSn";
i2c1.$name = "CONFIG_I2C3";
i2c1.enableIntr = false;
i2c1.sdkInfra = "LLD";
i2c1.ownTargetAddr = 0x53;
i2c1.I2C.$assign = "I2C3";
i2c1.I2C_child.$name = "drivers_i2c_v1_i2c_v1_template0";
i2c2.$name = "CONFIG_I2C1";
i2c2.sdkInfra = "LLD";
i2c2.ownTargetAddr = 0x40;
i2c2.I2C.$assign = "I2C1";
i2c2.I2C_child.$name = "drivers_i2c_v1_i2c_v1_template1";
debug_log.enableUartLog = true;
debug_log.uartLog.$name = "CONFIG_UART0";
debug_log.uartLog.UART.$assign = "UART0";
debug_log.uartLog.UART.RXD.$assign = "UART0_RXD";
debug_log.uartLog.UART.TXD.$assign = "UART0_TXD";
debug_log.uartLog.child.$name = "drivers_uart_v2_uart_v2_template0";
mpu_armv71.$name = "CONFIG_MPU_REGION0";
mpu_armv71.size = 31;
mpu_armv71.attributes = "Device";
mpu_armv71.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv71.allowExecute = false;
mpu_armv72.$name = "CONFIG_MPU_REGION1";
mpu_armv72.size = 15;
mpu_armv72.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv73.$name = "CONFIG_MPU_REGION2";
mpu_armv73.baseAddr = 0x80000;
mpu_armv73.size = 15;
mpu_armv73.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.$name = "CONFIG_MPU_REGION3";
mpu_armv74.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.baseAddr = 0x70000000;
mpu_armv74.size = 21;
default_linker1.$name = "memory_configurator_default_linker0";
general1.$name = "CONFIG_GENERAL0";
general1.linker.$name = "TIARMCLANG0";
region1.$name = "MEMORY_REGION_CONFIGURATION0";
region1.memory_region.create(11);
region1.memory_region[0].type = "TCMA";
region1.memory_region[0].$name = "R5F_VECS";
region1.memory_region[0].size = 0x40;
region1.memory_region[0].auto = false;
region1.memory_region[1].type = "TCMA";
region1.memory_region[1].$name = "R5F_TCMA";
region1.memory_region[1].size = 0x7FC0;
region1.memory_region[2].type = "TCMB";
region1.memory_region[2].size = 0x8000;
region1.memory_region[2].$name = "R5F_TCMB";
region1.memory_region[3].$name = "SBL";
region1.memory_region[3].auto = false;
region1.memory_region[3].size = 0x40000;
region1.memory_region[4].$name = "OCRAM";
region1.memory_region[4].auto = false;
region1.memory_region[4].manualStartAddress = 0x70040000;
region1.memory_region[4].size = 0x40000;
region1.memory_region[5].type = "FLASH";
region1.memory_region[5].auto = false;
region1.memory_region[5].size = 0x80000;
region1.memory_region[5].$name = "FLASH";
region1.memory_region[6].$name = "USER_SHM_MEM";
region1.memory_region[6].auto = false;
region1.memory_region[6].manualStartAddress = 0x701D0000;
region1.memory_region[6].size = 0x4000;
region1.memory_region[6].isShared = true;
region1.memory_region[6].shared_cores = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[7].$name = "LOG_SHM_MEM";
region1.memory_region[7].auto = false;
region1.memory_region[7].manualStartAddress = 0x701D4000;
region1.memory_region[7].size = 0x4000;
region1.memory_region[7].isShared = true;
region1.memory_region[7].shared_cores = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[8].type = "CUSTOM";
region1.memory_region[8].$name = "RTOS_NORTOS_IPC_SHM_MEM";
region1.memory_region[8].auto = false;
region1.memory_region[8].manualStartAddress = 0x72000000;
region1.memory_region[8].size = 0x3E80;
region1.memory_region[8].isShared = true;
region1.memory_region[8].shared_cores = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[9].type = "CUSTOM";
region1.memory_region[9].$name = "MAILBOX_HSM";
region1.memory_region[9].auto = false;
region1.memory_region[9].manualStartAddress = 0x44000000;
region1.memory_region[9].size = 0x3CE;
region1.memory_region[9].isShared = true;
region1.memory_region[9].shared_cores = ["r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[10].type = "CUSTOM";
region1.memory_region[10].$name = "MAILBOX_R5F";
region1.memory_region[10].auto = false;
region1.memory_region[10].manualStartAddress = 0x44000400;
region1.memory_region[10].size = 0x3CE;
region1.memory_region[10].isShared = true;
region1.memory_region[10].shared_cores = ["r5fss0-1","r5fss1-0","r5fss1-1"];
section1.load_memory = "R5F_VECS";
section1.group = false;
section1.$name = "Vector Table";
section1.output_section.create(1);
section1.output_section[0].$name = ".vectors";
section1.output_section[0].palignment = true;
section2.load_memory = "OCRAM";
section2.$name = "Text Segments";
section2.output_section.create(5);
section2.output_section[0].$name = ".text.hwi";
section2.output_section[0].palignment = true;
section2.output_section[1].$name = ".text.cache";
section2.output_section[1].palignment = true;
section2.output_section[2].$name = ".text.mpu";
section2.output_section[2].palignment = true;
section2.output_section[3].$name = ".text.boot";
section2.output_section[3].palignment = true;
section2.output_section[4].$name = ".text:abort";
section2.output_section[4].palignment = true;
section3.load_memory = "OCRAM";
section3.$name = "Code and Read-Only Data";
section3.output_section.create(2);
section3.output_section[0].$name = ".text";
section3.output_section[0].palignment = true;
section3.output_section[1].$name = ".rodata";
section3.output_section[1].palignment = true;
section4.load_memory = "OCRAM";
section4.$name = "Data Segment";
section4.output_section.create(1);
section4.output_section[0].$name = ".data";
section4.output_section[0].palignment = true;
section5.load_memory = "OCRAM";
section5.$name = "Memory Segments";
section5.output_section.create(3);
section5.output_section[0].$name = ".bss";
section5.output_section[0].output_sections_start = "__BSS_START";
section5.output_section[0].output_sections_end = "__BSS_END";
section5.output_section[0].palignment = true;
section5.output_section[1].$name = ".sysmem";
section5.output_section[1].palignment = true;
section5.output_section[2].$name = ".stack";
section5.output_section[2].palignment = true;
section6.load_memory = "OCRAM";
section6.$name = "Stack Segments";
section6.output_section.create(5);
section6.output_section[0].$name = ".irqstack";
section6.output_section[0].output_sections_start = "__IRQ_STACK_START";
section6.output_section[0].output_sections_end = "__IRQ_STACK_END";
section6.output_section[0].input_section.create(1);
section6.output_section[0].input_section[0].$name = ". = . + __IRQ_STACK_SIZE;";
section6.output_section[1].$name = ".fiqstack";
section6.output_section[1].output_sections_start = "__FIQ_STACK_START";
section6.output_section[1].output_sections_end = "__FIQ_STACK_END";
section6.output_section[1].input_section.create(1);
section6.output_section[1].input_section[0].$name = ". = . + __FIQ_STACK_SIZE;";
section6.output_section[2].$name = ".svcstack";
section6.output_section[2].output_sections_start = "__SVC_STACK_START";
section6.output_section[2].output_sections_end = "__SVC_STACK_END";
section6.output_section[2].input_section.create(1);
section6.output_section[2].input_section[0].$name = ". = . + __SVC_STACK_SIZE;";
section6.output_section[3].$name = ".abortstack";
section6.output_section[3].output_sections_start = "__ABORT_STACK_START";
section6.output_section[3].output_sections_end = "__ABORT_STACK_END";
section6.output_section[3].input_section.create(1);
section6.output_section[3].input_section[0].$name = ". = . + __ABORT_STACK_SIZE;";
section6.output_section[4].$name = ".undefinedstack";
section6.output_section[4].output_sections_start = "__UNDEFINED_STACK_START";
section6.output_section[4].output_sections_end = "__UNDEFINED_STACK_END";
section6.output_section[4].input_section.create(1);
section6.output_section[4].input_section[0].$name = ". = . + __UNDEFINED_STACK_SIZE;";
section7.load_memory = "OCRAM";
section7.$name = "Initialization and Exception Handling";
section7.output_section.create(3);
section7.output_section[0].$name = ".ARM.exidx";
section7.output_section[0].palignment = true;
section7.output_section[1].$name = ".init_array";
section7.output_section[1].palignment = true;
section7.output_section[2].$name = ".fini_array";
section7.output_section[2].palignment = true;
section8.load_memory = "USER_SHM_MEM";
section8.type = "NOLOAD";
section8.$name = "User Shared Memory";
section8.group = false;
section8.output_section.create(1);
section8.output_section[0].$name = ".bss.user_shared_mem";
section8.output_section[0].alignment = 0;
section9.load_memory = "LOG_SHM_MEM";
section9.$name = "Log Shared Memory";
section9.group = false;
section9.type = "NOLOAD";
section9.output_section.create(1);
section9.output_section[0].$name = ".bss.log_shared_mem";
section9.output_section[0].alignment = 0;
section10.load_memory = "RTOS_NORTOS_IPC_SHM_MEM";
section10.type = "NOLOAD";
section10.$name = "IPC Shared Memory";
section10.group = false;
section10.output_section.create(1);
section10.output_section[0].$name = ".bss.ipc_vring_mem";
section10.output_section[0].alignment = 0;
section11.load_memory = "MAILBOX_HSM";
section11.type = "NOLOAD";
section11.$name = "SIPC HSM Queue Memory";
section11.group = false;
section11.output_section.create(1);
section11.output_section[0].$name = ".bss.sipc_hsm_queue_mem";
section11.output_section[0].alignment = 0;
section12.load_memory = "MAILBOX_R5F";
section12.$name = "SIPC R5F Queue Memory";
section12.group = false;
section12.type = "NOLOAD";
section12.output_section.create(1);
section12.output_section[0].$name = ".bss.sipc_secure_host_queue_mem";
section12.output_section[0].alignment = 0;
* Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
* version of the tool will not impact the pinmux you originally saw. These lines can be completely deleted in order to
* re-solve from scratch.
i2c1.I2C.SCL.$suggestSolution = "EPWM8_B";
i2c1.I2C.SDA.$suggestSolution = "EPWM8_A";
i2c2.I2C.SCL.$suggestSolution = "I2C1_SCL";
i2c2.I2C.SDA.$suggestSolution = "I2C1_SDA";
Tx_Byte = 0x0A, Rx_Byte = 0x00, 0x52503004 : 0x00000040 0x52503008 : 0x00000438 0x52501020 : 0x0000000A 0x52503018 : 0x0000000A GPIO LED Blinking...1 Tx_Byte = 0x0A, Rx_Byte = 0x00, 0x52503004 : 0x00000040 0x52503008 : 0x00000438 0x52501020 : 0x0000000A 0x52503018 : 0x0000000A GPIO LED Blinking...1 Tx_Byte = 0x0A, Rx_Byte = 0x00, 0x52503004 : 0x00000040 0x52503008 : 0x00000438 0x52501020 : 0x0000000A 0x52503018 : 0x0000000A GPIO LED Blinking...1 Tx_Byte = 0x0A, Rx_Byte = 0x00, 0x52503004 : 0x00000040 0x52503008 : 0x00000438 0x52501020 : 0x0000000A 0x52503018 : 0x0000000A
