Part Number: AM2432
Other Parts Discussed in Thread: DP83869
Dear all:
We currently have a project to design an EtherCAT slave and an EtherNet/IP slave using AM2432, where the EtherCAT rate is 100M and the EtherNet/IP rate is 1000M. According to the design requirements of the EtherCAT slave, the physical layer PHY interface is MII or RMII interface, but the 1000M EtherNet/IP interface is RGMII interface. Therefore, if we choose a PHY that supports both RGMII and MII interfaces, can we achieve compatibility between the two (EtherCAT and EtherNet/IP) through the same PCBA? Thank you!
