Part Number: TM4C1230H6PM
the library in TivaWare C Series 1.1 and TivaWare C Series 2.2 should be recompiled for the
used micro?
Best Regards
used micro?
Best Regards
I don't understand your question. If you have installed a particular TivaWare version such as 2.2.0.295 then the driverlib.lib is already built and can be found at C:\ti\TivaWare_C_Series-2.2.0.295\driverlib\ccs\Debug\driverlib.lib. If you are going to modify the driverlib source code then you would need to rebuild the library.
