Part Number: MSPM0C1103
Good morning TI team
I am using MSPM0C1103 micro-controller with the following setup: IAR Embedded Workbench IDE and J-link (by SEGGEER).
In MSPM0C1103 there is a Cortex M0+:
- I need to know if it’s possible to use the watchdog internal to M0, where it’s always enabled (default) at power-up (see M0 ARM spec). If M0 watchdog is implemented in MSPM0C1103, how can I use it?
- My software uses the WWDT timer and it is configured and enabled only by application software. Is it possible to enable it at power-up? In old microcontrollers (@8bit), this feature was possible to do by a particular option bit and not by application software. This ensures that the WD always starts at startup. I would like to have WWDT enabled (default) at power-up and not by application software.
Thank you for your support.
Michele
