Part Number: MSPM0G3518
Hi team,
I hope you are doing good!
Can you please help me to understand the correct pin connections for the VREF module?
1) If I use the external VREF I need the decoupling capacitor between VREF+ and VREF-, correct? Can I also just use VREF+ and take VREF- for a differnet signal? From my understanding this is not recommended but in the Sysconfig tool I can select that just VREF+ is enabled and VREF- is not and can be used for a different signal. Which approach is correct?
2) If I use the internal VREF source, should I connect VREF- to GND?
3) Just for confirmation. If I have the internal VREF mode activated I still need the decoupling capacitor right?
Looking forward to your answer.
Best regards
Felix
