Part Number: TMS570LC4357-EP
We are trying to debug TMS570LC43HDK using FT4232H-56Q mini module as our custom hardware will have FT4232H IC for JTAG debugging. We are able to successfully connect JTAG using OpenOCD libraries and able to read and write in internal SRAM through telnet, gdb. When we tried to connect FT4232H-56Q mini module channel A JTAG pins to Arm 20 pin JTAG connector of TMS570LC43HDK to simulate XDS100v2 using CCS,we are getting the following error
The value is '-183' (0xffffff49) The title is 'SC_ERR_CTL_CBL_BREAK_FAR'. Kindly provide a solution to resolve the problem.
PS:- We have programmed the EEPROM of FT4232H-56Q mini module to configure the channel A as debug port using XDS100v2 configuration XML file.
