Part Number: AM2434
The customer has questions about EtherCAT specification of Industrial Communications SDK. Could you help to answer their questions below.
In the EtherCAT specification, there is an optional feature which detects as an error if the number of process data reception failures reaches the value set in “0x10F1:2 Sync Error count limit”,.
Does the TI EtherCAT solution in SDK support this feature?
If it does, how should it be implemented on the slave side to handle this error when it occurs?
If it does not, is there any similar functionality implemented separately?
Thanks and regards,
Hideaki
