MSPM0G3507: How to write values directly to flash from View > Memory
Part Number: MSPM0G3507
Hi experts,
I am using MSPM0G3507.
Q:Is it possible to write directly in CCS under View > Memory?
I modified mspm0g3507.gel located in C:\ti\ccs2020\ccs\ccs_base\emulation\gel to set 0x1000~0x1FFF and 0x400000~0x41FFF as |r|w|as4. Additionally, I have set the .cmd file to rwx.
Are there any other settings I need to configure?
O.H
  • Hi O.H,
    You can not directly write into Flash memory from the memory view. The only way to update this memory is by importing data from a file. You can however modify SRAM memory that has already been allocated from within the memory view.
    Brian
  • Hi Brian,
    Thnak you for your reply.
    The import failed. Did I miss any settings? I am trying to import the following file. The values ​​do not change even after refreshing the screen. SRAM values ​​can be changed directly or through import.
    @1000
    11 FF FF FF FF FF FF FF 22 22 FF FF FF FF FF FF
    33 33 33 33 FF FF FF FF 00 EF CD AB 78 56 34 12
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    q
    @400770
    FF 55 FF BE EF FF FF FF FF FF FF FF FF FF FF FF
    q
    Best reards,
    O.H
  • Hi O.H,
    In the project->properties->Debug->Category:MSPM0 Flash Settings: change the erase method to erase necessary sectors only. Also make sure the file's length you are importing is divisible by 8.
    When making these adjustments I was able to load in the files you provided.
    Brian
  • Hi Brian,
    Thank you for your support.
    I have confirmed this myself. The default settings for .gel and .cmd seem to be fine.
    O.H
