AM2434: AM243 issue with 100 Mbsp CPSW
Part Number: AM2434
Other Parts Discussed in Thread: LP-AM243, DP83TG720-EVM-AM2, LP-AM261
Dear experts,
I am currently evaluating gPTP performance of a setup involving LP-AM243 boards.
I encountered an issue while testing how background traffic affects time synchronization performance.
The setup is: PC (iperf client) <> LP-AM243 (gPTP timeTransmitter) <> LP-AM243 (gPTP timeReceiver) <> PC (iperf server)
I am running with 100Mbits/s CPSW Ethernet and only a relatively small background traffic introduced with iperf degrades the gPTP performance.
Here is attached logs from both AM243 boards, where you can see the error messages. Iperf traffic is  started around time 60s sending TCP packets on 3Mbits/s rate in both  directions for 10 seconds.
This test was done without auto negotiation, but I encountered the same issue with auto negotiation as well.
I did not have the issue when running with 1Gbits/s CPSW Ethernet. Highest traffic I could achieve with iperf in that case was around 170Mbits/s, and that did not seem to affect the gPTP performance.
Please let me know if you have any insights or suggestions on what might be causing this behavior. Would it be possible to have an online session for figuring out this issue unless there is an easy fix for it?
Looking forward to hearing from you!
243_master_no_auto.log
243_slave_no_auto.log
  • Hi Alex,
    Please let me test this in our setup and try to recreate the issue to have further insights. Please expect a reply in 2 working days. Ideally, when the traffic is switching data, it should not reach till the R5 core in the switching nodes, in this case, AM243x-LP boards. My suspicion is that the initial handshake messages which happen with broadcast destination MAC address are entering the stack, and combined with the internal clocking differences for 100M, we are not able to retrieve the timestamps for these packets.
    I will recreate this in our local setup, and get back with results.
    Thanks and regards,
    Teja.
  • Hi Teja,
    How did you proceed with the recreation ?
    Alex
  • Hi Alex,
    I was engaged in other activities, and couldn't focus on this thread. I will get back to you tomorrow with the test results.
    Thank you for your patience,
    Teja.
  • Hi Teja,
    I hope you had the chance to look into this yesterday.
    How are the results so far.
    Alex
  • Hey team,
    It is 14 days now since this topic has been raised.... Can you please help to look into that topic ?
    Alex
  • Hi Alex,
    We are able to reproduce the issue, and informed the development team regarding the issue seen. Please give us 3 days to identify the issue at hand, and get back with analysis. I will keep the thread updated as we get new info.
    Thanks and regards,
    Teja.
  • Hi Teja,
    Thanks for the update.
    Please share an update once identification & analysis information are available.
    Alex
  • Hi Alex,
    The development team is looking into the issue to find the root cause. I will keep the thread posted regarding the updates.
    Thanks and regards,
    Teja.
  • Hi Teja,
    Is there any progress so far ?
    Alex
  • Hi Alex,
    We have informed the dev team, and the issue is due to the timestamp data not being available when there is large data throughput in 100M mode. They are running some tests to understand the reason behind it.
    We are also involving the stack team for more inputs on this. I will let you know further details when we get a response from the stack team.
    Teja.
  • Hi Alex,
    We were able to root cause the issue to a time stamp processing sequence where the packet is spending more time in the queue before being transmitted out in 100 Mbps mode. We are looking into possible fixes to address this. I will update the thread once we have more details on the final fix that is proposed.
    Thanks and regards,
    Teja.
  • Thanks Teja,
    Let me know once the fix is available.
    Alex
  • Hi Alex,
    We currently have a fix from the stack team, and we are trying to validate it. I will update the thread with the fix once we finish validating the fix.
    Teja.
  • Hi Teja,
    did you complete the validation so far ?
  • Hi Alex,
    We have ran the tests, but the issue is still persistent, though not as bad as before. The devices are briefly going out of sync and coming back. But if the idea is to demonstrate the stability of the system, we have an AdHOC workaround which is not impacting the gPTP sync and stability, but the overall throughput is slightly throttled.
    I can share the fix/workaround with you if that works for you.
    Thanks and regards,
    Teja.
  • Dear team,
    I now doing similar testing for a setup with a LP-AM261 boards with 100 base DP83TG720-EVM-AM2 SPE PHYs.
    The setup is following: PC (iperf client) <> Microchip LAN9383 (gPTP timeTransmitter) <> AM261 (gPTP timeReceiver) <> Microchip LAN9383 <> PC (iperf server).
    Here I am creating bidirectional traffic with 10Mbits/s rate. (iperf3 -c <server ip> --bidir -u -t 60 -b 10M -i 1)
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2026.02.05 14:23:54 =~=~=~=~=~=~=~=~=~=~=~=
    IFV:gptp:011026-102512:domainIndex=0, clock_master_sync_receive:the master clock rate to 213568ppb, GMdiff=6nsec
    IFV:gptp:011026-227508:domainIndex=0, clock_master_sync_receive:the master clock rate to 213521ppb, GMdiff=-16nsec
    IFV:gptp:011026-352500:domainIndex=0, clock_master_sync_receive:the master clock rate to 213586ppb, GMdiff=15nsec
    IFV:gptp:011026-477627:domainIndex=0, clock_master_sync_receive:the master clock rate to 213530ppb, GMdiff=-12nsec
    IFV:gptp:011026-602499:domainIndex=0, clock_master_sync_receive:the master clock rate to 213581ppb, GMdiff=12nsec
    IFV:gptp:011026-727480:domainIndex=0, clock_master_sync_receive:the master clock rate to 213563ppb, GMdiff=3nsec
    IFV:gptp:011026-852472:domainIndex=0, clock_master_sync_receive:the master clock rate to 213515ppb, GMdiff=-19nsec
    IFV:gptp:011026-977465:domainIndex=0, clock_master_sync_receive:the master clock rate to 213561ppb, GMdiff=4nsec
    IFV:gptp:011027-102457:domainIndex=0, clock_master_sync_receive:the master clock rate to 213583ppb, GMdIFV:gptp:011143-471378:domainIndex=0, clock_master_sync_receive:the master clock rate to 213602ppb, GMdiff=-4nsec
    IFV:gptp:011143-596255:domainIndex=0, clock_master_sync_receive:the master clock rate to 213487ppb, GMdiff=-55nsec
    IFV:gptp:011143-721235:domainIndex=0, clock_master_sync_receive:the master clock rate to 213397ppb, GMdiff=-89nsec
    IFV:gptp:011143-846229:domainIndex=0, clock_master_sync_receive:the master clock rate to 213409ppb, GMdiff=-74nsec
    IFV:gptp:011143-971221:domainIndex=0, clock_master_sync_receive:the master clock rate to 213457ppb, GMdiff=-44nsec
    IFV:gptp:011144-096214:domainIndex=0, clock_master_sync_receive:the master clock rate to 213503ppb, GMdiff=-19nsec
    IFV:gptp:011144-221209:domainIndex=0, clock_master_sync_receive:the master clock rate to 213362ppb, GMdiff=-80nsec
    IFV:gptp:011144-346202:domainIndex=0, clock_master_sync_receive:the master clock rate to 213495ppb, GMdiff=-12nsec
    IFV:gptp:011144-471331:domainIndex=0, clock_master_sync_receive:the master clock rate to 213448ppb, GMdiff=-32nsec
    IFV:gptp:011144-596202:domainIndex=0, clock_master_sync_receive:the master clock rate to 213536ppb, GMdiff=11nsec
    IFV:gptp:011144-721182:domainIndex=0, clock_master_sync_receive:the master clock rate to 213440ppb, GMdiff=-33nsec
    IFV:gptp:011144-846175:domainIndex=0, clock_master_sync_receive:the master clock rate to 213580ppb, GMdiff=33nsec
    IFV:gptp:011144-971169:domainIndex=0, clock_master_sync_receive:the master clock rate to 213539ppb, GMdiff=11nsec
    IFV:gptp:011145-096159:domainIndex=0, clock_master_sync_receive:the master clock rate to 213493ppb, GMdiff=-11nsec
    IFV:gptp:011145-221155:domainIndex=0, clock_master_sync_receive:the master clock rate to 213541ppb, GMdiff=12nsec
    IFV:gptp:011145-346147:domainIndex=0, clock_master_sync_receive:the master clock rate to 213575ppb, GMdiff=26nsec
    IFV:gptp:011145-471276:domainIndex=0, clock_master_sync_receive:the master clock rate to 213491ppb, GMdiff=-15nsec
    IFV:gptp:011145-596149:domainIndex=0, clock_master_sync_receive:the master clock rate to 213561ppb, GMdiff=18nsec
    IFV:gptp:011145-721128:domainIndex=0, clock_master_sync_receive:the master clock rate to 213536ppb, GMdiff=5nsec
    IFV:gptp:011145-846163:domainIndex=0, clock_master_sync_receive:the master clock rate to 213514ppb, GMdiff=-6nsec
    IFV:gptp:011145-971113:domainIndex=0, clock_master_sync_receive:the master clock rate to 213541ppb, GMdiff=7nsec
    IFV:gptp:011146-096151:domainIndex=0, clock_master_sync_receive:the master clock rate to 213517ppb, GMdiff=-5nsec
    IFV:gptp:011146-221100:domainIndex=0, clock_master_sync_receive:the master clock rate to 213563ppb, GMdiff=16nsec
    IFV:gptp:011146-346139:domainIndex=0, clock_master_sync_receive:the master clock rate to 213620ppb, GMdiff=40nsec
    IFV:gptp:011146-471224:domainIndex=0, clock_master_sync_receive:the master clock rate to 213671ppb, GMdiff=59nsec
    IFV:gptp:011146-596093:domainIndex=0, clock_master_sync_receive:the master clock rate to 213573ppb, GMdiff=9nsec
    IFV:gptp:011146-721074:domainIndex=0, clock_master_sync_receive:the master clock rate to 213606ppb, GMdiff=23nsec
    IFV:gptp:011146-846067:domainIndex=0, clock_master_sync_receive:the master clock rate to 213542ppb, GMdiff=-8nsec
    IFV:gptp:011146-971060:domainIndex=0, clock_master_sync_receive:the master clock rate to 213606ppb, GMdiff=22nsec
    IFV:gptp:011147-096054:domainIndex=0, clock_master_sync_receive:the master clock rate to 213549ppb, GMdiff=-6nsec
    IFV:gptp:011147-221048:domainIndex=0, clock_master_sync_receive:the master clock rate to 213596ppb, GMdiff=16nsec
      11147.313s : CPU load =   3.46 %
    IFV:gptp:011147-346041:domainIndex=0, clock_master_sync_receive:the master clock rate to 213546ppb, GMdiff=-8nsec
    IFV:gptp:011147-471170:domainIndex=0, clock_master_sync_receive:the master clock rate to 213567ppb, GMdiff=3nsec
    IFV:gptp:011147-596043:domainIndex=0, clock_master_sync_receive:the master clock rate to 213528ppb, GMdiff=-15nsec
    IFV:gptp:011147-721022:domainIndex=0, clock_master_sync_receive:the master clock rate to 213462ppb, GMdiff=-43nsec
    IFV:gptp:011147-846014:domainIndex=0, clock_master_sync_receive:the master clock rate to 213526ppb, GMdiff=-10nsec
    IFV:gptp:011147-971007:domainIndex=0, clock_master_sync_receive:the master clock rate to 213548ppb, GMdiff=1nsec
    IFV:gptp:011148-095998:domainIndex=0, clock_master_sync_receive:the master clock rate to 213536ppb, GMdiff=-5nsec
    IFV:gptp:011148-220991:domainIndex=0, clock_master_sync_receive:the master clock rate to 213455ppb, GMdiff=-41nsec
    IFV:gptp:011148-345985:domainIndex=0, clock_master_sync_receive:the master clock rate to 213543ppb, GMdiff=3nsec
    IFV:gptp:011148-720965:domainIndex=0, clock_master_sync_receive:the master clock rate to 213451ppb, GMdiff=-42nsec
    IFV:gptp:011148-846006:domainIndex=0, clock_master_sync_receive:the master clock rate to 213489ppb, GMdiff=-20nsec
    IFV:gptp:011148-970952:domainIndex=0, clock_master_sync_receive:the master clock rate to 213446ppb, GMdiff=-37nsec
    IFV:gptp:011149-095989:domainIndex=0, clock_master_sync_receive:the master clock rate to 213570ppb, GMdiff=23nsec
    IFV:gptp:011149-220939:domainIndex=0, clock_master_sync_receive:the master clock rate to 213539ppb, GMdiff=7nsec
    IFV:gptp:011149-345975:domainIndex=0, clock_master_sync_receive:the master clock rate to 213566ppb, GMdiff=19nsec
    IFV:gptp:011149-595933:domainIndex=0, clock_master_sync_receive:the master clock rate to 213515ppb, GMdiff=-12nsec
    IFV:gptp:011149-720912:domainIndex=0, clock_master_sync_receive:the master clock rate to 213584ppb, GMdiff=20nsec
    IFV:gptp:011149-845905:domainIndex=0, clock_master_sync_receive:the master clock rate to 213636ppb, GMdiff=41nsec
    IFV:gptp:011149-970898:domainIndex=0, clock_master_sync_receive:the master clock rate to 213600ppb, GMdiff=20nsec
    IFV:gptp:011150-220885:domainIndex=0, clock_master_sync_receive:the master clock rate to 213515ppb, GMdiff=-20nsec
    IFV:gptp:011150-345878:domainIndex=0, clock_master_sync_receive:the master clock rate to 213627ppb, GMdiff=32nsec
    IFV:gptp:011150-595879:domainIndex=0, clock_master_sync_receive:the master clock rate to 213702ppb, GMdiff=63nsec
    IFV:gptp:011150-720902:domainIndex=0, clock_master_sync_receive:the master clock rate to 213628ppb, GMdiff=23nsec
    IFV:gptp:011150-845851:domainIndex=0, clock_master_sync_receive:the master clock rate to 213586ppb, GMdiff=2nsec
    IFV:gptp:011150-970889:domainIndex=0, clock_master_sync_receive:the master clock rate to 213707ppb, GMdiff=56nsec
    IFV:gptp:011151-095838:domainIndex=0, clock_master_sync_receive:the master clock rate to 213577ppb, GMdiff=-8nsec
    IFV:gptp:011151-220875:domainIndex=0, clock_master_sync_receive:the master clock rate to 213697ppb, GMdiff=47nsec
    IFV:gptp:011151-345824:domainIndex=0, clock_master_sync_receive:the master clock rate to 213663ppb, GMdiff=27nsec
    IFV:gptp:011151-470997:domainIndex=0, clock_master_sync_receive:the master clock rate to 213586ppb, GMdiff=-11nsec
    IFV:gptp:011151-595826:domainIndex=0, clock_master_sync_receive:the master clock rate to 213644ppb, GMdiff=16nsec
    IFV:gptp:011151-720805:domainIndex=0, clock_master_sync_receive:the master clock rate to 213592ppb, GMdiff=-9nsec
    IFV:gptp:011151-845797:domainIndex=0, clock_master_sync_receive:the master clock rate to 213610ppb, GMdiff=0nsec
    IFV:gptp:011151-970791:domainIndex=0, clock_master_sync_receive:the master clock rate to 213663ppb, GMdiff=24nsec
    IFV:gptp:011152-095786:domainIndex=0, clock_master_sync_receive:the master clock rate to 213523ppb, GMdiff=-41nsec
    Starting OSPI Bootloader ...
    KPI_DATA: [BOOTLOADER_PROFILE] CPU Clock        : 500.000 MHz
    KPI_DATA: [BOOTLOADER_PROFILE] Boot Media       : NOR SPI FLASH
    KPI_DATA: [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz
    KPI_DATA: [BOOTLOADER_PROFILE] Boot Image Size  : 338 KB
    KPI_DATA: [BOOTLOADER_PROFILE] Cores present    :
    r5f0-0
    KPI_DATA: [BOOTLOADER PROFILE] System_init                      :        426us
    KPI_DATA: [BOOTLOADER PROFILE] Drivers_open                     :         90us
    KPI_DATA: [BOOTLOADER PROFILE] LoadHsmRtFw                      :       6291us
    KPI_DATA: [BOOTLOADER PROFILE] Board_driversOpen                :       6509us
    KPI_DATA: [BOOTLOADER PROFILE] CPU load                         :       7987us
    KPI_DATA: [BOOTLOADER PROFILE] SBL End                          :          4us
    KPI_DATA: [BOOTLOADER_PROFILE] SBL Total Time Taken             :      21309us
    Image loading done, switching to application ...
           TSN CPSW App
    start to open driver.
    EnetAppUtils_reduceCoreMacAllocation: Reduced Mac Address Allocation for CoreId:0 From 4 To 2
    Init all configs
    sitara-cpsw: init config
    Open MAC port 1
    Open MAC port 2
    sitara-cpsw: Create RX task for regular traffic
    initQs() txFreePktInfoQ initialized with 8 pkts
    MAC port addr: 70:ff:76:1f:2f:ee
    sitara-cpsw: default RX flow started
    log ovflow!
    INF:uconf:uc_dbal_setproc:uniconf is licensed
    INF:uconf:create_semname_with_dbname:null dbname is specified.
    Uniconf/ModuleInit time= 1392/8418 us
    EnetApp_initTsn:TSN app start done!
    log ovflow!
    INF:ubase:SM_DATA_INST: fragsize=8 fragused/fragnum=2032/2032 (100%)
    INF:gptp:000000-125056:domainIndex=0, GM changed old=00:00:00:00:00:00:00:00, new=70:FF:76:FF:FE:1F:2F:EE
    INF:gptp:000000-125168:gptpclock_set_gmsync:gptpInstanceIndex=0, domainIndex=0, gmstate=2
    EnetPhy_bindDriver:1942
    Cpsw_handleLinkUp:1616
    MAC Port 1: link up
    MAC Port 2: link up
    INF:cbase:000000-632285:cbl_query_response:tilld0: link UP, speed=100, duplex=1 !!!! (81us since link change event)
    INF:cbase:000000-632633:cbl_query_response:tilld1: link UP, speed=100, duplex=1 !!!! (430us since link change event)
    log ovflow!
    waiting_for_pdelay_interval_timer_proc:portIndex=2, not asCapable
    log ovflow!
    INF:gptp:000001-750710:gm_stable:gm_unstable_proc:domainIndex=0
    log ovflow!
    INF:gptp:000001-874524:setFollowUp_txFollowUp:domainIndex=0, portIndex=2, fup gap=1875msec tsync_ts_threshold=175msec
    log ovflow!
    gptpclock_set_gmsync:gptpInstanceIndex=0, domainIndex=0, gmstate=1
    INF:gptp:000002-633618:set_phase_offsetGM:domainIndex=0, New adjustment(New GM?)
    INF:gptp:000002-633714:set_phase_offsetGM:domainIndex=0, offset adjustment, diff=578431457213
    INF:gptp:000002-874135:reset asCapable for domainIndex=0, portIndex=2
    INF:gptp:000002-874253:gptpgcfg_set_asCapable:domainInde=0, portIndex=2, ascapable=0
    INF:gptp:000002-883388:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=13846
    IFV:gptp:000002-883583:domainIndex=0, clock_master_sync_receive:the master clock rate to 67378ppb, GMdiff=13846nsec
    INF:gptp:000003-008365:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=18367
    IFV:gptp:000003-008512:domainIndex=0, clock_master_sync_receive:the master clock rate to 121905ppb, GMdiff=18367nsec
    INF:gptp:000003-133315:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=21252
    IFV:gptp:000003-133462:domainIndex=0, clock_master_sync_receive:the master clock rate to 166245ppb, GMdiff=21252nsec
    INF:gptp:000003-258352:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=22750
    IFV:gptp:000003-258499:domainIndex=0, clock_master_sync_receive:the master clock rate to 200974ppb, GMdiff=22750nsec
    INF:gptp:000003-383302:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=23117
    IFV:gptp:000003-383449:domainIndex=0, clock_master_sync_receive:the master clock rate to 227028ppb, GMdiff=23117nsec
    INF:gptp:000003-508338:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=22703
    IFV:gptp:000003-508485:domainIndex=0, clock_master_sync_receive:the master clock rate to 246421ppb, GMdiff=22703nsec
    INF:gptp:000003-633423:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=21652
    IFV:gptp:000003-633570:domainIndex=0, clock_master_sync_receive:the master clock rate to 259672ppb, GMdiff=21652nsec
    INF:gptp:000003-758282:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=20229
    IFV:gptp:000003-758429:domainIndex=0, clock_master_sync_receive:the master clock rate to 268505ppb, GMdiff=20229nsec
    INF:gptp:000003-883290:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=18486
    IFV:gptp:000003-883436:domainIndex=0, clock_master_sync_receive:the master clock rate to 273049ppb, GMdiff=18486nsec
    INF:gptp:000004-008267:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=16639
    IFV:gptp:000004-008414:domainIndex=0, clock_master_sync_receive:the master clock rate to 274911ppb, GMdiff=16639nsec
    INF:gptp:000004-133262:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=14679
    IFV:gptp:000004-133409:domainIndex=0, clock_master_sync_receive:the master clock rate to 273911ppb, GMdiff=14679nsec
    INF:gptp:000004-258254:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=12806
    IFV:gptp:000004-258401:domainIndex=0, clock_master_sync_receive:the master clock rate to 271734ppb, GMdiff=12806nsec
    INF:gptp:000004-383248:set_phase_offsetGM:domainIndex=0, offset adjustment by Freq., diff=10950
    IFV:gptp:000004-383395:domainIndex=0, clock_master_sync_receive:the master clock rate to 267837ppb, GMdiff=10950nsec
    IFV:gptp:000004-508343:domainIndex=0, clock_master_sync_receive:the master clock rate to 263605ppb, GMdiff=9263nsec
    IFV:gptp:000004-633469:domainIndex=0, clock_master_sync_receive:the master clock rate to 258590ppb, GMdiff=7675nsec
    INF:gptp:000004-758159:set_phase_offsetGM:domainIndex=0, stable
    IFV:gptp:000004-758373:domainIndex=0, clock_master_sync_receive:the master clock rate to 253536ppb, GMdiff=6262nsec
    IFV:gptp:000004-883340:domainIndex=0, clock_master_sync_receive:the master clock rate to 244238ppb, GMdiff=4945nsec
    IFV:gptp:000005-008315:domainIndex=0, clock_master_sync_receive:the master clock rate to 237876ppb, GMdiff=4024nsec
          5. 68s : CPU load =   3.88 %
    IFV:gptp:000005-133310:domainIndex=0, clock_master_sync_receive:the master clock rate to 232118ppb, GMdiff=3204nsec
    IFV:gptp:000005-258302:domainIndex=0, clock_master_sync_receive:the master clock rate to 228118ppb, GMdiff=2622nsec
    IFV:gptp:000005-383295:domainIndex=0, clock_master_sync_receive:the master clock rate to 225194ppb, GMdiff=2188nsec
    IFV:gptp:000005-508288:domainIndex=0, clock_master_sync_receive:the master clock rate to 222623ppb, GMdiff=1810nsec
    IFV:gptp:000005-633415:domainIndex=0, clock_master_sync_receive:the master clock rate to 220818ppb, GMdiff=1536nsec
    IFV:gptp:000005-758276:domainIndex=0, clock_master_sync_receive:the master clock rate to 218510ppb, GMdiff=1210nsec
    IFV:gptp:000005-883283:domainIndex=0, clock_master_sync_receive:the master clock rate to 217741ppb, GMdiff=1080nsec
    IFV:gptp:000006-008265:domainIndex=0, clock_master_sync_receive:the master clock rate to 216856ppb, GMdiff=940nsec
    IFV:gptp:000006-133257:domainIndex=0, clock_master_sync_receive:the master clock rate to 216290ppb, GMdiff=843nsec
    IFV:gptp:000006-258248:domainIndex=0, clock_master_sync_receive:the master clock rate to 215213ppb, GMdiff=687nsec
    IFV:gptp:000006-383243:domainIndex=0, clock_master_sync_receive:the master clock rate to 215369ppb, GMdiff=685nsec
    IFV:gptp:000006-508236:domainIndex=0, clock_master_sync_receive:the master clock rate to 214435ppb, GMdiff=551nsec
    IFV:gptp:000006-633362:domainIndex=0, clock_master_sync_receive:the master clock rate to 214367ppb, GMdiff=526nsec
    IFV:gptp:000006-758222:domainIndex=0, clock_master_sync_receive:the master clock rate to 214564ppb, GMdiff=534nsec
    IFV:gptp:000006-883231:domainIndex=0, clock_master_sync_receive:the master clock rate to 214442ppb, GMdiff=503nsec
    IFV:gptp:000007-008210:domainIndex=0, clock_master_sync_receive:the master clock rate to 214204ppb, GMdiff=459nsec
    IFV:gptp:000007-133201:domainIndex=0, clock_master_sync_receive:the master clock rate to 213865ppb, GMdiff=404nsec
    IFV:gptp:000007-258197:domainIndex=0, clock_master_sync_receive:the master clock rate to 213637ppb, GMdiff=364nsec
    IFV:gptp:000007-383189:domainIndex=0, clock_master_sync_receive:the master clock rate to 214016ppb, GMdiff=399nsec
    IFV:gptp:000007-508184:domainIndex=0, clock_master_sync_receive:the master clock rate to 213852ppb, GMdiff=367nsec
    IFV:gptp:000007-633314:domainIndex=0, clock_master_sync_receive:the master clock rate to 213400ppb, GMdiff=301nsec
    IFV:gptp:000007-758168:domainIndex=0, clock_master_sync_receive:the master clock rate to 213524ppb, GMdiff=307nsec
    IFV:gptp:000007-883176:domainIndex=0, clock_master_sync_receive:the master clock rate to 214012ppb, GMdiff=357nsec
    IFV:gptp:000008-008158:domainIndex=0, clock_master_sync_receive:the master clock rate to 213779ppb, GMdiff=318nsec
    IFV:gptp:000008-133150:domainIndex=0, clock_master_sync_receive:the master clock rate to 213281ppb, GMdiff=248nsec
    IFV:gptp:000008-258143:domainIndex=0, clock_master_sync_receive:the master clock rate to 213730ppb, GMdiff=295nsec
    IFV:gptp:000008-383137:domainIndex=0, clock_master_sync_receive:the master clock rate to 213573ppb, GMdiff=267nsec
    IFV:gptp:000008-508130:domainIndex=0, clock_master_sync_receive:the master clock rate to 213721ppb, GMdiff=277nsec
    IFV:gptp:000008-633259:domainIndex=0, clock_master_sync_receive:the master clock rate to 213172ppb, GMdiff=202nsec
    IFV:gptp:000008-758117:domainIndex=0, clock_master_sync_receive:the master clock rate to 213230ppb, GMdiff=203nsec
    IFV:gptp:000008-883126:domainIndex=0, clock_master_sync_receive:the master clock rate to 213436ppb, GMdiff=222nsec
    IFV:gptp:000009-008102:domainIndex=0, clock_master_sync_receive:the master clock rate to 213285ppb, GMdiff=197nsec
    IFV:gptp:000009-133140:domainIndex=0, clock_master_sync_receive:the master clock rate to 213498ppb, GMdiff=217nsec
    IFV:gptp:000009-258089:domainIndex=0, clock_master_sync_receive:the master clock rate to 213634ppb, GMdiff=227nsec
    IFV:gptp:000009-383126:domainIndex=0, clock_master_sync_receive:the master clock rate to 213469ppb, GMdiff=200nsec
    IFV:gptp:000009-508076:domainIndex=0, clock_master_sync_receive:the master clock rate to 213180ppb, GMdiff=159nsec
    IFV:gptp:000009-633250:domainIndex=0, clock_master_sync_receive:the master clock rate to 213606ppb, GMdiff=206nsec
    IFV:gptp:000009-758064:domainIndex=0, clock_master_sync_receive:the master clock rate to 213368ppb, GMdiff=171nsec
    IFV:gptp:000009-883071:domainIndex=0, clock_master_sync_receive:the master clock rate to 213271ppb, GMdiff=154nsec
    domain=0, offset=0nsec, hw-adjrate=213271ppb
            gmsync=true, last_setts64=0nsec
    IFV:gptp:000010-008138:domainIndex=0, clock_master_sync_receive:the master clock rate to 213367ppb, GMdiff=161nsec
         10. 69s : CPU load =   3.13 %
    IFV:gptp:000010-133043:domainIndex=0, clock_master_sync_receive:the master clock rate to 213341ppb, GMdiff=153nsec
    IFV:gptp:000010-258036:domainIndex=0, clock_master_sync_receive:the master clock rate to 213716ppb, GMdiff=194nsec
    IFV:gptp:000010-383029:domainIndex=0, clock_master_sync_receive:the master clock rate to 213650ppb, GMdiff=180nsec
    IFV:gptp:000010-508023:domainIndex=0, clock_master_sync_receive:the master clock rate to 213555ppb, GMdiff=163nsec
    IFV:gptp:000010-633153:domainIndex=0, clock_master_sync_receive:the master clock rate to 213382ppb, GMdiff=137nsec
    IFV:gptp:000010-758009:domainIndex=0, clock_master_sync_receive:the master clock rate to 213342ppb, GMdiff=128nsec
    INF:gptp:000011-007934:domainIndex=0, clock_master_sync_receive:stable rate
    IFV:gptp:000011-008231:domainIndex=0, clock_master_sync_receive:the master clock rate to 213356ppb, GMdiff=122nsec
    INF:gptp:000011-008278:gptpclock_set_gmsync:gptpInstanceIndex=0, domainIndex=0, gmstate=2
    INF:gptp:000011-124089:gm_stable:gm_stable_proc:domainIndex=0
    IFV:gptp:000011-132990:domainIndex=0, clock_master_sync_receive:the master clock rate to 213424ppb, GMdiff=139nsec
    IFV:gptp:000011-257982:domainIndex=0, clock_master_sync_receive:the master clock rate to 213401ppb, GMdiff=113nsec
    IFV:gptp:000011-382975:domainIndex=0, clock_master_sync_receive:the master clock rate to 213384ppb, GMdiff=93nsec
    IFV:gptp:000011-507968:domainIndex=0, clock_master_sync_receive:the master clock rate to 213431ppb, GMdiff=104nsec
    IFV:gptp:000011-633101:domainIndex=0, clock_master_sync_receive:the master clock rate to 213471ppb, GMdiff=111nsec
    IFV:gptp:000011-882963:domainIndex=0, clock_master_sync_receive:the master clock rate to 213503ppb, GMdiff=103nsec
    IFV:gptp:000012-007942:domainIndex=0, clock_master_sync_receive:the master clock rate to 213393ppb, GMdiff=43nsec
    IFV:gptp:000012-132937:domainIndex=0, clock_master_sync_receive:the master clock rate to 213518ppb, GMdiff=94nsec
    IFV:gptp:000012-257928:domainIndex=0, clock_master_sync_receive:the master clock rate to 213497ppb, GMdiff=74nsec
    IFV:gptp:000012-382921:domainIndex=0, clock_master_sync_receive:the master clock rate to 213513ppb, GMdiff=73nsec
    IFV:gptp:000012-507915:domainIndex=0, clock_master_sync_receive:the master clock rate to 213494ppb, GMdiff=56nsec
    IFV:gptp:000012-633047:domainIndex=0, clock_master_sync_receive:the master clock rate to 213482ppb, GMdiff=44nsec
    IFV:gptp:000012-757900:domainIndex=0, clock_master_sync_receive:the master clock rate to 213466ppb, GMdiff=32nsec
    IFV:gptp:000012-882908:domainIndex=0, clock_master_sync_receive:the master clock rate to 213421ppb, GMdiff=8nsec
    IFV:gptp:000013-007889:domainIndex=0, clock_master_sync_receive:the master clock rate to 213465ppb, GMdiff=27nsec
    IFV:gptp:000013-132881:domainIndex=0, clock_master_sync_receive:the master clock rate to 213438ppb, GMdiff=12nsec
    IFV:gptp:000013-257875:domainIndex=0, clock_master_sync_receive:the master clock rate to 213357ppb, GMdiff=-26nsec
    IFV:gptp:000013-382868:domainIndex=0, clock_master_sync_receive:the master clock rate to 213325ppb, GMdiff=-38nsec
    IFV:gptp:000013-507862:domainIndex=0, clock_master_sync_receive:the master clock rate to 213433ppb, GMdiff=15nsec
    IFV:gptp:000013-632992:domainIndex=0, clock_master_sync_receive:the master clock rate to 213299ppb, GMdiff=-47nsec
    IFV:gptp:000013-757849:domainIndex=0, clock_master_sync_receive:the master clock rate to 213417ppb, GMdiff=11nsec
    IFV:gptp:000013-882856:domainIndex=0, clock_master_sync_receive:the master clock rate to 213360ppb, GMdiff=-16nsec
    IFV:gptp:000014-007880:domainIndex=0, clock_master_sync_receive:the master clock rate to 213440ppb, GMdiff=22nsec
    IFV:gptp:000014-132828:domainIndex=0, clock_master_sync_receive:the master clock rate to 213411ppb, GMdiff=7nsec
    IFV:gptp:000014-257866:domainIndex=0, clock_master_sync_receive:the master clock rate to 213333ppb, GMdiff=-29nsec
    IFV:gptp:000014-382814:domainIndex=0, clock_master_sync_receive:the master clock rate to 213395ppb, GMdiff=2nsec
    IFV:gptp:000014-507852:domainIndex=0, clock_master_sync_receive:the master clock rate to 213300ppb, GMdiff=-41nsec
    IFV:gptp:000014-632937:domainIndex=0, clock_master_sync_receive:the master clock rate to 213401ppb, GMdiff=9nsec
    IFV:gptp:000014-882801:domainIndex=0, clock_master_sync_receive:the master clock rate to 213364ppb, GMdiff=-10nsec
    IFV:gptp:000015-007782:domainIndex=0, clock_master_sync_receive:the master clock rate to 213283ppb, GMdiff=-45nsec
         15. 70s : CPU load =   3.11 %
    IFV:gptp:000015-132818:domainIndex=0, clock_master_sync_receive:the master clock rate to 213307ppb, GMdiff=-29nsec
    IFV:gptp:000015-257767:domainIndex=0, clock_master_sync_receive:the master clock rate to 213354ppb, GMdiff=-5nsec
    IFV:gptp:000015-382805:domainIndex=0, clock_master_sync_receive:the master clock rate to 213394ppb, GMdiff=14nsec
    IFV:gptp:000015-507755:domainIndex=0, clock_master_sync_receive:the master clock rate to 213249ppb, GMdiff=-52nsec
    IFV:gptp:000015-757741:domainIndex=0, clock_master_sync_receive:the master clock rate to 213345ppb, GMdiff=2nsec
    IFV:gptp:000016-007729:domainIndex=0, clock_master_sync_receive:the master clock rate to 213330ppb, GMdiff=-5nsec
    IFV:gptp:000016-132722:domainIndex=0, clock_master_sync_receive:the master clock rate to 213376ppb, GMdiff=16nsec
    IFV:gptp:000016-257716:domainIndex=0, clock_master_sync_receive:the master clock rate to 213237ppb, GMdiff=-48nsec
    IFV:gptp:000016-382710:domainIndex=0, clock_master_sync_receive:the master clock rate to 213378ppb, GMdiff=20nsec
    IFV:gptp:000016-507702:domainIndex=0, clock_master_sync_receive:the master clock rate to 213229ppb, GMdiff=-49nsec
    IFV:gptp:000016-632830:domainIndex=0, clock_master_sync_receive:the master clock rate to 213326ppb, GMdiff=0nsec
    IFV:gptp:000016-757688:domainIndex=0, clock_master_sync_receive:the master clock rate to 213218ppb, GMdiff=-48nsec
    IFV:gptp:000016-882697:domainIndex=0, clock_master_sync_receive:the master clock rate to 213235ppb, GMdiff=-35nsec
    IFV:gptp:000017-007674:domainIndex=0, clock_master_sync_receive:the master clock rate to 213209ppb, GMdiff=-43nsec
    IFV:gptp:000017-382699:domainIndex=0, clock_master_sync_receive:the master clock rate to 213110ppb, GMdiff=-73nsec
    IFV:gptp:000017-632822:domainIndex=0, clock_master_sync_receive:the master clock rate to 213190ppb, GMdiff=-20nsec
    IFV:gptp:000017-757636:domainIndex=0, clock_master_sync_receive:the master clock rate to 213239ppb, GMdiff=4nsec
    IFV:gptp:000017-882643:domainIndex=0, clock_master_sync_receive:the master clock rate to 213194ppb, GMdiff=-17nsec
    IFV:gptp:000018-007621:domainIndex=0, clock_master_sync_receive:the master clock rate to 213177ppb, GMdiff=-23nsec
    IFV:gptp:000018-132616:domainIndex=0, clock_master_sync_receive:the master clock rate to 213247ppb, GMdiff=11nsec
    IFV:gptp:000018-257609:domainIndex=0, clock_master_sync_receive:the master clock rate to 213188ppb, GMdiff=-17nsec
    IFV:gptp:000018-382602:domainIndex=0, clock_master_sync_receive:the master clock rate to 213258ppb, GMdiff=16nsec
    IFV:gptp:000018-507595:domainIndex=0, clock_master_sync_receive:the master clock rate to 213315ppb, GMdiff=40nsec
    IFV:gptp:000018-632724:domainIndex=0, clock_master_sync_receive:the master clock rate to 213274ppb, GMdiff=17nsec
    IFV:gptp:000018-757583:domainIndex=0, clock_master_sync_receive:the master clock rate to 213211ppb, GMdiff=-13nsec
    IFV:gptp:000018-882589:domainIndex=0, clock_master_sync_receive:the master clock rate to 213260ppb, GMdiff=11nsec
    IFV:gptp:000019-007570:domainIndex=0, clock_master_sync_receive:the master clock rate to 213220ppb, GMdiff=-8nsec
    IFV:gptp:000019-132562:domainIndex=0, clock_master_sync_receive:the master clock rate to 213164ppb, GMdiff=-32nsec
    IFV:gptp:000019-257557:domainIndex=0, clock_master_sync_receive:the master clock rate to 213312ppb, GMdiff=38nsec
    IFV:gptp:000019-382593:domainIndex=0, clock_master_sync_receive:the master clock rate to 213213ppb, GMdiff=-11nsec
    IFV:gptp:000019-507542:domainIndex=0, clock_master_sync_receive:the master clock rate to 213318ppb, GMdiff=37nsec
    IFV:gptp:000019-632715:domainIndex=0, clock_master_sync_receive:the master clock rate to 213351ppb, GMdiff=48nsec
    IFV:gptp:000019-757528:domainIndex=0, clock_master_sync_receive:the master clock rate to 213333ppb, GMdiff=35nsec
    IFV:gptp:000019-882537:domainIndex=0, clock_master_sync_receive:the master clock rate to 213226ppb, GMdiff=-17nsec
    domain=0, offset=0nsec, hw-adjrate=213226ppb
    IFV:gptp:000020-007517:domainIndex=0, clock_master_sync_receive:the master clock rate to 213338ppb, GMdiff=35nsec
         20. 71s : CPU load =   3.05 %
    IFV:gptp:000020-382495:domainIndex=0, clock_master_sync_receive:the master clock rate to 213280ppb, GMdiff=-2nsec
    IFV:gptp:000020-507533:domainIndex=0, clock_master_sync_receive:the master clock rate to 213265ppb, GMdiff=-9nsec
    IFV:gptp:000020-632618:domainIndex=0, clock_master_sync_receive:the master clock rate to 213421ppb, GMdiff=62nsec
    IFV:gptp:000020-882482:domainIndex=0, clock_master_sync_receive:the master clock rate to 213349ppb, GMdiff=20nsec
    IFV:gptp:000021-007462:domainIndex=0, clock_master_sync_receive:the master clock rate to 213439ppb, GMdiff=58nsec
    IFV:gptp:000021-132457:domainIndex=0, clock_master_sync_receive:the master clock rate to 213503ppb, GMdiff=80nsec
    IFV:gptp:000021-257448:domainIndex=0, clock_master_sync_receive:the master clock rate to 213367ppb, GMdiff=11nsec
    IFV:gptp:000021-382444:domainIndex=0, clock_master_sync_receive:the master clock rate to 213476ppb, GMdiff=59nsec
    IFV:gptp:000021-632565:domainIndex=0, clock_master_sync_receive:the master clock rate to 213410ppb, GMdiff=13nsec
    IFV:gptp:000021-757423:domainIndex=0, clock_master_sync_receive:the master clock rate to 213429ppb, GMdiff=20nsec
    IFV:gptp:000021-882431:domainIndex=0, clock_master_sync_receive:the master clock rate to 213455ppb, GMdiff=30nsec
    IFV:gptp:000022-007410:domainIndex=0, clock_master_sync_receive:the master clock rate to 213428ppb, GMdiff=15nsec
    IFV:gptp:000022-132404:domainIndex=0, clock_master_sync_receive:the master clock rate to 213463ppb, GMdiff=29nsec
    IFV:gptp:000022-257396:domainIndex=0, clock_master_sync_receive:the master clock rate to 213348ppb, GMdiff=-26nsec
    IFV:gptp:000022-382390:domainIndex=0, clock_master_sync_receive:the master clock rate to 213361ppb, GMdiff=-17nsec
    IFV:gptp:000022-507383:domainIndex=0, clock_master_sync_receive:the master clock rate to 213436ppb, GMdiff=19nsec
    IFV:gptp:000022-757369:domainIndex=0, clock_master_sync_receive:the master clock rate to 213489ppb, GMdiff=36nsec
    IFV:gptp:000022-882375:domainIndex=0, clock_master_sync_receive:the master clock rate to 213436ppb, GMdiff=8nsec
    IFV:gptp:000023-007354:domainIndex=0, clock_master_sync_receive:the master clock rate to 213498ppb, GMdiff=35nsec
    IFV:gptp:000023-132348:domainIndex=0, clock_master_sync_receive:the master clock rate to 213468ppb, GMdiff=18nsec
    IFV:gptp:000023-257344:domainIndex=0, clock_master_sync_receive:the master clock rate to 213413ppb, GMdiff=-9nsec
    IFV:gptp:000023-382342:domainIndex=0, clock_master_sync_receive:the master clock rate to 213460ppb, GMdiff=13nsec
    IFV:gptp:000023-507334:domainIndex=0, clock_master_sync_receive:the master clock rate to 213509ppb, GMdiff=34nsec
    IFV:gptp:000023-632458:domainIndex=0, clock_master_sync_receive:the master clock rate to 213455ppb, GMdiff=6nsec
    IFV:gptp:000023-757317:domainIndex=0, clock_master_sync_receive:the master clock rate to 213519ppb, GMdiff=34nsec
    IFV:gptp:000023-882324:domainIndex=0, clock_master_sync_receive:the master clock rate to 213470ppb, GMdiff=8nsec
    IFV:gptp:000024-007303:domainIndex=0, clock_master_sync_receive:the master clock rate to 213512ppb, GMdiff=26nsec
    IFV:gptp:000024-132296:domainIndex=0, clock_master_sync_receive:the master clock rate to 213445ppb, GMdiff=-7nsec
    IFV:gptp:000024-257293:domainIndex=0, clock_master_sync_receive:the master clock rate to 213357ppb, GMdiff=-46nsec
    IFV:gptp:000024-382283:domainIndex=0, clock_master_sync_receive:the master clock rate to 213438ppb, GMdiff=-5nsec
    IFV:gptp:000024-507276:domainIndex=0, clock_master_sync_receive:the master clock rate to 213468ppb, GMdiff=9nsec
    IFV:gptp:000024-632404:domainIndex=0, clock_master_sync_receive:the master clock rate to 213455ppb, GMdiff=2nsec
    IFV:gptp:000024-882271:domainIndex=0, clock_master_sync_receive:the master clock rate to 213429ppb, GMdiff=-14nsec
    IFV:gptp:000025-007252:domainIndex=0, clock_master_sync_receive:the master clock rate to 213343ppb, GMdiff=-51nsec
         25. 72s : CPU load =   3.02 %
    IFV:gptp:000025-132245:domainIndex=0, clock_master_sync_receive:the master clock rate to 213423ppb, GMdiff=-10nsec
    IFV:gptp:000025-382233:domainIndex=0, clock_master_sync_receive:the master clock rate to 213344ppb, GMdiff=-46nsec
    IFV:gptp:000025-507225:domainIndex=0, clock_master_sync_receive:the master clock rate to 213406ppb, GMdiff=-13nsec
    IFV:gptp:000025-632352:domainIndex=0, clock_master_sync_receive:the master clock rate to 213453ppb, GMdiff=10nsec
    IFV:gptp:000025-757212:domainIndex=0, clock_master_sync_receive:the master clock rate to 213366ppb, GMdiff=-30nsec
    IFV:gptp:000026-007196:domainIndex=0, clock_master_sync_receive:the master clock rate to 213352ppb, GMdiff=-27nsec
    IFV:gptp:000026-132291:domainIndex=0, clock_master_sync_receive:the master clock rate to 213363ppb, GMdiff=-19nsec
    IFV:gptp:000026-257205:domainIndex=0, clock_master_sync_receive:the master clock rate to 213262ppb, GMdiff=-62nsec
    IFV:gptp:000026-382177:domainIndex=0, clock_master_sync_receive:the master clock rate to 213405ppb, GMdiff=9nsec
    IFV:gptp:000026-507367:domainIndex=0, clock_master_sync_receive:the master clock rate to 213392ppb, GMdiff=2nsec
    IFV:gptp:000026-632300:domainIndex=0, clock_master_sync_receive:the master clock rate to 213371ppb, GMdiff=-8nsec
    IFV:gptp:000026-757157:domainIndex=0, clock_master_sync_receive:the master clock rate to 213329ppb, GMdiff=-26nsec
    IFV:gptp:000026-882187:domainIndex=0, clock_master_sync_receive:the master clock rate to 213367ppb, GMdiff=-6nsec
    IFV:gptp:000027-007145:domainIndex=0, clock_master_sync_receive:the master clock rate to 213249ppb, GMdiff=-58nsec
    IFV:gptp:000027-132138:domainIndex=0, clock_master_sync_receive:the master clock rate to 213361ppb, GMdiff=-2nsec
    IFV:gptp:000027-257132:domainIndex=0, clock_master_sync_receive:the master clock rate to 213263ppb, GMdiff=-46nsec
    IFV:gptp:000027-382124:domainIndex=0, clock_master_sync_receive:the master clock rate to 213357ppb, GMdiff=1nsec
    IFV:gptp:000027-632247:domainIndex=0, clock_master_sync_receive:the master clock rate to 213251ppb, GMdiff=-47nsec
    IFV:gptp:000027-757108:domainIndex=0, clock_master_sync_receive:the master clock rate to 213403ppb, GMdiff=26nsec
    IFV:gptp:000027-882113:domainIndex=0, clock_master_sync_receive:the master clock rate to 213416ppb, GMdiff=29nsec
    IFV:gptp:000028-007091:domainIndex=0, clock_master_sync_receive:the master clock rate to 213403ppb, GMdiff=20nsec
    IFV:gptp:000028-132085:domainIndex=0, clock_master_sync_receive:the master clock rate to 213287ppb, GMdiff=-34nsec
    IFV:gptp:000028-257077:domainIndex=0, clock_master_sync_receive:the master clock rate to 213417ppb, GMdiff=28nsec
    IFV:gptp:000028-382071:domainIndex=0, clock_master_sync_receive:the master clock rate to 213294ppb, GMdiff=-30nsec
    IFV:gptp:000028-507064:domainIndex=0, clock_master_sync_receive:the master clock rate to 213445ppb, GMdiff=41nsec
    IFV:gptp:000028-632345:domainIndex=0, clock_master_sync_receive:the master clock rate to 213400ppb, GMdiff=16nsec
    IFV:gptp:000028-882057:domainIndex=0, clock_master_sync_receive:the master clock rate to 213444ppb, GMdiff=31nsec
    IFV:gptp:000029-007058:domainIndex=0, clock_master_sync_receive:the master clock rate to 213395ppb, GMdiff=6nsec
    IFV:gptp:000029-132169:domainIndex=0, clock_master_sync_receive:the master clock rate to 213505ppb, GMdiff=55nsec
    IFV:gptp:000029-382018:domainIndex=0, clock_master_sync_receive:the master clock rate to 213381ppb, GMdiff=-12nsec
    IFV:gptp:000029-507009:domainIndex=0, clock_master_sync_receive:the master clock rate to 213404ppb, GMdiff=0nsec
    IFV:gptp:000029-632140:domainIndex=0, clock_master_sync_receive:the master clock rate to 213499ppb, GMdiff=43nsec
    IFV:gptp:000029-756994:domainIndex=0, clock_master_sync_receive:the master clock rate to 213487ppb, GMdiff=33nsec
    IFV:gptp:000029-882005:domainIndex=0, clock_master_sync_receive:the master clock rate to 213380ppb, GMdiff=-19nsec
    IFV:gptp:000030-006982:domainIndex=0, clock_master_sync_receive:the master clock rate to 213483ppb, GMdiff=29nsec
    domain=0, offset=0nsec, hw-adjrate=213483ppb
         30. 73s : CPU load =   3.05 %
    IFV:gptp:000030-381961:domainIndex=0, clock_master_sync_receive:the master clock rate to 213518ppb, GMdiff=40nsec
    IFV:gptp:000030-507075:domainIndex=0, clock_master_sync_receive:the master clock rate to 213497ppb, GMdiff=26nsec
    IFV:gptp:000030-632085:domainIndex=0, clock_master_sync_receive:the master clock rate to 213452ppb, GMdiff=3nsec
    IFV:gptp:000030-756943:domainIndex=0, clock_master_sync_receive:the master clock rate to 213551ppb, GMdiff=47nsec
    IFV:gptp:000030-881949:domainIndex=0, clock_master_sync_receive:the master clock rate to 213564ppb, GMdiff=48nsec
    IFV:gptp:000031-131922:domainIndex=0, clock_master_sync_receive:the master clock rate to 213622ppb, GMdiff=64nsec
    IFV:gptp:000031-256916:domainIndex=0, clock_master_sync_receive:the master clock rate to 213569ppb, GMdiff=33nsec
    IFV:gptp:000031-381909:domainIndex=0, clock_master_sync_receive:the master clock rate to 213635ppb, GMdiff=59nsec
    IFV:gptp:000031-506901:domainIndex=0, clock_master_sync_receive:the master clock rate to 213486ppb, GMdiff=-14nsec
    IFV:gptp:000031-756887:domainIndex=0, clock_master_sync_receive:the master clock rate to 213437ppb, GMdiff=-30nsec
    IFV:gptp:000031-881895:domainIndex=0, clock_master_sync_receive:the master clock rate to 213467ppb, GMdiff=-13nsec
    IFV:gptp:000032-006875:domainIndex=0, clock_master_sync_receive:the master clock rate to 213522ppb, GMdiff=13nsec
    IFV:gptp:000032-131867:domainIndex=0, clock_master_sync_receive:the master clock rate to 213550ppb, GMdiff=24nsec
    IFV:gptp:000032-256861:domainIndex=0, clock_master_sync_receive:the master clock rate to 213534ppb, GMdiff=14nsec
    IFV:gptp:000032-506849:domainIndex=0, clock_master_sync_receive:the master clock rate to 213545ppb, GMdiff=17nsec
    IFV:gptp:000032-631977:domainIndex=0, clock_master_sync_receive:the master clock rate to 213429ppb, GMdiff=-37nsec
    IFV:gptp:000032-756836:domainIndex=0, clock_master_sync_receive:the master clock rate to 213543ppb, GMdiff=18nsec
    IFV:gptp:000032-881842:domainIndex=0, clock_master_sync_receive:the master clock rate to 213566ppb, GMdiff=27nsec
    IFV:gptp:000033-006822:domainIndex=0, clock_master_sync_receive:the master clock rate to 213550ppb, GMdiff=17nsec
    IFV:gptp:000033-131814:domainIndex=0, clock_master_sync_receive:the master clock rate to 213522ppb, GMdiff=3nsec
    IFV:gptp:000033-256809:domainIndex=0, clock_master_sync_receive:the master clock rate to 213564ppb, GMdiff=22nsec
    IFV:gptp:000033-381802:domainIndex=0, clock_master_sync_receive:the master clock rate to 213430ppb, GMdiff=-40nsec
    IFV:gptp:000033-506796:domainIndex=0, clock_master_sync_receive:the master clock rate to 213585ppb, GMdiff=34nsec
    IFV:gptp:000033-631924:domainIndex=0, clock_master_sync_receive:the master clock rate to 213428ppb, GMdiff=-40nsec
    IFV:gptp:000033-756781:domainIndex=0, clock_master_sync_receive:the master clock rate to 213521ppb, GMdiff=6nsec
    IFV:gptp:000033-881790:domainIndex=0, clock_master_sync_receive:the master clock rate to 213544ppb, GMdiff=16nsec
    IFV:gptp:000034-006768:domainIndex=0, clock_master_sync_receive:the master clock rate to 213590ppb, GMdiff=35nsec
    IFV:gptp:000034-131760:domainIndex=0, clock_master_sync_receive:the master clock rate to 213547ppb, GMdiff=12nsec
    IFV:gptp:000034-256756:domainIndex=0, clock_master_sync_receive:the master clock rate to 213588ppb, GMdiff=29nsec
    IFV:gptp:000034-381748:domainIndex=0, clock_master_sync_receive:the master clock rate to 213552ppb, GMdiff=10nsec
    IFV:gptp:000034-506741:domainIndex=0, clock_master_sync_receive:the master clock rate to 213479ppb, GMdiff=-24nsec
    IFV:gptp:000034-756729:domainIndex=0, clock_master_sync_receive:the master clock rate to 213416ppb, GMdiff=-45nsec
    IFV:gptp:000034-881736:domainIndex=0, clock_master_sync_receive:the master clock rate to 213393ppb, GMdiff=-51nsec
    IFV:gptp:000035-006713:domainIndex=0, clock_master_sync_receive:the master clock rate to 213489ppb, GMdiff=-3nsec
         35. 74s : CPU load =   3.02 %
    IFV:gptp:000035-381696:domainIndex=0, clock_master_sync_receive:the master clock rate to 213517ppb, GMdiff=11nsec
    IFV:gptp:000035-506687:domainIndex=0, clock_master_sync_receive:the master clock rate to 213492ppb, GMdiff=-2nsec
    IFV:gptp:000035-631817:domainIndex=0, clock_master_sync_receive:the master clock rate to 213540ppb, GMdiff=20nsec
    IFV:gptp:000035-756675:domainIndex=0, clock_master_sync_receive:the master clock rate to 213440ppb, GMdiff=-27nsec
    IFV:gptp:000035-881683:domainIndex=0, clock_master_sync_receive:the master clock rate to 213542ppb, GMdiff=22nsec
    IFV:gptp:000036-006662:domainIndex=0, clock_master_sync_receive:the master clock rate to 213447ppb, GMdiff=-23nsec
    IFV:gptp:000036-131653:domainIndex=0, clock_master_sync_receive:the master clock rate to 213589ppb, GMdiff=43nsec
    IFV:gptp:000036-256648:domainIndex=0, clock_master_sync_receive:the master clock rate to 213448ppb, GMdiff=-25nsec
    IFV:gptp:000036-381641:domainIndex=0, clock_master_sync_receive:the master clock rate to 213597ppb, GMdiff=44nsec
    IFV:gptp:000036-506633:domainIndex=0, clock_master_sync_receive:the master clock rate to 213459ppb, GMdiff=-23nsec
    IFV:gptp:000036-631763:domainIndex=0, clock_master_sync_receive:the master clock rate to 213562ppb, GMdiff=26nsec
    IFV:gptp:000036-756621:domainIndex=0, clock_master_sync_receive:the master clock rate to 213615ppb, GMdiff=47nsec
    IFV:gptp:000036-881630:domainIndex=0, clock_master_sync_receive:the master clock rate to 213564ppb, GMdiff=19nsec
    IFV:gptp:000037-006609:domainIndex=0, clock_master_sync_receive:the master clock rate to 213627ppb, GMdiff=45nsec
    IFV:gptp:000037-131602:domainIndex=0, clock_master_sync_receive:the master clock rate to 213658ppb, GMdiff=54nsec
    IFV:gptp:000037-256709:domainIndex=0, clock_master_sync_receive:the master clock rate to 213566ppb, GMdiff=7nsec
    IFV:gptp:000037-381588:domainIndex=0, clock_master_sync_receive:the master clock rate to 213648ppb, GMdiff=43nsec
    CpswCpts_ioctl_handler_ENET_TIMESYNC_IOCTL_GET_ETH_TX_TIMESTAMP:370
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    ERR:cbase:Enet_ioctl GET_ETH_TX_TIMESTAMP failed -14
    IFV:gptp:000037-631711:domainIndex=0, clock_master_sync_receive:the master clock rate to 213623ppb, GMdiff=26nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    log ovflow!
    domainIndex=0, clock_master_sync_receive:the master clock rate to 211813ppb, GMdiff=-781nsec
    IFV:gptp:000038-006550:domainIndex=0, clock_master_sync_receive:the master clock rate to 212400ppb, GMdiff=-663nsec
    IFV:gptp:000038-131543:domainIndex=0, clock_master_sync_receive:the master clock rate to 212028ppb, GMdiff=-688nsec
    IFV:gptp:000038-256538:domainIndex=0, clock_master_sync_receive:the master clock rate to 212763ppb, GMdiff=-578nsec
    IFV:gptp:000038-381530:domainIndex=0, clock_master_sync_receive:the master clock rate to 212611ppb, GMdiff=-579nsec
    IFV:gptp:000038-506568:domainIndex=0, clock_master_sync_receive:the master clock rate to 212771ppb, GMdiff=-542nsec
    IFV:gptp:000038-631654:domainIndex=0, clock_master_sync_receive:the master clock rate to 212783ppb, GMdiff=-524nsec
    IFV:gptp:000038-756513:domainIndex=0, clock_master_sync_receive:the master clock rate to 219002ppb, GMdiff=245nsec
    IFV:gptp:000038-881520:domainIndex=0, clock_master_sync_receive:the master clock rate to 217480ppb, GMdiff=53nsec
    IFV:gptp:000039-006616:domainIndex=0, clock_master_sync_receive:the master clock rate to 216826ppb, GMdiff=-28nsec
    IFV:gptp:000039-131494:domainIndex=0, clock_master_sync_receive:the master clock rate to 215904ppb, GMdiff=-139nsec
    IFV:gptp:000039-256486:domainIndex=0, clock_master_sync_receive:the master clock rate to 215046ppb, GMdiff=-239nsec
    IFV:gptp:000039-381481:domainIndex=0, clock_master_sync_receive:the master clock rate to 214855ppb, GMdiff=-255nsec
    IFV:gptp:000039-506473:domainIndex=0, clock_master_sync_receive:the master clock rate to 214536ppb, GMdiff=-286nsec
    IFV:gptp:000039-631604:domainIndex=0, clock_master_sync_receive:the master clock rate to 214243ppb, GMdiff=-313nsec
    IFV:gptp:000039-756461:domainIndex=0, clock_master_sync_receive:the master clock rate to 214041ppb, GMdiff=-328nsec
    IFV:gptp:000039-881468:domainIndex=0, clock_master_sync_receive:the master clock rate to 213787ppb, GMdiff=-349nsec
    IFV:gptp:000040-006449:domainIndex=0, clock_master_sync_receive:the master clock rate to 213337ppb, GMdiff=-393nsec
         40. 75s : CPU load =   3.09 %
    domain=0, offset=0nsec, hw-adjrate=213337ppb
    IFV:gptp:000040-131441:domainIndex=0, clock_master_sync_receive:the master clock rate to 213643ppb, GMdiff=-344nsec
    IFV:gptp:000040-256433:domainIndex=0, clock_master_sync_receive:the master clock rate to 213484ppb, GMdiff=-353nsec
    IFV:gptp:000040-381545:domainIndex=0, clock_master_sync_receive:the master clock rate to 213453ppb, GMdiff=-346nsec
    INF:gptp:000040-506361:domainIndex=0, clock_master_sync_receive:stable rate
    IFV:gptp:000040-506484:domainIndex=0, clock_master_sync_receive:the master clock rate to 213350ppb, GMdiff=-348nsec
    IFV:gptp:000040-631550:domainIndex=0, clock_master_sync_receive:the master clock rate to 213321ppb, GMdiff=-322nsec
    IFV:gptp:000040-756408:domainIndex=0, clock_master_sync_receive:the master clock rate to 213178ppb, GMdiff=-350nsec
    IFV:gptp:000040-881526:domainIndex=0, clock_master_sync_receive:the master clock rate to 213124ppb, GMdiff=-335nsec
    IFV:gptp:000041-006396:domainIndex=0, clock_master_sync_receive:the master clock rate to 212973ppb, GMdiff=-365nsec
    IFV:gptp:000041-256381:domainIndex=0, clock_master_sync_receive:the master clock rate to 212867ppb, GMdiff=-332nsec
    IFV:gptp:000041-381375:domainIndex=0, clock_master_sync_receive:the master clock rate to 212980ppb, GMdiff=-245nsec
    IFV:gptp:000041-506368:domainIndex=0, clock_master_sync_receive:the master clock rate to 212911ppb, GMdiff=-249nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000041-631498:domainIndex=0, clock_master_sync_receive:the master clock rate to 212900ppb, GMdiff=-226nsec
    IFV:gptp:000041-756355:domainIndex=0, clock_master_sync_receive:the master clock rate to 212821ppb, GMdiff=-236nsec
    IFV:gptp:000041-881363:domainIndex=0, clock_master_sync_receive:the master clock rate to 212851ppb, GMdiff=-196nsec
    IFV:gptp:000042-006341:domainIndex=0, clock_master_sync_receive:the master clock rate to 212904ppb, GMdiff=-151nsec
    IFV:gptp:000042-131336:domainIndex=0, clock_master_sync_receive:the master clock rate to 212835ppb, GMdiff=-165nsec
    IFV:gptp:000042-256490:domainIndex=0, clock_master_sync_receive:the master clock rate to 212948ppb, GMdiff=-96nsec
    IFV:gptp:000042-381324:domainIndex=0, clock_master_sync_receive:the master clock rate to 212933ppb, GMdiff=-92nsec
    IFV:gptp:000042-506316:domainIndex=0, clock_master_sync_receive:the master clock rate to 212968ppb, GMdiff=-66nsec
    IFV:gptp:000042-631443:domainIndex=0, clock_master_sync_receive:the master clock rate to 212874ppb, GMdiff=-101nsec
    IFV:gptp:000042-756304:domainIndex=0, clock_master_sync_receive:the master clock rate to 212984ppb, GMdiff=-41nsec
    IFV:gptp:000042-881311:domainIndex=0, clock_master_sync_receive:the master clock rate to 212939ppb, GMdiff=-57nsec
    IFV:gptp:000043-006290:domainIndex=0, clock_master_sync_receive:the master clock rate to 212977ppb, GMdiff=-34nsec
    IFV:gptp:000043-131426:domainIndex=0, clock_master_sync_receive:the master clock rate to 212954ppb, GMdiff=-41nsec
    IFV:gptp:000043-256277:domainIndex=0, clock_master_sync_receive:the master clock rate to 213130ppb, GMdiff=42nsec
    IFV:gptp:000043-381270:domainIndex=0, clock_master_sync_receive:the master clock rate to 213023ppb, GMdiff=-11nsec
    IFV:gptp:000043-506265:domainIndex=0, clock_master_sync_receive:the master clock rate to 213126ppb, GMdiff=36nsec
    IFV:gptp:000043-631390:domainIndex=0, clock_master_sync_receive:the master clock rate to 213199ppb, GMdiff=65nsec
    IFV:gptp:000043-756249:domainIndex=0, clock_master_sync_receive:the master clock rate to 213305ppb, GMdiff=105nsec
    IFV:gptp:000044-006238:domainIndex=0, clock_master_sync_receive:the master clock rate to 213469ppb, GMdiff=154nsec
    IFV:gptp:000044-256222:domainIndex=0, clock_master_sync_receive:the master clock rate to 213548ppb, GMdiff=159nsec
    IFV:gptp:000044-381217:domainIndex=0, clock_master_sync_receive:the master clock rate to 213458ppb, GMdiff=101nsec
    IFV:gptp:000044-506212:domainIndex=0, clock_master_sync_receive:the master clock rate to 213572ppb, GMdiff=141nsec
    IFV:gptp:000044-631342:domainIndex=0, clock_master_sync_receive:the master clock rate to 213651ppb, GMdiff=161nsec
    IFV:gptp:000044-756197:domainIndex=0, clock_master_sync_receive:the master clock rate to 213565ppb, GMdiff=105nsec
    IFV:gptp:000044-881208:domainIndex=0, clock_master_sync_receive:the master clock rate to 213576ppb, GMdiff=98nsec
    IFV:gptp:000045-006185:domainIndex=0, clock_master_sync_receive:the master clock rate to 213607ppb, GMdiff=101nsec
         45. 76s : CPU load =   3.13 %
    IFV:gptp:000045-131177:domainIndex=0, clock_master_sync_receive:the master clock rate to 213641ppb, GMdiff=105nsec
    IFV:gptp:000045-381363:domainIndex=0, clock_master_sync_receive:the master clock rate to 213675ppb, GMdiff=101nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000045-631288:domainIndex=0, clock_master_sync_receive:the master clock rate to 213740ppb, GMdiff=106nsec
    IFV:gptp:000045-756323:domainIndex=0, clock_master_sync_receive:the master clock rate to 213726ppb, GMdiff=88nsec
    IFV:gptp:000045-881152:domainIndex=0, clock_master_sync_receive:the master clock rate to 213642ppb, GMdiff=41nsec
    IFV:gptp:000046-131123:domainIndex=0, clock_master_sync_receive:the master clock rate to 213791ppb, GMdiff=95nsec
    IFV:gptp:000046-256304:domainIndex=0, clock_master_sync_receive:the master clock rate to 213703ppb, GMdiff=45nsec
    IFV:gptp:000046-381113:domainIndex=0, clock_master_sync_receive:the master clock rate to 213739ppb, GMdiff=56nsec
    IFV:gptp:000046-756214:domainIndex=0, clock_master_sync_receive:the master clock rate to 213676ppb, GMdiff=12nsec
    IFV:gptp:000047-006076:domainIndex=0, clock_master_sync_receive:the master clock rate to 213720ppb, GMdiff=33nsec
    IFV:gptp:000047-256063:domainIndex=0, clock_master_sync_receive:the master clock rate to 213703ppb, GMdiff=20nsec
    IFV:gptp:000047-506049:domainIndex=0, clock_master_sync_receive:the master clock rate to 213622ppb, GMdiff=-24nsec
    IFV:gptp:000047-631263:domainIndex=0, clock_master_sync_receive:the master clock rate to 213663ppb, GMdiff=-3nsec
    IFV:gptp:000048-256011:domainIndex=0, clock_master_sync_receive:the master clock rate to 213548ppb, GMdiff=-53nsec
    IFV:gptp:000048-381005:domainIndex=0, clock_master_sync_receive:the master clock rate to 213567ppb, GMdiff=-39nsec
    IFV:gptp:000048-505996:domainIndex=0, clock_master_sync_receive:the master clock rate to 213518ppb, GMdiff=-57nsec
    IFV:gptp:000048-631127:domainIndex=0, clock_master_sync_receive:the master clock rate to 213460ppb, GMdiff=-77nsec
    IFV:gptp:000048-755979:domainIndex=0, clock_master_sync_receive:the master clock rate to 213654ppb, GMdiff=18nsec
    IFV:gptp:000048-880990:domainIndex=0, clock_master_sync_receive:the master clock rate to 213601ppb, GMdiff=-8nsec
    IFV:gptp:000049-005968:domainIndex=0, clock_master_sync_receive:the master clock rate to 213521ppb, GMdiff=-43nsec
    IFV:gptp:000049-130960:domainIndex=0, clock_master_sync_receive:the master clock rate to 213571ppb, GMdiff=-16nsec
    IFV:gptp:000049-255953:domainIndex=0, clock_master_sync_receive:the master clock rate to 213590ppb, GMdiff=-6nsec
    IFV:gptp:000049-380947:domainIndex=0, clock_master_sync_receive:the master clock rate to 213556ppb, GMdiff=-21nsec
    IFV:gptp:000049-631073:domainIndex=0, clock_master_sync_receive:the master clock rate to 213485ppb, GMdiff=-49nsec
    IFV:gptp:000049-755928:domainIndex=0, clock_master_sync_receive:the master clock rate to 213466ppb, GMdiff=-52nsec
    IFV:gptp:000049-880935:domainIndex=0, clock_master_sync_receive:the master clock rate to 213436ppb, GMdiff=-60nsec
    IFV:gptp:000050-005916:domainIndex=0, clock_master_sync_receive:the master clock rate to 213347ppb, GMdiff=-93nsec
         50. 77s : CPU load =   2.92 %
    domain=0, offset=0nsec, hw-adjrate=213347ppb
    IFV:gptp:000050-130971:domainIndex=0, clock_master_sync_receive:the master clock rate to 213443ppb, GMdiff=-40nsec
    IFV:gptp:000050-255901:domainIndex=0, clock_master_sync_receive:the master clock rate to 213421ppb, GMdiff=-46nsec
    IFV:gptp:000050-380894:domainIndex=0, clock_master_sync_receive:the master clock rate to 213441ppb, GMdiff=-32nsec
    IFV:gptp:000050-505886:domainIndex=0, clock_master_sync_receive:the master clock rate to 213403ppb, GMdiff=-46nsec
    IFV:gptp:000050-631020:domainIndex=0, clock_master_sync_receive:the master clock rate to 213355ppb, GMdiff=-63nsec
    IFV:gptp:000050-880967:domainIndex=0, clock_master_sync_receive:the master clock rate to 213379ppb, GMdiff=-36nsec
    IFV:gptp:000051-005861:domainIndex=0, clock_master_sync_receive:the master clock rate to 213361ppb, GMdiff=-40nsec
    IFV:gptp:000051-130854:domainIndex=0, clock_master_sync_receive:the master clock rate to 213423ppb, GMdiff=-8nsec
    IFV:gptp:000051-255848:domainIndex=0, clock_master_sync_receive:the master clock rate to 213274ppb, GMdiff=-74nsec
    IFV:gptp:000051-380840:domainIndex=0, clock_master_sync_receive:the master clock rate to 213323ppb, GMdiff=-44nsec
    IFV:gptp:000051-505834:domainIndex=0, clock_master_sync_receive:the master clock rate to 213368ppb, GMdiff=-19nsec
    IFV:gptp:000051-755820:domainIndex=0, clock_master_sync_receive:the master clock rate to 213402ppb, GMdiff=2nsec
    IFV:gptp:000051-880827:domainIndex=0, clock_master_sync_receive:the master clock rate to 213363ppb, GMdiff=-16nsec
    IFV:gptp:000052-005808:domainIndex=0, clock_master_sync_receive:the master clock rate to 213341ppb, GMdiff=-24nsec
    IFV:gptp:000052-130930:domainIndex=0, clock_master_sync_receive:the master clock rate to 213430ppb, GMdiff=19nsec
    IFV:gptp:000052-255794:domainIndex=0, clock_master_sync_receive:the master clock rate to 213354ppb, GMdiff=-17nsec
    IFV:gptp:000052-505781:domainIndex=0, clock_master_sync_receive:the master clock rate to 213468ppb, GMdiff=37nsec
    IFV:gptp:000052-630909:domainIndex=0, clock_master_sync_receive:the master clock rate to 213453ppb, GMdiff=26nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000052-755767:domainIndex=0, clock_master_sync_receive:the master clock rate to 213466ppb, GMdiff=29nsec
    IFV:gptp:000053-005756:domainIndex=0, clock_master_sync_receive:the master clock rate to 213406ppb, GMdiff=-1nsec
    IFV:gptp:000053-130747:domainIndex=0, clock_master_sync_receive:the master clock rate to 213357ppb, GMdiff=-23nsec
    IFV:gptp:000053-255739:domainIndex=0, clock_master_sync_receive:the master clock rate to 213511ppb, GMdiff=48nsec
    IFV:gptp:000053-380733:domainIndex=0, clock_master_sync_receive:the master clock rate to 213469ppb, GMdiff=24nsec
    IFV:gptp:000053-630857:domainIndex=0, clock_master_sync_receive:the master clock rate to 213483ppb, GMdiff=30nsec
    IFV:gptp:000053-755715:domainIndex=0, clock_master_sync_receive:the master clock rate to 213609ppb, GMdiff=83nsec
    IFV:gptp:000053-880722:domainIndex=0, clock_master_sync_receive:the master clock rate to 213585ppb, GMdiff=63nsec
    IFV:gptp:000054-005826:domainIndex=0, clock_master_sync_receive:the master clock rate to 213606ppb, GMdiff=66nsec
    IFV:gptp:000054-255688:domainIndex=0, clock_master_sync_receive:the master clock rate to 213630ppb, GMdiff=61nsec
    IFV:gptp:000054-380680:domainIndex=0, clock_master_sync_receive:the master clock rate to 213616ppb, GMdiff=48nsec
    IFV:gptp:000054-505675:domainIndex=0, clock_master_sync_receive:the master clock rate to 213628ppb, GMdiff=48nsec
    IFV:gptp:000054-630803:domainIndex=0, clock_master_sync_receive:the master clock rate to 213668ppb, GMdiff=61nsec
    IFV:gptp:000054-755660:domainIndex=0, clock_master_sync_receive:the master clock rate to 213591ppb, GMdiff=20nsec
    IFV:gptp:000054-880666:domainIndex=0, clock_master_sync_receive:the master clock rate to 213576ppb, GMdiff=11nsec
    IFV:gptp:000055-005846:domainIndex=0, clock_master_sync_receive:the master clock rate to 213607ppb, GMdiff=24nsec
         55. 78s : CPU load =   3.07 %
    IFV:gptp:000055-255633:domainIndex=0, clock_master_sync_receive:the master clock rate to 213490ppb, GMdiff=-33nsec
    IFV:gptp:000055-380628:domainIndex=0, clock_master_sync_receive:the master clock rate to 213518ppb, GMdiff=-17nsec
    IFV:gptp:000055-505761:domainIndex=0, clock_master_sync_receive:the master clock rate to 213632ppb, GMdiff=36nsec
    IFV:gptp:000055-630750:domainIndex=0, clock_master_sync_receive:the master clock rate to 213512ppb, GMdiff=-22nsec
    IFV:gptp:000055-755605:domainIndex=0, clock_master_sync_receive:the master clock rate to 213550ppb, GMdiff=-3nsec
    IFV:gptp:000056-005618:domainIndex=0, clock_master_sync_receive:the master clock rate to 213587ppb, GMdiff=19nsec
    IFV:gptp:000056-255580:domainIndex=0, clock_master_sync_receive:the master clock rate to 213533ppb, GMdiff=-6nsec
    IFV:gptp:000056-380573:domainIndex=0, clock_master_sync_receive:the master clock rate to 213574ppb, GMdiff=13nsec
    IFV:gptp:000056-505568:domainIndex=0, clock_master_sync_receive:the master clock rate to 213538ppb, GMdiff=-5nsec
    IFV:gptp:000056-630696:domainIndex=0, clock_master_sync_receive:the master clock rate to 213448ppb, GMdiff=-45nsec
    IFV:gptp:000056-755552:domainIndex=0, clock_master_sync_receive:the master clock rate to 213424ppb, GMdiff=-51nsec
    IFV:gptp:000056-880560:domainIndex=0, clock_master_sync_receive:the master clock rate to 213547ppb, GMdiff=10nsec
    IFV:gptp:000057-005540:domainIndex=0, clock_master_sync_receive:the master clock rate to 213512ppb, GMdiff=-7nsec
    IFV:gptp:000057-380628:domainIndex=0, clock_master_sync_receive:the master clock rate to 213532ppb, GMdiff=5nsec
    IFV:gptp:000057-505514:domainIndex=0, clock_master_sync_receive:the master clock rate to 213437ppb, GMdiff=-38nsec
    IFV:gptp:000057-630642:domainIndex=0, clock_master_sync_receive:the master clock rate to 213488ppb, GMdiff=-11nsec
    IFV:gptp:000057-755501:domainIndex=0, clock_master_sync_receive:the master clock rate to 213575ppb, GMdiff=29nsec
    IFV:gptp:000057-880619:domainIndex=0, clock_master_sync_receive:the master clock rate to 213563ppb, GMdiff=20nsec
    IFV:gptp:000058-005487:domainIndex=0, clock_master_sync_receive:the master clock rate to 213595ppb, GMdiff=32nsec
    IFV:gptp:000058-130479:domainIndex=0, clock_master_sync_receive:the master clock rate to 213542ppb, GMdiff=5nsec
    IFV:gptp:000058-255473:domainIndex=0, clock_master_sync_receive:the master clock rate to 213600ppb, GMdiff=31nsec
    IFV:gptp:000058-380468:domainIndex=0, clock_master_sync_receive:the master clock rate to 213446ppb, GMdiff=-41nsec
    IFV:gptp:000058-505461:domainIndex=0, clock_master_sync_receive:the master clock rate to 213494ppb, GMdiff=-15nsec
    IFV:gptp:000058-630588:domainIndex=0, clock_master_sync_receive:the master clock rate to 213543ppb, GMdiff=9nsec
    IFV:gptp:000058-755630:domainIndex=0, clock_master_sync_receive:the master clock rate to 213469ppb, GMdiff=-25nsec
    IFV:gptp:000058-880456:domainIndex=0, clock_master_sync_receive:the master clock rate to 213555ppb, GMdiff=16nsec
    IFV:gptp:000059-005434:domainIndex=0, clock_master_sync_receive:the master clock rate to 213583ppb, GMdiff=27nsec
    IFV:gptp:000059-130427:domainIndex=0, clock_master_sync_receive:the master clock rate to 213567ppb, GMdiff=17nsec
    IFV:gptp:000059-255420:domainIndex=0, clock_master_sync_receive:the master clock rate to 213593ppb, GMdiff=27nsec
    IFV:gptp:000059-380414:domainIndex=0, clock_master_sync_receive:the master clock rate to 213572ppb, GMdiff=15nsec
    IFV:gptp:000059-630536:domainIndex=0, clock_master_sync_receive:the master clock rate to 213618ppb, GMdiff=36nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000059-761995:domainIndex=0, clock_master_sync_receive:the master clock rate to 213498ppb, GMdiff=-22nsec
    IFV:gptp:000059-880399:domainIndex=0, clock_master_sync_receive:the master clock rate to 213555ppb, GMdiff=6nsec
         60. 79s : CPU load =   3.03 %
    domain=0, offset=0nsec, hw-adjrate=213555ppb
    IFV:gptp:000060-130510:domainIndex=0, clock_master_sync_receive:the master clock rate to 213598ppb, GMdiff=27nsec
    IFV:gptp:000060-255366:domainIndex=0, clock_master_sync_receive:the master clock rate to 213550ppb, GMdiff=3nsec
    IFV:gptp:000060-380361:domainIndex=0, clock_master_sync_receive:the master clock rate to 213500ppb, GMdiff=-20nsec
    IFV:gptp:000060-505353:domainIndex=0, clock_master_sync_receive:the master clock rate to 213451ppb, GMdiff=-40nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000060-630484:domainIndex=0, clock_master_sync_receive:the master clock rate to 213559ppb, GMdiff=13nsec
    IFV:gptp:000060-755343:domainIndex=0, clock_master_sync_receive:the master clock rate to 213439ppb, GMdiff=-42nsec
    IFV:gptp:000060-880347:domainIndex=0, clock_master_sync_receive:the master clock rate to 213450ppb, GMdiff=-32nsec
    IFV:gptp:000061-005442:domainIndex=0, clock_master_sync_receive:the master clock rate to 213582ppb, GMdiff=31nsec
    IFV:gptp:000061-255313:domainIndex=0, clock_master_sync_receive:the master clock rate to 213531ppb, GMdiff=1nsec
    IFV:gptp:000061-380374:domainIndex=0, clock_master_sync_receive:the master clock rate to 213583ppb, GMdiff=24nsec
    IFV:gptp:000061-505302:domainIndex=0, clock_master_sync_receive:the master clock rate to 213540ppb, GMdiff=2nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000061-755289:domainIndex=0, clock_master_sync_receive:the master clock rate to 213482ppb, GMdiff=-25nsec
    IFV:gptp:000061-880430:domainIndex=0, clock_master_sync_receive:the master clock rate to 213434ppb, GMdiff=-44nsec
    IFV:gptp:000062-005276:domainIndex=0, clock_master_sync_receive:the master clock rate to 213489ppb, GMdiff=-15nsec
    IFV:gptp:000062-255261:domainIndex=0, clock_master_sync_receive:the master clock rate to 213408ppb, GMdiff=-49nsec
    IFV:gptp:000062-380257:domainIndex=0, clock_master_sync_receive:the master clock rate to 213392ppb, GMdiff=-51nsec
    IFV:gptp:000062-505248:domainIndex=0, clock_master_sync_receive:the master clock rate to 213504ppb, GMdiff=5nsec
    IFV:gptp:000062-630377:domainIndex=0, clock_master_sync_receive:the master clock rate to 213471ppb, GMdiff=-11nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000062-755236:domainIndex=0, clock_master_sync_receive:the master clock rate to 213524ppb, GMdiff=14nsec
    IFV:gptp:000063-005223:domainIndex=0, clock_master_sync_receive:the master clock rate to 213554ppb, GMdiff=24nsec
    IFV:gptp:000063-130217:domainIndex=0, clock_master_sync_receive:the master clock rate to 213412ppb, GMdiff=-42nsec
    IFV:gptp:000063-255211:domainIndex=0, clock_master_sync_receive:the master clock rate to 213558ppb, GMdiff=28nsec
    IFV:gptp:000063-380202:domainIndex=0, clock_master_sync_receive:the master clock rate to 213498ppb, GMdiff=-2nsec
    IFV:gptp:000063-505195:domainIndex=0, clock_master_sync_receive:the master clock rate to 213461ppb, GMdiff=-19nsec
    IFV:gptp:000063-755182:domainIndex=0, clock_master_sync_receive:the master clock rate to 213479ppb, GMdiff=-3nsec
    IFV:gptp:000063-880210:domainIndex=0, clock_master_sync_receive:the master clock rate to 213444ppb, GMdiff=-19nsec
    IFV:gptp:000064-005169:domainIndex=0, clock_master_sync_receive:the master clock rate to 213462ppb, GMdiff=-9nsec
    IFV:gptp:000064-130163:domainIndex=0, clock_master_sync_receive:the master clock rate to 213534ppb, GMdiff=24nsec
    IFV:gptp:000064-255156:domainIndex=0, clock_master_sync_receive:the master clock rate to 213554ppb, GMdiff=31nsec
    IFV:gptp:000064-505320:domainIndex=0, clock_master_sync_receive:the master clock rate to 213570ppb, GMdiff=30nsec
    IFV:gptp:000064-630271:domainIndex=0, clock_master_sync_receive:the master clock rate to 213524ppb, GMdiff=6nsec
    IFV:gptp:000064-755130:domainIndex=0, clock_master_sync_receive:the master clock rate to 213481ppb, GMdiff=-14nsec
    IFV:gptp:000064-880179:domainIndex=0, clock_master_sync_receive:the master clock rate to 213580ppb, GMdiff=32nsec
         65. 80s : CPU load =   3.08 %
    IFV:gptp:000065-130152:domainIndex=0, clock_master_sync_receive:the master clock rate to 213531ppb, GMdiff=0nsec
    IFV:gptp:000065-255101:domainIndex=0, clock_master_sync_receive:the master clock rate to 213589ppb, GMdiff=26nsec
    IFV:gptp:000065-380160:domainIndex=0, clock_master_sync_receive:the master clock rate to 213529ppb, GMdiff=-4nsec
    IFV:gptp:000065-505098:domainIndex=0, clock_master_sync_receive:the master clock rate to 213504ppb, GMdiff=-15nsec
    IFV:gptp:000065-630220:domainIndex=0, clock_master_sync_receive:the master clock rate to 213627ppb, GMdiff=42nsec
    IFV:gptp:000065-755077:domainIndex=0, clock_master_sync_receive:the master clock rate to 213563ppb, GMdiff=9nsec
    IFV:gptp:000065-880252:domainIndex=0, clock_master_sync_receive:the master clock rate to 213479ppb, GMdiff=-30nsec
    IFV:gptp:000066-005084:domainIndex=0, clock_master_sync_receive:the master clock rate to 213575ppb, GMdiff=16nsec
    IFV:gptp:000066-130057:domainIndex=0, clock_master_sync_receive:the master clock rate to 213628ppb, GMdiff=38nsec
    IFV:gptp:000066-255050:domainIndex=0, clock_master_sync_receive:the master clock rate to 213495ppb, GMdiff=-26nsec
    IFV:gptp:000066-380187:domainIndex=0, clock_master_sync_receive:the master clock rate to 213624ppb, GMdiff=35nsec
    IFV:gptp:000066-505036:domainIndex=0, clock_master_sync_receive:the master clock rate to 213594ppb, GMdiff=18nsec
    IFV:gptp:000066-630187:domainIndex=0, clock_master_sync_receive:the master clock rate to 213583ppb, GMdiff=11nsec
    IFV:gptp:000066-755021:domainIndex=0, clock_master_sync_receive:the master clock rate to 213570ppb, GMdiff=4nsec
    IFV:gptp:000066-880121:domainIndex=0, clock_master_sync_receive:the master clock rate to 213467ppb, GMdiff=-43nsec
    IFV:gptp:000067-005009:domainIndex=0, clock_master_sync_receive:the master clock rate to 213577ppb, GMdiff=11nsec
    IFV:gptp:000067-130005:domainIndex=0, clock_master_sync_receive:the master clock rate to 213486ppb, GMdiff=-31nsec
    IFV:gptp:000067-254992:domainIndex=0, clock_master_sync_receive:the master clock rate to 213585ppb, GMdiff=17nsec
    IFV:gptp:000067-379985:domainIndex=0, clock_master_sync_receive:the master clock rate to 213564ppb, GMdiff=6nsec
    IFV:gptp:000067-504981:domainIndex=0, clock_master_sync_receive:the master clock rate to 213517ppb, GMdiff=-16nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    IFV:gptp:000067-630112:domainIndex=0, clock_master_sync_receive:the master clock rate to 213557ppb, GMdiff=4nsec
    IFV:gptp:000067-754965:domainIndex=0, clock_master_sync_receive:the master clock rate to 213571ppb, GMdiff=10nsec
    IFV:gptp:000067-880021:domainIndex=0, clock_master_sync_receive:the master clock rate to 213624ppb, GMdiff=33nsec
    IFV:gptp:000068-004953:domainIndex=0, clock_master_sync_receive:the master clock rate to 213693ppb, GMdiff=60nsec
    IFV:gptp:000068-129991:domainIndex=0, clock_master_sync_receive:the master clock rate to 213554ppb, GMdiff=-9nsec
    IFV:gptp:000068-255086:domainIndex=0, clock_master_sync_receive:the master clock rate to 213600ppb, GMdiff=13nsec
    IFV:gptp:000068-379975:domainIndex=0, clock_master_sync_receive:the master clock rate to 213641ppb, GMdiff=30nsec
    IFV:gptp:000068-504925:domainIndex=0, clock_master_sync_receive:the master clock rate to 213579ppb, GMdiff=-1nsec
    IFV:gptp:000068-630060:domainIndex=0, clock_master_sync_receive:the master clock rate to 213647ppb, GMdiff=30nsec
    IFV:gptp:000068-879964:domainIndex=0, clock_master_sync_receive:the master clock rate to 213512ppb, GMdiff=-35nsec
    IFV:gptp:000069-004900:domainIndex=0, clock_master_sync_receive:the master clock rate to 213535ppb, GMdiff=-21nsec
    IFV:gptp:000069-129935:domainIndex=0, clock_master_sync_receive:the master clock rate to 213648ppb, GMdiff=32nsec
    IFV:gptp:000069-254888:domainIndex=0, clock_master_sync_receive:the master clock rate to 213535ppb, GMdiff=-22nsec
    IFV:gptp:000069-379922:domainIndex=0, clock_master_sync_receive:the master clock rate to 213567ppb, GMdiff=-5nsec
    IFV:gptp:000069-504874:domainIndex=0, clock_master_sync_receive:the master clock rate to 213610ppb, GMdiff=15nsec
    IFV:gptp:000069-754860:domainIndex=0, clock_master_sync_receive:the master clock rate to 213523ppb, GMdiff=-30nsec
    IFV:gptp:000070-004846:domainIndex=0, clock_master_sync_receive:the master clock rate to 213594ppb, GMdiff=12nsec
         70. 81s : CPU load =   3.10 %
    domain=0, offset=0nsec, hw-adjrate=213594ppb
    IFV:gptp:000070-129945:domainIndex=0, clock_master_sync_receive:the master clock rate to 213627ppb, GMdiff=26nsec
    IFV:gptp:000070-254835:domainIndex=0, clock_master_sync_receive:the master clock rate to 213506ppb, GMdiff=-31nsec
    IFV:gptp:000070-379870:domainIndex=0, clock_master_sync_receive:the master clock rate to 213625ppb, GMdiff=26nsec
    IFV:gptp:000070-504820:domainIndex=0, clock_master_sync_receive:the master clock rate to 213593ppb, GMdiff=9nsec
    IFV:gptp:000070-629948:domainIndex=0, clock_master_sync_receive:the master clock rate to 213623ppb, GMdiff=22nsec
    IFV:gptp:000070-754806:domainIndex=0, clock_master_sync_receive:the master clock rate to 213606ppb, GMdiff=12nsec
    IFV:gptp:000070-879935:domainIndex=0, clock_master_sync_receive:the master clock rate to 213664ppb, GMdiff=37nsec
    IFV:gptp:000071-004794:domainIndex=0, clock_master_sync_receive:the master clock rate to 213516ppb, GMdiff=-33nsec
    IFV:gptp:000071-129829:domainIndex=0, clock_master_sync_receive:the master clock rate to 213608ppb, GMdiff=12nsec
    IFV:gptp:000071-754753:domainIndex=0, clock_master_sync_receive:the master clock rate to 213693ppb, GMdiff=46nsec
    IFV:gptp:000072-004740:domainIndex=0, clock_master_sync_receive:the master clock rate to 213598ppb, GMdiff=-6nsec
    IFV:gptp:000072-129920:domainIndex=0, clock_master_sync_receive:the master clock rate to 213656ppb, GMdiff=21nsec
    IFV:gptp:000072-254727:domainIndex=0, clock_master_sync_receive:the master clock rate to 213688ppb, GMdiff=33nsec
    IFV:gptp:000072-379763:domainIndex=0, clock_master_sync_receive:the master clock rate to 213659ppb, GMdiff=16nsec
    IFV:gptp:000072-504714:domainIndex=0, clock_master_sync_receive:the master clock rate to 213712ppb, GMdiff=38nsec
    IFV:gptp:000072-629841:domainIndex=0, clock_master_sync_receive:the master clock rate to 213664ppb, GMdiff=12nsec
    IFV:gptp:000072-754699:domainIndex=0, clock_master_sync_receive:the master clock rate to 213638ppb, GMdiff=-1nsec
    IFV:gptp:000072-879752:domainIndex=0, clock_master_sync_receive:the master clock rate to 213594ppb, GMdiff=-21nsec
    IFV:gptp:000073-004812:domainIndex=0, clock_master_sync_receive:the master clock rate to 213627ppb, GMdiff=-4nsec
    IFV:gptp:000073-129723:domainIndex=0, clock_master_sync_receive:the master clock rate to 213594ppb, GMdiff=-19nsec
    IFV:gptp:000073-254672:domainIndex=0, clock_master_sync_receive:the master clock rate to 213641ppb, GMdiff=4nsec
    IFV:gptp:000073-379709:domainIndex=0, clock_master_sync_receive:the master clock rate to 213598ppb, GMdiff=-16nsec
    IFV:gptp:000073-504660:domainIndex=0, clock_master_sync_receive:the master clock rate to 213610ppb, GMdiff=-9nsec
    IFV:gptp:000073-629789:domainIndex=0, clock_master_sync_receive:the master clock rate to 213503ppb, GMdiff=-56nsec
    EnetPer_ioctl:1379
    Enet_ioctl:1042
    log ovflow!
    domainIndex=0, clock_master_sync_receive:the master clock rate to 211787ppb, GMdiff=-812nsec
    IFV:gptp:000073-879692:domainIndex=0, clock_master_sync_receive:the master clock rate to 212252ppb, GMdiff=-731nsec
    IFV:gptp:000074-004628:domainIndex=0, clock_master_sync_receive:the master clock rate to 212152ppb, GMdiff=-721nsec
    IFV:gptp:000074-129665:domainIndex=0, clock_master_sync_receive:the master clock rate to 212491ppb, GMdiff=-658nsec
    IFV:gptp:000074-254616:domainIndex=0, clock_master_sync_receive:the master clock rate to 212805ppb, GMdiff=-600nsec
    IFV:gptp:000074-379651:domainIndex=0, clock_master_sync_receive:the master clock rate to 212655ppb, GMdiff=-600nsec
    IFV:gptp:000074-504602:domainIndex=0, clock_master_sync_receive:the master clock rate to 212877ppb, GMdiff=-555nsec
    IFV:gptp:000074-629730:domainIndex=0, clock_master_sync_receive:the master clock rate to 213134ppb, GMdiff=-507nsec
    IFV:gptp:000074-754590:domainIndex=0, clock_master_sync_receive:the master clock rate to 219233ppb, GMdiff=247nsec
    IFV:gptp:000074-879642:domainIndex=0, clock_master_sync_receive:the master clock rate to 217926ppb, GMdiff=81nsec
    IFV:gptp:000075-004580:domainIndex=0, clock_master_sync_receive:the master clock rate to 216726ppb, GMdiff=-67nsec
         75. 82s : CPU load =   3.06 %
    IFV:gptp:000075-129615:domainIndex=0, clock_master_sync_receive:the master clock rate to 216026ppb, GMdiff=-150nsec
    IFV:gptp:000075-254566:domainIndex=0, clock_master_sync_receive:the master clock rate to 215230ppb, GMdiff=-242nsec
    IFV:gptp:000075-379603:domainIndex=0, clock_master_sync_receive:the master clock rate to 214841ppb, GMdiff=-282nsec
    IFV:gptp:000075-504552:domainIndex=0, clock_master_sync_receive:the master clock rate to 214334ppb, GMdiff=-335nsec
    IFV:gptp:000075-629883:domainIndex=0, clock_master_sync_receive:the master clock rate to 213930ppb, GMdiff=-374nsec
    IFV:gptp:000075-754540:domainIndex=0, clock_master_sync_receive:the master clock rate to 213614ppb, GMdiff=-401nsec
    IFV:gptp:000075-879590:domainIndex=0, clock_master_sync_receive:the master clock rate to 214091ppb, GMdiff=-331nsec
    IFV:gptp:000076-004526:domainIndex=0, clock_master_sync_receive:the master clock rate to 213637ppb, GMdiff=-376nsec
    IFV:gptp:000076-129561:domainIndex=0, clock_master_sync_receive:the master clock rate to 213520ppb, GMdiff=-379nsec
    IFV:gptp:000076-254512:domainIndex=0, clock_master_sync_receive:the master clock rate to 213442ppb, GMdiff=-377nsec
    IFV:gptp:000076-379549:domainIndex=0, clock_master_sync_receive:the master clock rate to 213044ppb, GMdiff=-414nsec
    IFV:gptp:000076-504699:domainIndex=0, clock_master_sync_receive:the master clock rate to 213055ppb, GMdiff=-400nsec
    IFV:gptp:000076-629627:domainIndex=0, clock_master_sync_receive:the master clock rate to 213425ppb, GMdiff=-343nsec
    IFV:gptp:000076-754485:domainIndex=0, clock_master_sync_receive:the master clock rate to 213150ppb, GMdiff=-366nsec
    IFV:gptp:000076-879536:domainIndex=0, clock_master_sync_receive:the master clock rate to 213215ppb, GMdiff=-347nsec
    IFV:gptp:000077-004472:domainIndex=0, clock_master_sync_receive:the master clock rate to 213269ppb, GMdiff=-330nsec
    IFV:gptp:000077-129509:domainIndex=0, clock_master_sync_receive:the master clock rate to 213122ppb, GMdiff=-338nsec
    IFV:gptp:000077-254460:domainIndex=0, clock_master_sync_receive:the master clock rate to 213582ppb, GMdiff=-272nsec
    IFV:gptp:000077-379672:domainIndex=0, clock_master_sync_receive:the master clock rate to 213441ppb, GMdiff=-281nsec
    IFV:gptp:000077-504488:domainIndex=0, clock_master_sync_receive:the master clock rate to 213528ppb, GMdiff=-262nsec
    IFV:gptp:000077-629574:domainIndex=0, clock_master_sync_receive:the master clock rate to 213348ppb, GMdiff=-276nsec
    IFV:gptp:000077-754432:domainIndex=0, clock_master_sync_receive:the master clock rate to 213576ppb, GMdiff=-240nsec
    IFV:gptp:000077-879483:domainIndex=0, clock_master_sync_receive:the master clock rate to 213336ppb, GMdiff=-262nsec
    IFV:gptp:000078-004419:domainIndex=0, clock_master_sync_receive:the master clock rate to 213535ppb, GMdiff=-230nsec
    IFV:gptp:000078-129454:domainIndex=0, clock_master_sync_receive:the master clock rate to 212992ppb, GMdiff=-289nsec
    IFV:gptp:000078-254404:domainIndex=0, clock_master_sync_receive:the master clock rate to 213242ppb, GMdiff=-250nsec
    IFV:gptp:000078-379587:domainIndex=0, clock_master_sync_receive:the master clock rate to 213261ppb, GMdiff=-240nsec
    IFV:gptp:000078-504392:domainIndex=0, clock_master_sync_receive:the master clock rate to 213218ppb, GMdiff=-238nsec
    IFV:gptp:000078-629520:domainIndex=0, clock_master_sync_receive:the master clock rate to 213537ppb, GMdiff=-192nsec
    IFV:gptp:000078-754378:domainIndex=0, clock_master_sync_receive:the master clock rate to 213465ppb, GMdiff=-195nsec
    IFV:gptp:000078-879429:domainIndex=0, clock_master_sync_receive:the master clock rate to 213335ppb, GMdiff=-205nsec
    IFV:gptp:000079-004366:domainIndex=0, clock_master_sync_receive:the master clock rate to 213053ppb, GMdiff=-233nsec
    IFV:gptp:000079-129402:domainIndex=0, clock_master_sync_receive:the master clock rate to 213580ppb, GMdiff=-162nsec
    IFV:gptp:000079-254350:domainIndex=0, clock_master_sync_receive:the master clock rate to 213078ppb, GMdiff=-218nsec
    IFV:gptp:000079-379389:domainIndex=0, clock_master_sync_receive:the master clock rate to 213345ppb, GMdiff=-179nsec
    IFV:gptp:000079-504340:domainIndex=0, clock_master_sync_receive:the master clock rate to 213136ppb, GMdiff=-199nsec
    IFV:gptp:000079-629579:domainIndex=0, clock_master_sync_receive:the master clock rate to 213234ppb, GMdiff=-181nsec
    IFV:gptp:000079-754346:domainIndex=0, clock_master_sync_receive:the master clock rate to 213470ppb, GMdiff=-147nsec
    IFV:gptp:000079-879376:domainIndex=0, clock_master_sync_receive:the master clock rate to 213515ppb, GMdiff=-137nsec
    IFV:gptp:000080-004315:domainIndex=0, clock_master_sync_receive:the master clock rate to 213432ppb, GMdiff=-143nsec
         80. 83s : CPU load =   3.13 %
    domain=0, offset=0nsec, hw-adjrate=213432ppb
    IFV:gptp:000080-129424:domainIndex=0, clock_master_sync_receive:the master clock rate to 213561ppb, GMdiff=-123nsec
    IFV:gptp:000080-254300:domainIndex=0, clock_master_sync_receive:the master clock rate to 213366ppb, GMdiff=-143nsec
    IFV:gptp:000080-379342:domainIndex=0, clock_master_sync_receive:the master clock rate to 213470ppb, GMdiff=-126nsec
    IFV:gptp:000080-504375:domainIndex=0, clock_master_sync_receive:the master clock rate to 213563ppb, GMdiff=-111nsec
    IFV:gptp:000080-629458:domainIndex=0, clock_master_sync_receive:the master clock rate to 213314ppb, GMdiff=-138nsec
    IFV:gptp:000080-754293:domainIndex=0, clock_master_sync_receive:the master clock rate to 213552ppb, GMdiff=-105nsec
    IFV:gptp:000080-879322:domainIndex=0, clock_master_sync_receive:the master clock rate to 213748ppb, GMdiff=-78nsec
    IFV:gptp:000081-004413:domainIndex=0, clock_master_sync_receive:the master clock rate to 213466ppb, GMdiff=-110nsec
    IFV:gptp:000081-129298:domainIndex=0, clock_master_sync_receive:the master clock rate to 213125ppb, GMdiff=-148nsec
    IFV:gptp:000081-254246:domainIndex=0, clock_master_sync_receive:the master clock rate to 213501ppb, GMdiff=-98nsec
    IFV:gptp:000081-379303:domainIndex=0, clock_master_sync_receive:the master clock rate to 213484ppb, GMdiff=-97nsec
    IFV:gptp:000081-504360:domainIndex=0, clock_master_sync_receive:the master clock rate to 213698ppb, GMdiff=-68nsec
    IFV:gptp:000081-629361:domainIndex=0, clock_master_sync_receive:the master clock rate to 213418ppb, GMdiff=-100nsec
    IFV:gptp:000081-754220:domainIndex=0, clock_master_sync_receive:the master clock rate to 213072ppb, GMdiff=-139nsec
    IFV:gptp:000081-879316:domainIndex=0, clock_master_sync_receive:the master clock rate to 212857ppb, GMdiff=-161nsec
    IFV:gptp:000082-004230:domainIndex=0, clock_master_sync_receive:the master clock rate to 213362ppb, GMdiff=-95nsec
    IFV:gptp:000082-129243:domainIndex=0, clock_master_sync_receive:the master clock rate to 213257ppb, GMdiff=-105nsec
    IFV:gptp:000082-254284:domainIndex=0, clock_master_sync_receive:the master clock rate to 213314ppb, GMdiff=-95nsec
    INF:gptp:000082-379172:domainIndex=0, clock_master_sync_receive:stable rate
    IFV:gptp:000082-379295:domainIndex=0, clock_master_sync_receive:the master clock rate to 213339ppb, GMdiff=-89nsec
    IFV:gptp:000082-504183:domainIndex=0, clock_master_sync_receive:the master clock rate to 213389ppb, GMdiff=-57nsec
    IFV:gptp:000082-629309:domainIndex=0, clock_master_sync_receive:the master clock rate to 213241ppb, GMdiff=-117nsec
    IFV:gptp:000082-754169:domainIndex=0, clock_master_sync_receive:the master clock rate to 213385ppb, GMdiff=-40nsec
    IFV:gptp:000082-879240:domainIndex=0, clock_master_sync_receive:the master clock rate to 213325ppb, GMdiff=-63nsec
    IFV:gptp:000083-004155:domainIndex=0, clock_master_sync_receive:the master clock rate to 213471ppb, GMdiff=9nsec
    IFV:gptp:000083-129192:domainIndex=0, clock_master_sync_receive:the master clock rate to 213434ppb, GMdiff=-9nsec
    IFV:gptp:000083-254142:domainIndex=0, clock_master_sync_receive:the master clock rate to 213387ppb, GMdiff=-29nsec
    IFV:gptp:000083-379177:domainIndex=0, clock_master_sync_receive:the master clock rate to 213464ppb, GMdiff=9nsec
    IFV:gptp:000083-504149:domainIndex=0, clock_master_sync_receive:the master clock rate to 213392ppb, GMdiff=-24nsec
    IFV:gptp:000083-629300:domainIndex=0, clock_master_sync_receive:the master clock rate to 213497ppb, GMdiff=26nsec
    IFV:gptp:000083-754115:domainIndex=0, clock_master_sync_receive:the master clock rate to 213445ppb, GMdiff=0nsec
    IFV:gptp:000083-879168:domainIndex=0, clock_master_sync_receive:the master clock rate to 213381ppb, GMdiff=-29nsec
    IFV:gptp:000084-004101:domainIndex=0, clock_master_sync_receive:the master clock rate to 213459ppb, GMdiff=9nsec
    IFV:gptp:000084-129160:domainIndex=0, clock_master_sync_receive:the master clock rate to 213503ppb, GMdiff=28nsec
    IFV:gptp:000084-254087:domainIndex=0, clock_master_sync_receive:the master clock rate to 213387ppb, GMdiff=-27nsec
    IFV:gptp:000084-379126:domainIndex=0, clock_master_sync_receive:the master clock rate to 213536ppb, GMdiff=43nsec
    IFV:gptp:000084-504076:domainIndex=0, clock_master_sync_receive:the master clock rate to 213486ppb, GMdiff=16nsec
    IFV:gptp:000084-629249:domainIndex=0, clock_master_sync_receive:the master clock rate to 213417ppb, GMdiff=-17nsec
    IFV:gptp:000084-754083:domainIndex=0, clock_master_sync_receive:the master clock rate to 213502ppb, GMdiff=23nsec
    IFV:gptp:000084-879112:domainIndex=0, clock_master_sync_receive:the master clock rate to 213446ppb, GMdiff=-5nsec
    IFV:gptp:000085-004048:domainIndex=0, clock_master_sync_receive:the master clock rate to 213429ppb, GMdiff=-12nsec
         85. 84s : CPU load =   3.13 %
    IFV:gptp:000085-129085:domainIndex=0, clock_master_sync_receive:the master clock rate to 213479ppb, GMdiff=12nsec
    IFV:gptp:000085-254036:domainIndex=0, clock_master_sync_receive:the master clock rate to 213542ppb, GMdiff=39nsec
    IFV:gptp:000085-379092:domainIndex=0, clock_master_sync_receive:the master clock rate to 213577ppb, GMdiff=51nsec
    IFV:gptp:000085-504022:domainIndex=0, clock_master_sync_receive:the master clock rate to 213481ppb, GMdiff=3nsec
    IFV:gptp:000085-629194:domainIndex=0, clock_master_sync_receive:the master clock rate to 213577ppb, GMdiff=46nsec
    IFV:gptp:000085-754007:domainIndex=0, clock_master_sync_receive:the master clock rate to 213656ppb, GMdiff=76nsec
    IFV:gptp:000085-879017:domainIndex=0, clock_master_sync_receive:the master clock rate to 213705ppb, GMdiff=90nsec
    IFV:gptp:000086-128986:domainIndex=0, clock_master_sync_receive:the master clock rate to 213746ppb, GMdiff=86nsec
    IFV:gptp:000086-253978:domainIndex=0, clock_master_sync_receive:the master clock rate to 213731ppb, GMdiff=70nsec
    IFV:gptp:000086-378973:domainIndex=0, clock_master_sync_receive:the master clock rate to 213659ppb, GMdiff=30nsec
    IFV:gptp:000086-503965:domainIndex=0, clock_master_sync_receive:the master clock rate to 213754ppb, GMdiff=69nsec
    IFV:gptp:000086-629098:domainIndex=0, clock_master_sync_receive:the master clock rate to 213738ppb, GMdiff=54nsec
    IFV:gptp:000086-753951:domainIndex=0, clock_master_sync_receive:the master clock rate to 213641ppb, GMdiff=5nsec
    IFV:gptp:000086-878959:domainIndex=0, clock_master_sync_receive:the master clock rate to 213765ppb, GMdiff=60nsec
    IFV:gptp:000087-003939:domainIndex=0, clock_master_sync_receive:the master clock rate to 213737ppb, GMdiff=41nsec
    IFV:gptp:000087-128931:domainIndex=0, clock_master_sync_receive:the master clock rate to 213711ppb, GMdiff=25nsec
    IFV:gptp:000087-253925:domainIndex=0, clock_master_sync_receive:the master clock rate to 213648ppb, GMdiff=-6nsec
    IFV:gptp:000087-378918:domainIndex=0, clock_master_sync_receive:the master clock rate to 213610ppb, GMdiff=-23nsec
    IFV:gptp:000087-503913:domainIndex=0, clock_master_sync_receive:the master clock rate to 213749ppb, GMdiff=42nsec
    IFV:gptp:000087-629044:domainIndex=0, clock_master_sync_receive:the master clock rate to 213610ppb, GMdiff=-25nsec
    IFV:gptp:000087-753899:domainIndex=0, clock_master_sync_receive:the master clock rate to 213716ppb, GMdiff=25nsec
    IFV:gptp:000087-878904:domainIndex=0, clock_master_sync_receive:the master clock rate to 213663ppb, GMdiff=-2nsec
    IFV:gptp:000088-003885:domainIndex=0, clock_master_sync_receive:the master clock rate to 213698ppb, GMdiff=14nsec
    IFV:gptp:000088-128878:domainIndex=0, clock_master_sync_receive:the master clock rate to 213641ppb, GMdiff=-13nsec
    IFV:gptp:000088-253873:domainIndex=0, clock_master_sync_receive:the master clock rate to 213680ppb, GMdiff=6nsec
    IFV:gptp:000088-378865:domainIndex=0, clock_master_sync_receive:the master clock rate to 213624ppb, GMdiff=-20nsec
    IFV:gptp:000088-503858:domainIndex=0, clock_master_sync_receive:the master clock rate to 213645ppb, GMdiff=-8nsec
    IFV:gptp:000088-628988:domainIndex=0, clock_master_sync_receive:the master clock rate to 213554ppb, GMdiff=-48nsec
    IFV:gptp:000088-753844:domainIndex=0, clock_master_sync_receive:the master clock rate to 213690ppb, GMdiff=18nsec
    IFV:gptp:000088-878852:domainIndex=0, clock_master_sync_receive:the master clock rate to 213653ppb, GMdiff=-1nsec
    IFV:gptp:000089-003832:domainIndex=0, clock_master_sync_receive:the master clock rate to 213670ppb, GMdiff=7nsec
    IFV:gptp:000089-128825:domainIndex=0, clock_master_sync_receive:the master clock rate to 213580ppb, GMdiff=-34nsec
    IFV:gptp:000089-253820:domainIndex=0, clock_master_sync_receive:the master clock rate to 213567ppb, GMdiff=-36nsec
    IFV:gptp:000089-503805:domainIndex=0, clock_master_sync_receive:the master clock rate to 213624ppb, GMdiff=-1nsec
    IFV:gptp:000089-628933:domainIndex=0, clock_master_sync_receive:the master clock rate to 213585ppb, GMdiff=-19nsec
    IFV:gptp:000089-753793:domainIndex=0, clock_master_sync_receive:the master clock rate to 213412ppb, GMdiff=-94nsec
    IFV:gptp:000089-878799:domainIndex=0, clock_master_sync_receive:the master clock rate to 213491ppb, GMdiff=-48nsec
         90. 85s : CPU load =   3.08 %
    domain=0, offset=0nsec, hw-adjrate=213491ppb
            gmsync=true, last_setts64=0nsec
    IFV:gptp:000090-128771:domainIndex=0, clock_master_sync_receive:the master clock rate to 213545ppb, GMdiff=-18nsec
    IFV:gptp:000090-253765:domainIndex=0, clock_master_sync_receive:the master clock rate to 213492ppb, GMdiff=-40nsec
    IFV:gptp:000090-378758:domainIndex=0, clock_master_sync_receive:the master clock rate to 213456ppb, GMdiff=-52nsec
    IFV:gptp:000090-503751:domainIndex=0, clock_master_sync_receive:the master clock rate to 213393ppb, GMdiff=-75nsec
    IFV:gptp:000090-628883:domainIndex=0, clock_master_sync_receive:the master clock rate to 213500ppb, GMdiff=-19nsec
    IFV:gptp:000090-878744:domainIndex=0, clock_master_sync_receive:the master clock rate to 213448ppb, GMdiff=-37nsec
    I
    The reason why we are having the failure is because the TSN stack is requesting the hardware for timestamp even before hardware was able to push it out to buffer due to high throughput. To handle this, a crude way to test it is by adding delay in the stack before requesting the timestamp. A better way to implement is to add a polling logic to fetch the timestamp instead of exiting at first try.
    We are working on finalising the approach to fix this issue. We are able to root cause it, and we are working with our stack team to fix it.
    Thanks and regards,
    Teja.
