AM2434: lwip-builds with #define LWIP_NOASSERT fails
Part Number: AM2434
for our release-build we do not want to set the asserts. so we defined LWIP_NOASSERT in the lwipopts.h.
We are using Industrial Comms 11 with the latest release. But now the -Werror compile option in the TI make-scripts produces this:
error: unused variable 'anyVariableUsedOnlyInAssertCall'
for every variable that is only created to be used in an assert.
I think this should be fixed.
Best regards
Felix
  • Hi Felix,
    Ideally, the variables which are used within the context of LwIP for error handling only should be used with the macro 'LWIP_UNUSED_ARG()' to handle this gracefully. This has been done in the sample example of lwip stack, and also in the examples available in MCU+ SDK.
    Can you please share whether you are observing these errors while building the libraries or while building the examples? I will check this internally as well, and let you know my results. If the errors are seen, I will take this feedback to the internal team to handle the errors in the SDK.
    Thanks and regards,
    Teja.
  • Hey Teja,
    sorry for the late reply:
    This happens when building the libraries. The message also makes sense if you check the code.
    To reproduce: set the LWIP_NOASSERT in the used lwipopts.h header file:
    and when compiling you will get the error:
    If you look into the related code, you can see that this variable is only used for the assert, but without the mentioned LWIP_UNUSED_ARG():
    And if LWIP_NOASSERT is set, the LWIP_ASSERT-call will translate to:
    which does not use the variable.
    This happens to some more places in the code.
    best regards
    Felix
  • Hi Felix,
    We are able to reproduce the issue, and looking into possible causes of this occurrence. This seems to be a LwIP stack related issue, where the corresponding errors are not handled in the public release itself. Please let me confirm if that is the case.
    As a solution, you would be able to modify the lwip_assert declaration such that it will not take much additional cycles, and use the condition given as input.
    Thanks and regards,
    Teja.
