MSPM0G5117: File Loader: Memory write failed: Timed out waiting for target to halt
Part Number: MSPM0G5117
Hi Team,
can you please help on the topic below - I pointed already to BSL enable:
We're working actively on MSPM0G5117SRGER and we're facing this problem:
  • Currently pin PA18, as stated in the demo board docs, will activate BSL at boot;
  • In our application, PA18 is connected to an application-related signal (in our case a normally high signal)
  • This is causing BSL invocation if we do not change manually that signal.
we found settings for NVM Configuration in Sysconfig to change BSL behavior but every change she makes will cause a flash error:
"File Loader: Memory write failed: Timed out waiting for target to halt"
Is there any advice on that topic, or do you think we're doing something wrong?
Thank you for your advice with BSL enable, unfortunately I already tried to disable the BSL from the sysconfig but the error mentioned by my colleage still shows up:
Is there anything else we can try?
