Please find below the contents of git patch files resulting from troubleshooting in SDK for am263x and am263px during on-site support. I have submitted patch file content rather than patch files in this post because the E2E forum does not support uploading files with the .patch extension.
The 3 defects discovered were:
1. Instruction re-ordering w.r.t kick register on higher optimization levels (-O2 and -O3) when manipulating TOP_RCM, TOP_MSS, TOP_CTRL, and MSS_CTRL.
2. DPL Log processing starvation with shared reader (reader unable to yield meant watchdog timeouts when producer throughput exceeds consumer)
3. DPL Shared memory log writer unable to disable line prelude (this makes creating structured logs impossible)
Patch1. 0001-rcm-add-volatile-to-fix-instruction-re-ordering-bug-.patch
From 91225c9d2fd8e6517745572fe42d16209821d8c8 Mon Sep 17 00:00:00 2001
Date: Tue, 9 Dec 2025 10:36:14 -0600
Subject: [PATCH] [rcm] add volatile to fix instruction re-ordering bug on -O2
source/drivers/soc/am263px/soc_rcm.c | 34 +++++++++++++-------------
source/drivers/soc/am263x/soc_rcm.c | 36 ++++++++++++++--------------
2 files changed, 35 insertions(+), 35 deletions(-)
diff --git a/source/drivers/soc/am263px/soc_rcm.c b/source/drivers/soc/am263px/soc_rcm.c
index e2e5f67807..0fb7503059 100644
--- a/source/drivers/soc/am263px/soc_rcm.c
+++ b/source/drivers/soc/am263px/soc_rcm.c
@@ -195,7 +195,7 @@ const SOC_RcmClkSrcInfo gCLKOUTClkSrcInfoMap =
* @details
* Mapping Array between Clock mode and Clock Mode Value for MCAN
-static uint16_t gMcanClkSrcValMap[] =
+static const uint16_t gMcanClkSrcValMap[] =
[SOC_RcmPeripheralClockSource_XTALCLK] = 0x666U,
[SOC_RcmPeripheralClockSource_SYS_CLK] = 0x222U,
@@ -218,7 +218,7 @@ static uint16_t gMcanClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for OSPI
-static uint16_t gOspiClkSrcValMap[] =
+static const uint16_t gOspiClkSrcValMap[] =
@@ -241,7 +241,7 @@ static uint16_t gOspiClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for RTI
-static uint16_t gRtiClkSrcValMap[] =
+static const uint16_t gRtiClkSrcValMap[] =
@@ -264,7 +264,7 @@ static uint16_t gRtiClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for WDT
-static uint16_t gWdtClkSrcValMap[] =
+static const uint16_t gWdtClkSrcValMap[] =
@@ -287,7 +287,7 @@ static uint16_t gWdtClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for McSPI
-static uint16_t gMcSpiClkSrcValMap[] =
+static const uint16_t gMcSpiClkSrcValMap[] =
@@ -310,7 +310,7 @@ static uint16_t gMcSpiClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for MMC
-static uint16_t gMmcClkSrcValMap[] =
+static const uint16_t gMmcClkSrcValMap[] =
@@ -333,7 +333,7 @@ static uint16_t gMmcClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for ICSSM UART
-static uint16_t gIcssmUartClkSrcValMap[] =
+static const uint16_t gIcssmUartClkSrcValMap[] =
@@ -356,7 +356,7 @@ static uint16_t gIcssmUartClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for CPTS
-static uint16_t gCptsClkSrcValMap[] =
+static const uint16_t gCptsClkSrcValMap[] =
@@ -402,7 +402,7 @@ static uint16_t gCptsClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for ControlSS PLL
-static uint16_t gControlssPllClkSrcValMap[] =
+static const uint16_t gControlssPllClkSrcValMap[] =
[SOC_RcmPeripheralClockSource_SYS_CLK] = UNSUPPORTED_CLOCK_SOURCE,
@@ -425,7 +425,7 @@ static uint16_t gControlssPllClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for I2C
-static uint16_t gI2cClkSrcValMap[] =
+static const uint16_t gI2cClkSrcValMap[] =
@@ -448,7 +448,7 @@ static uint16_t gI2cClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for LIN
-static uint16_t gLinUartClkSrcValMap[] =
+static const uint16_t gLinUartClkSrcValMap[] =
@@ -471,7 +471,7 @@ static uint16_t gLinUartClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for R5F and SYSCLK
-static uint16_t gR5SysClkSrcValMap[] =
+static const uint16_t gR5SysClkSrcValMap[] =
[SOC_RcmPeripheralClockSource_XTALCLK] = UNSUPPORTED_CLOCK_SOURCE,
@@ -494,7 +494,7 @@ static uint16_t gR5SysClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for Trace
-static uint16_t gTraceClkSrcValMap[] =
+static const uint16_t gTraceClkSrcValMap[] =
@@ -517,7 +517,7 @@ static uint16_t gTraceClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for CLKOUT
-static uint16_t gClkoutClkSrcValMap[] =
+static const uint16_t gClkoutClkSrcValMap[] =
@@ -540,7 +540,7 @@ static uint16_t gClkoutClkSrcValMap[] =
* @details
* Mapping Array between Reset Cause Bit and Reset Cause
-static SOC_RcmResetCause gResetBitToResetCause[12U] =
+static cosnt SOC_RcmResetCause gResetBitToResetCause[12U] =
SOC_RcmResetCause_POWER_ON_RESET,
SOC_RcmResetCause_WARM_RESET,
@@ -869,7 +869,7 @@ static uint32_t SBL_rcmIsDualCoreSwitchSupported(uint32_t cpuId)
static void SOC_rcmGetClkSrcAndDivReg (SOC_RcmPeripheralId periphId,
SOC_RcmPeripheralClockSource clkSource,
- uint16_t *clkSrcVal,
+ volatile uint16_t *clkSrcVal,
volatile uint32_t **clkSrcReg,
volatile uint32_t **clkdDivReg)
@@ -2066,7 +2066,7 @@ int32_t SOC_rcmSetPeripheralClock (SOC_RcmPeripheralId periphId,
uint32_t freqHz)
volatile uint32_t *ptrClkSrcReg, *ptrClkDivReg;
- uint16_t clkSrcVal;
+ volatile uint16_t clkSrcVal;
uint32_t clkDivisor;
int32_t retVal;
uint32_t Finp;
diff --git a/source/drivers/soc/am263x/soc_rcm.c b/source/drivers/soc/am263x/soc_rcm.c
index 5f91214501..90b8e9ce72 100644
--- a/source/drivers/soc/am263x/soc_rcm.c
+++ b/source/drivers/soc/am263x/soc_rcm.c
* @details
* @details
* Mapping Array between Clock mode and Clock Mode Value for QSPI
-static uint16_t gQspiClkSrcValMap[] =
+static const uint16_t gQspiClkSrcValMap[] =
@@ -241,7 +241,7 @@ static uint16_t gQspiClkSrcValMap[] =
* @details
* @details
* @details
* @details
* @details
* @details
@@ -379,7 +379,7 @@ static uint16_t gCptsClkSrcValMap[] =
* @details
* Mapping Array between Clock mode and Clock Mode Value for GPMC
-static uint16_t gGpmcClkSrcValMap[] =
+static const uint16_t gGpmcClkSrcValMap[] =
@@ -402,7 +402,7 @@ static uint16_t gGpmcClkSrcValMap[] =
* @details
* @details
* @details
* @details
* @details
* @details
* @details
+static const SOC_RcmResetCause gResetBitToResetCause[12U] =
@@ -2030,7 +2030,7 @@ int32_t SOC_rcmSetPeripheralClock (SOC_RcmPeripheralId periphId,
uint32_t freqHz)
+ uint16_t volatile clkSrcVal;
int32_t retVal;
uint32_t Finp;
2.50.1
Patch2: 0001-dpl-support-yieldable-log-processing.patch
From 2c284741b4154198c90bac70f92a26e6355dd402 Mon Sep 17 00:00:00 2001
Date: Sat, 22 Nov 2025 17:47:52 -0600
Subject: [PATCH] [dpl] support yieldable log processing
source/kernel/dpl/DebugP.h | 25 +++++++++++
.../nortos/dpl/common/DebugP_shmLogReader.c | 41 ++++++++++++++++---
2 files changed, 61 insertions(+), 5 deletions(-)
diff --git a/source/kernel/dpl/DebugP.h b/source/kernel/dpl/DebugP.h
index 896bab964d..a4f2925189 100644
--- a/source/kernel/dpl/DebugP.h
+++ b/source/kernel/dpl/DebugP.h
@@ -92,6 +92,16 @@ extern "C" {
#define DebugP_SHM_LOG_IS_VALID (0x12345678U)
+/** \brief Infinite read chunk size for the shared memory reader
+ * DebugP_shmLogReaderSetChunkSize(DebugP_SHM_LOG_READER_CHUNK_SIZE_INF)
+ * will make DebugP_shmLogRead() process the entire shared memory log in one go
+ * or until the end of the shared memory log is reached.
+#define DebugP_SHM_LOG_READER_CHUNK_SIZE_INF UINT16_MAX
* Macro defines the value of two
@@ -323,11 +333,26 @@ void DebugP_uartLogWriterPutChar(char character);
* The parameter `shmLog` is a array and is indexed using core ID as defined by \ref CSL_CoreID
+ * A single invocation processes up to DebugP_shmLogReaderGetChunkSize() log lines
* \param shmLog [in] Array of addresses of shared memory where the reader should read from.
* \param numCores [in] Number of entries in the shmLog array. Typically \ref CSL_CORE_ID_MAX
void DebugP_shmLogReaderInit(DebugP_ShmLog *shmLog, uint16_t numCores);
+/** \brief Set the read chunk size for the shared memory reader
+ * \param readChunkSize [in] The read chunk size in bytes.
+void DebugP_shmLogReaderSetChunkSize(uint16_t readChunkSize);
+/** \brief Get the read chunk size for the shared memory reader
+ * \return The read chunk size in bytes.
+uint16_t DebugP_shmLogReaderGetChunkSize(void);
* \brief Reads logs from shared memory.
diff --git a/source/kernel/nortos/dpl/common/DebugP_shmLogReader.c b/source/kernel/nortos/dpl/common/DebugP_shmLogReader.c
index 1af8d696b5..0db5f97b41 100755
--- a/source/kernel/nortos/dpl/common/DebugP_shmLogReader.c
+++ b/source/kernel/nortos/dpl/common/DebugP_shmLogReader.c
@@ -38,12 +38,19 @@
#define DEBUG_SHM_LOG_READER_LINE_BUF_SIZE (130u)
typedef struct {
uint8_t isCoreShmLogInialized[CSL_CORE_ID_MAX];
- DebugP_ShmLog *shmLog;
uint8_t numCores;
- char lineBuf[DEBUG_SHM_LOG_READER_LINE_BUF_SIZE+UNSIGNED_INTEGERVAL_THREE]; /* +3 to add \r\n and null char at end of string in worst case */
+ * Support yieldable log processing so user can return and perform other tasks e.g. petting watchdog
+ * This is useful in scenarios when:
+ * - Other cores produce logs at a faster rate than the reader can consume them
+ * - The reader has other tasks to perform e.g. petting watchdog, servicing I/O, etc
+ uint16_t chunkSize;
+ DebugP_ShmLog *shmLog;
+ char lineBuf[DEBUG_SHM_LOG_READER_LINE_BUF_SIZE+UNSIGNED_INTEGERVAL_THREE]; /* +3 to add \r\n and null char at end of string in worst case */
} DebugP_ShmLogReaderCtrl;
DebugP_ShmLogReaderCtrl gDebugShmLogReaderCtrl;
@@ -66,10 +73,21 @@ void DebugP_shmLogReaderInit(DebugP_ShmLog *shmLog, uint16_t numCores)
gDebugShmLogReaderCtrl.shmLog = shmLog;
gDebugShmLogReaderCtrl.numCores = (uint8_t)numCores;
+ gDebugShmLogReaderCtrl.chunkSize = DebugP_SHM_LOG_READER_CHUNK_SIZE_INF;
DebugP_shmLogReaderTaskCreate();
+void DebugP_shmLogReaderSetChunkSize(uint16_t chunkSize){
+ gDebugShmLogReaderCtrl.chunkSize = chunkSize;
+uint16_t DebugP_shmLogReaderGetChunkSize(void){
+ return gDebugShmLogReaderCtrl.chunkSize;
uint32_t DebugP_shmLogReaderGetString(DebugP_ShmLog *shmLog,
char *buf, uint32_t buf_size)
@@ -163,8 +181,10 @@ uint32_t DebugP_shmLogReaderGetString(DebugP_ShmLog *shmLog,
void DebugP_shmLogRead(void)
uint32_t i;
- for(i=0; i<gDebugShmLogReaderCtrl.numCores; i++)
+ uint32_t linesRead = 0;
+ static uint32_t coreIndex = 0;
+ for(i=coreIndex; i<gDebugShmLogReaderCtrl.numCores; i++)
DebugP_ShmLog *shmLog = &gDebugShmLogReaderCtrl.shmLog[i];
@@ -190,9 +210,20 @@ void DebugP_shmLogRead(void)
DebugP_log(gDebugShmLogReaderCtrl.lineBuf);
+ if (gDebugShmLogReaderCtrl.chunkSize != DebugP_SHM_LOG_READER_CHUNK_SIZE_INF){
+ linesRead++;
+ if (linesRead >= gDebugShmLogReaderCtrl.chunkSize){
+ /* Save core index so next invocation we resume log processing from the current core */
+ coreIndex = i;
+ return;
} while(strLen != 0U);
+ /* All logs processed without exceeding chunk size - reset core index to start from the beginning next invocation */
+ coreIndex = 0;
void DebugP_shmLogReaderTaskMain(void *args)
2.50.1
Patch 3: 0001-dpl-allow-enabling-disabling-shmLogWriter-line-prelu.patch
From b1055116b42a569cef993639b3432035c25ab876 Mon Sep 17 00:00:00 2001
Date: Mon, 1 Dec 2025 09:52:33 -0600
Subject: [PATCH] [dpl] allow enabling/disabling shmLogWriter line prelude
source/kernel/dpl/DebugP.h | 13 +++++++++++++
.../kernel/nortos/dpl/common/DebugP_shmLogWriter.c | 12 +++++++++++-
2 files changed, 24 insertions(+), 1 deletion(-)
index 896bab964d..909c966acd 100644
@@ -294,6 +294,19 @@ void DebugP_logZoneRestore(uint32_t logZoneMask);
void DebugP_shmLogWriterInit(DebugP_ShmLog *shmLog, uint16_t selfCoreId);
+ * \brief Enable auto prelude for shared memory log writer
+void DebugP_shmLogWriterPreludeEnable();
+ * \brief Disable auto prelude for shared memory log writer
+ * This is useful for creating structured logs
+void DebugP_shmLogWriterPreludeDisable();
* \brief Write a character to shared memory log
diff --git a/source/kernel/nortos/dpl/common/DebugP_shmLogWriter.c b/source/kernel/nortos/dpl/common/DebugP_shmLogWriter.c
index e309807af1..b260328744 100755
--- a/source/kernel/nortos/dpl/common/DebugP_shmLogWriter.c
+++ b/source/kernel/nortos/dpl/common/DebugP_shmLogWriter.c
@@ -39,6 +39,7 @@
static DebugP_ShmLog *gDebugShmLogWriter = NULL;
static const char *gDebugShmLogWriterSelfCoreName = "unknown";
+static uint8_t gDebugShmLogWriterPreludeEnabled = 0;
void DebugP_shmLogWriterPutLine(const uint8_t *buf, uint16_t num_bytes);
@@ -49,6 +50,7 @@ void DebugP_shmLogWriterInit(DebugP_ShmLog *shmLog, uint16_t selfCoreId)
gDebugShmLogWriter->rdIndex = 0;
gDebugShmLogWriter->wrIndex = 0;
gDebugShmLogWriter->isValid = DebugP_SHM_LOG_IS_VALID;
+ gDebugShmLogWriterPreludeEnabled = 1;
@@ -118,7 +120,7 @@ void DebugP_shmLogWriterPutChar(char character)
static uint8_t lineBuf[DebugP_SHM_LOG_WRITER_LINE_BUF_SIZE+UNSIGNED_INTEGERVAL_TWO]; /* +2 to add \r\n char at end of string in worst case */
static uint32_t lineBufIndex = 0;
- if(lineBufIndex==0U)
+ if(lineBufIndex==0U && gDebugShmLogWriterPreludeEnabled)
uint64_t curTime = ClockP_getTimeUsec();
@@ -154,3 +156,11 @@ static uint32_t lineBufIndex = 0;
+void DebugP_shmLogWriterPreludeEnable(){
+void DebugP_shmLogWriterPreludeDisable(){
+ gDebugShmLogWriterPreludeEnabled = 0;
2.50.1
I am creating this post because after discussion with Nilab, there is currently no process to merge pull requests made against the github mirror at https://github.com/TexasInstruments/mcupsdk-core/pulls.
