AM2634: Issue in Ethernet client and Server Transmission part.
Part Number: AM2634
Hi Ti,
i am using AM2634 in the customised board and we are using dp83822 ic.
we are using ti provided example code enet_cpsw_udp_igmp so our connection is like one customized board with another customized board
so,i flashed client coad with one board and server code in another board so totally 2 board.So, in one board server will transmit and receive message every 250ms and same wise for client also in another board so,
In server side ip address is 192.168.2.203 only one port and one socket is created.
In client side ip address is 192.168.2.210 in one ip we creted 6 different ports.[49607,49608,49609,49610,49611,49612].
we checked Client tx is fine and server Rx is getting data 11111,22222,...66666 from each portcorrectly but server tx and client rx is getting data loss and not proper order.
the below image is for the reference which we got.
i am attaching the test code server code zip file below,
https://lotuswirelesso365-my.sharepoint.com/:u:/g/personal/aakash_v_lotuswireless_com/IQDmdigWojZTRICqkosKOWN9AcCvLa1XHovLEwt5HDs49JA?e=PSq4UY
client code zip file below,
https://lotuswirelesso365-my.sharepoint.com/:u:/g/personal/aakash_v_lotuswireless_com/IQDkIRFkz2aOTr7T1L5W8IxIAUxFKwTZzJkpYpKL_4hmpKU?e=qwG9Z0
main.c file below
https://lotuswirelesso365-my.sharepoint.com/:u:/g/personal/aakash_v_lotuswireless_com/IQB3JDmRuwD1SahVr3TkG4V7Adc6OQby7SJky71yJBjSczw?e=6G1qv4
can you kindly check the issue and let me know.Your's replay is mostly welcome.
